Anyone doing ovtunes in Denver?
Discussion in 'Colorado' started by Goodtimes, Nov 19, 2020.
  1. Nov 19, 2020 at 8:59 PM
    Goodtimes
    Goodtimes [OP] Well-Known Member
    Hey everyone, looking at doing an ovtune. Any opinions or feedback on it? Before I buy it from them anyone doing it locally? Thanks
    ORtoCOTaco and MGMSangTaco like this.
  2. Nov 20, 2020 at 12:18 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    johntoyota likes this.
  3. Nov 20, 2020 at 5:53 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I can help you out with it if you want to just have your ECU flashed and not worry about being able to do it yourself on the fly
    What year is your truck?
  4. Nov 20, 2020 at 6:53 AM
    Goodtimes
    Hey John, it's a 2019 dcsb auto.
  5. Nov 20, 2020 at 7:05 AM
    johntoyota
    Down yonder in TN
    16 truck
    OK. It would take a few visits together to get it set up. I would have to unlock your ECU ID which can take a few days. But first we would have to verify what your ECU ID is.
  6. Nov 21, 2020 at 12:16 AM
    johntoyota
    Down yonder in TN
    16 truck
    100% you can! Youll love it! You can get more low end torque, smoother throttle, we can give you all your throttle instead of the laggy acceleration which is especially awesome in 4LO and you can force the tranny to stay in a certain gear if you want. My truck is night and day different with it. I will never go back to the factory tune..
    Youre a 17 arent you? We might get lucky and you have the same ECU ID as me which will save a lot of time and a little bit of money too. Call me and we can talk about it.
  7. Nov 23, 2020 at 7:03 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    he may not be 04b04 - possisble he is still 04b02 or 04b03 if he has not had the TSB (s) done. I have a premium and regular octane I'm sure he would like for 04b04. One for general use and one for towing with significant tip-in. LMK.
    and FWIW - you would be better off downloading the TS software and doing the TSB yourself - dealing with the stealership on these (TSB) is brain damage and a waste of time. Look in the signature block of @tonered or @lapoltba for the TS link. GL.
  8. Nov 23, 2020 at 7:25 AM
    johntoyota
    Down yonder in TN
    16 truck
    Yeah we talked about it this weekend. Ill do the TS method if it is needed.
  9. Dec 3, 2020 at 8:20 AM
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    Groove toyota on Broadway flashed my ecu to 04b04 last year when I brought it in asking for the cold throttle stumble TSB. I've never seen much pushback from their service dept.
    Adding to the positive feedback...OVT is a must have for anyone that lives at elevation. I was smiling ear to ear the first time I blasted up to the Eisenhower tunnel without having to be screaming at 4300 rpm in third gear.
  10. Dec 3, 2020 at 8:25 AM
    Goodtimes
    Awesome to hear, can't wait to get the tune. It was annoying on stock tires, extra annoying on 285s
  11. Dec 3, 2020 at 8:45 AM
    Kerbouchard!
    Englewood, CO
    fishin' tank
    For sure--I should have mentioned that I also had gears done. I put the 4.88s in December 2019 and drove it with the stock ecu calibration for about 9 months. It was much better, but wasn't until OVT that I was totally satisfied. If you plan to keep the truck for the longer term, do both. Expensive, but totally worth it.
  12. Dec 6, 2020 at 11:33 AM
    RedZeppelin
    RedZeppelin Well-Known Member
    Wondering if I can get in on this too. All the vfTuner stuff seems like a lot of work when in reality I wouldn’t be fiddling with parameters and settings. OVT 2.0 sounds like the most I want/need. 2017 TRDOR DCSB and I have the TSB 0077-16 applied but not sure the ECU ID. I typically go for the 87 octane but since we’re at elevation does the 85 work with OVT’s 87 performance file? Like @Kerbouchard! said, I would love to not be on the floor going up to Eisenhower. Thanks
    edit: if there’s a better file for my needs I’m all ears. I can also pay in beer
    xxTacocaTxx and Kerbouchard! like this.
  13. Dec 6, 2020 at 3:58 PM
    Kerbouchard!
    Englewood, CO
    fishin' tank
    OVT has an octane learning component. The standard octane will be fine for any of the 80 series grades of gas. The premium octane has a specific tune.
    I can flash anyone who is on 04b04. I haven't downloaded or tried Tech Stream yet, but I'd be willing to give it a shot if you need to flash a TSB.
  14. Dec 7, 2020 at 7:09 AM
    RedZeppelin
    @johntoyota what would it take to get flashed? From what I know, 2.0 is the last version that OVT is offering so that's as much as I need.
  15. Dec 7, 2020 at 7:12 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
  16. Dec 7, 2020 at 7:14 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Didn’t the new Toyota TSB make the OVtune stuff obsolete. I’ve read it’s as good if not better.
  17. Dec 7, 2020 at 7:24 AM
    OVTune
    OVTune Well-Known Member
    OVTune
    No, it didn't. And just like any TSB, we will have tuned versions of that TBS which will be better than the TSB itself.
    xxTacocaTxx and JoeCOVA[QUOTED] like this.
  18. Dec 7, 2020 at 7:25 AM
    RedZeppelin
    I had TSB0077-16 in early July before the factory warranty expired. It's a little less shifty around town, but low-mid power is definitely still lacking. It's still impossible to pull that I-70 stretch from Golden to Genesee without hitting 3rd gear a few times. If I have more than just me in the truck, I have to keep it in s3 and just rev to 4k to keep up with the semis
  19. Dec 7, 2020 at 7:54 AM
    JoeCOVA
    Joe
    Colorado Springs
    Ah good to know.
  20. Dec 7, 2020 at 8:36 AM
    johntoyota
    Down yonder in TN
    16 truck
    What year truck are you?
    Also, 2.0 final is still not out yet. So we are dealing with his preliminary releases that are not going to be as complete as the final that will hopefully be out soon.
