Anyone do body/collision work on one of these trucks yet? Door check captive nut broken.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by unclejunk, Oct 27, 2020.
  1. Oct 27, 2020 at 4:02 AM
    unclejunk
    unclejunk [OP] Well-Known Member
    Albany NY
    '18 Quicksand OR DCSB 6MT
    So long story short.. I bent my drivers door back a bit past where its supposed to go, marked up the door slightly, but more importantly.. it broke the welded/captive nut for the door check.
    Now the door check is loose, so it makes that awful click/clack sound when opening and closing, and I can't tighten it. I also can't remove the bolt to put in a nutsert and solve the problem.
    Does anyone know if there is any way to access that welded nut for the door check? If I start pulling interior panels, is there a small window I can get a wrench/socket/something in there? Or pull the fender liner? Or do I have to pull the entire fender? Or is it maybe not even accessible without cutting a window somewhere...
    I've never seen one of these trucks apart and can't seem to find any pictures out there.
