Anyone Else Changing Wiper Blade Inserts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pushgears, Jan 18, 2022.
  1. Jan 18, 2022 at 3:00 AM
    pushgears
    pushgears [OP] Well-Known Member
    2021 OR DCSB MT
    I changed the wiper blade inserts this weekend. My local dealer doesn't stock them, and my brother asked why not change the whole blade? My reasoning is that the inserts are 1/4 the price and at $15/pair, I can change them every 5000 miles. Half a century ago, I learned in Driver's Ed that "visual acuity is 90% of your driving", and there is nothing like new wipers.
    Am I the only one?
    rainsux and mquibble like this.
  2. Jan 18, 2022 at 3:07 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Most people on here replace the inserts. Personally, I don't think the stock Tacoma wipers are the greatest but they are easy to change and do last a while.
    Tacospike likes this.
  3. Jan 18, 2022 at 3:09 AM
    Tacospike
    Two Trucks
    Not the only one. A lot of people have just change the blade
    hr206 and Skydvrr like this.
  4. Jan 18, 2022 at 3:25 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Nope. I've been using beem blade style wipers for years, and I'm not going back to conventional.
  5. Jan 18, 2022 at 3:47 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Inserts. The aftermarket wipers I have tried ended up in the garbage after a short time.
    TartanEagle and bulalo like this.
  6. Jan 18, 2022 at 4:21 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Give the wipers a cleaning with alcohol and paper towel. The first few passes will be really black. After a few wipes it stops. Then they are clean. Wipe down the windshield while your at it. This extends the wiper blades life.
  7. Jan 18, 2022 at 4:48 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    +1 to cleaning the blade I, too, use alcohol. A friend of mine uses emery cloth and it seems to work well.
    mquibble likes this.
  8. Jan 18, 2022 at 4:59 AM
    nl_tacoma
    nl_tacoma Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    I change the inserts and use Toyota winter wipers in the winter. Much better than the all season wipers for not freezing up - there's no frame.
    I got hosed at the dealer during a service couple of years ago. Service advisor told me the wipers needed to be replaced. I knew one was getting bad. Cost was around $38 (Canadian) each for the Toyota wipers. I passed. I had a set of Michelin wipers that I got on promotion at a parts store that I would use. They didn't work well at all - would chatter across the windshield. Did a quick check on here and that's when I found out that the Toyota OEM wipers have replaceable inserts. Parts guys at the dealership found it strange I wanted complete wipers. Then I told him the story. Inserts were like $15 each I think. Unfortunately, I had thrown mine out - the one time I didn't keep old wipers for spares. Expensive lesson in listening to "service" advisor. My fault. I should have known better.
    PacoTheTaco303, mquibble and JGO like this.
  9. Jan 18, 2022 at 5:02 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Inserts only.
    Chew likes this.
  10. Jan 18, 2022 at 6:32 AM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    RainEx on the windshield and Alcohol on the blade works very nice. Some advise to lastly wipe the blade with WD40 and let it sit a bit. Tried that and it also works well.
  11. Jan 18, 2022 at 6:39 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    I use Trico Flex blades, (beam style). I can get them on Amazon for around $11 each. Ran the on my 1st Gen for many years as well. Never had an issue with them.
  12. Jan 18, 2022 at 6:55 AM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    My 2017 had nearly 90,000 miles and I’ve changed the entire blades 2 times. They’re not that expensive but to each their own..
  13. Jan 18, 2022 at 7:10 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I use the refills on the tacoma since I can have the dealer order them for me. I have changed them once. I usually change the wipers about every year. On previous vehicles I bought new blades every time. A ot of the time the beam style ones. They are much more expensive and I don't think they work significantly better than the refills. cleaning your blades once in a while and rainXing your windshield a few times a year helps much more I believe.
  14. Jan 18, 2022 at 7:12 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Toyota refill blades are the best bang for the buck option. I think they’re great, and they are inexpensive.
  15. Jan 18, 2022 at 7:29 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The options may depend on the region.
    It has been years since I've seen the blade refills in this area. The blade/arm assembly is just about in every store selling auto parts. The price on these arms has dropped since they first hit the market. I can get a set (2) for the Tacoma for about $20. I replace them when streaking, skipping or chattering begins. The time to replace is less than 5 minutes.
    The refills (if available) are nearly the same cost and are a more tedious replacement with the threading thru the claws.
    For $20 and 5 minutes to replace.....it doesn't make sense to stretch the wiper life or to fiddle around restoring the blade with a rub down using alcohol or WD-40 (good lord).
  16. Jan 18, 2022 at 7:39 AM
    Chicken_Taco
    Chicken_Taco Well-Known Member
    Comfortably numb on the Darkside of the moon
    2019 Midnight Black Tacoma TRD Sport
    Working on it ...
    At Christmas every year I get all my kids a new set of wiper blades for their cars. Also the wife, guess who changes her blades out? I feel like this way I know at least once a year everyone is getting new wipers on their car.
    My younger son has a 2018 Camry. We put new complete new blades on his car but I saved his old Original ones. I would like to see if I can just get the refill from the dealer.
    cookiedough likes this.
  17. Oct 27, 2023 at 11:21 AM
    radio_dave
    radio_dave Member
    Dave
    2016 Tacoma SR5
    Tried to replace the inserts last year for the original Toyota wipers. Had to take them back because the inserts were too big (much too big). Returned the inserts and ended up buying brand new Toyota wipers instead.
    Today I bought new inserts at the dealership again, and they are too big! Much too big!
    Anyone else?
  18. Oct 27, 2023 at 11:27 AM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    I also change the inserts. I have a spare set in my console if needed. I also have a spare set of OEM brake pad and rotors ready to go on when I need to change them. My plan is to take the used rotors and have them turned. I will keep this rotation going until I need to get another set. It may take awhile.
  19. Oct 27, 2023 at 11:32 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Nope. Mine from the dealer fit perfect and worked great.
    $6 a pair, I bought two pair. Installed one, the other in the parts locker. Last set (original) lasted 5 years (then one side split), can't go wrong with that value.
  20. Oct 27, 2023 at 11:34 AM
    suprafastcelica
    Tiffin, OH
    Parts numbers are listed below.
    85214-04030
    85214-0E140
