Anyone down to take on a blown head gasket job in Norcal?
Discussion in 'Northern California' started by grand, Jan 10, 2013.
  1. Jan 10, 2013 at 10:52 PM
    grand
    grand [OP] New Member
    Im new on this forum. Hello! :)
    Im located in Alameda. I can pay in cash and or beer, hell, even hard liquor. Breakfast, lunch and dinner included. Depending how efficient you are to get this done, tiddy bar I can take you there too!
    I have a 97 Tacoma 4 cylinder, base model 5speed. Theres coolant in one of the cylinders and im running on 3 cylinders. I did not drive the car once I noticed this issue.
    I hoping someone thats capable of doing this job locally. I want to avoid the dealership rape session as much as I can.
    Anyone down to help a brother out?
  2. Jan 11, 2013 at 12:16 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    I wish i could, but i swore off side jobs 2 years ago. I will ask some guys i used to work with.
  3. Jan 11, 2013 at 12:17 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Should take you about 4hours said and done. Its easy, good luck.. I've done them plenty.
  4. Jan 11, 2013 at 5:41 PM
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    i have no experience with that but willing to help, howdy neighbor, hayward here.
  5. Jan 11, 2013 at 5:56 PM
    Walker
    Walker Well-Known Member
    Walker
    Weippe, Idaho
    10 Trd OffRoad
    3" procomp, Light Racing UCA's
    Make sure you get the head resurfaced when you do the head gasket and while you at it why dont you do a valve job, thats what i do everytime i pull a head.
  6. Jan 11, 2013 at 6:55 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    I can do it. 1500 though. I can take partial payment in kettle corn. lol
  7. Jan 11, 2013 at 11:43 PM
    gixxerguy01
    gixxerguy01 Member
    Norcal
    06 DC TRD OR 4X4
    TRD S/C, APR X1, 3" lift, Pro Comp MX6R shocks, Firestone Ride Rite bags, 285/75/R16 BFG AT, Painted handles & mirrors. Billet grill. Tinted front windows.
    Head gasket job will take about 2 days. Depends on turn around time on machine shop. You should send the cylinder head to a machine shop for pressure testing & resurfacing before reinstalling it. Straight edge the block to check for warpage. Make sure all surfaces are prepared & clean. Good time to do a valve adjustment by replacing shims that are out of spec.
  8. Jan 12, 2013 at 5:00 AM
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    Just a note, I believe the 3RZ-FE head bolts are TTY, so you'll need a new set every time you take it off.
  9. Jan 12, 2013 at 10:58 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Maybe a magnaflux too?
  10. Jan 14, 2013 at 12:39 AM
    gixxerguy01
    gixxerguy01 Member
    Norcal
    06 DC TRD OR 4X4
    You cannot magnaflux aluminum. Pressure testing is one way to check for cracks on aluminum heads.
  11. Jan 14, 2013 at 4:19 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Dye penetrant is what works for aluminum. Magnaflux or dye penetrant on steel.
    What was the cause for the blown gasket? It will be a key factor on if it's worth replacing the gasket, or the whole engine.
  12. Jan 14, 2013 at 2:13 PM
    brian
    Elizabeth City, NC
    Didn't know they were aluminum. Last truck I owned had cast heads so it came to mind.
  13. Jan 21, 2013 at 10:19 AM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    Hasen't every yota yead since the late 70's been aluminum. I can't think of one thats not.
    when i redbuilt my 2rz head i re-used head bolts and had no issues. As long as you check thickness of bolts and clean out bolt threads with a tap and compressed air you should be fine. Now tourging down an iron head is a different story and i wouldn't recomend re-using those bolts even though did once cause they typically are good for one re-usage.
    I would never take the head off without making sure it needed re-surfacing and cheking for leaky valves. So it could be 4-6 hours or several days depending on what shape its in.
