Anyone done the DIY AC recharge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdex8357, Oct 18, 2024.
  1. Oct 18, 2024 at 5:08 PM
    cdex8357
    cdex8357 [OP] “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    My 2013 Tacoma is only blowing cold from the driver side vent. It’s been sitting for about 6 months.. haven’t driven it much cause I got a company car now.
    wondering if there are any recommendations for this?
    R1234yf is what it uses I think.
  2. Oct 18, 2024 at 5:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It uses R134a.
    - Not 1234yf -
    You need a set of gauges at a minimum.
    Stay away from the DIY “Fix in a can” stuff.
    Taco'09 and Jimmyh like this.
  3. Oct 18, 2024 at 7:19 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    thanks man.. I caught it right before in when to AZ. I need to do that.. got the can crap gauges. Prolly over charged now. Work on it tomorrow
    TnShooter[QUOTED] likes this.
  4. Oct 18, 2024 at 7:49 PM
    TacoTuesday1
    FL
    I use an r134a machine
  5. Oct 18, 2024 at 8:04 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You have other problems if only one side is blowing cold. Probably some mice building a nest inside your ducts.
    Frog4aday likes this.
  6. Oct 19, 2024 at 1:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The common symptom of a low charge is cool on the drivers side and it is warmer as you go towards the passenger side. Then when it gets low enough it stops working at all.
    Greg-tacoma, Williston and TnShooter like this.
  7. Oct 19, 2024 at 1:32 PM
    JasonLee
    15 TRD OffRoad
    oh, I did not know that. Thanks for calling that out specifically.
    Jimmyh[QUOTED] likes this.
  8. Oct 19, 2024 at 3:38 PM
    TacoTuesday1
    FL
    Performing a recharge is a part of diagnosis
  9. Oct 19, 2024 at 4:18 PM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x4
    I agree, fix-in-a-can should be avoided -- I think it's required to contain a leak-sealing compound. Once that's in your system, nobody will want to service it, because it will gum up their recovery equipment.
    I used some in a pinch... summer road-trip in 110+ degree temperatures and it stopped blowing cold, on a Sunday so shops were closed. It was actually the compressor failing to cycle, but that may have been due to lack of charge. Bought an all-in-one recharge can and put ... probably 14 ounces in, sitting there in the car-parts-zone parking lot. Started blowing cold again right away.
    I then purchased a new compressor (mine had in fact been leaking -- I can see the dye down there), hoses, and condenser... plus a vacuum pump and manifold setup, and refrigerant. But I have yet to actually do the job. In part because nobody will evacuate the system for me, and I don't want to discharge it outside. But mostly because... shit, it still works. And that was several years ago.
    I will eventually have to vent it myself and replace all these parts. The risk is that, if the compressor grenades, then I'll also need to replace the evaporator, which is a huge pain in the ass. Doing it preemptively would save me that trouble... but dang, it just keeps working, so I guess I'm okay with that risk.
    Edit: Re-reading this, I can see how it can be interpreted as an endorsement of the recharge kits. In a way, it is. But I would recommend proper repair, for the long-term.
  10. Oct 19, 2024 at 6:03 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Had this issue with a previous car. Diagnosis was a leaky high-side schrader valve. Replaced/recharged and problem fiixed.
