Anyone Else Changing Wiper Blade Inserts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pushgears, Jan 18, 2022.
  1. Oct 27, 2023 at 11:50 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    How hard/how much effort is it supposed take to remove the inserts from the OEM wiper frames? I have new ones (inserts) and have watched the videos that are around, but it seems like it takes way too much force remove them or even get them started. I'm working from the correct end to remove the old insert. Neither wiper insert wants to budge and it feels like something is going to get bent if I try forcing them any further. Tnx
  2. Oct 27, 2023 at 12:07 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Pinch the wee clip embedded into the rubber (at one end).
    Williston[QUOTED] likes this.
  3. Oct 27, 2023 at 12:08 PM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    Did you buy the truck new or used. Does it have non oem blades on it?
  4. Oct 27, 2023 at 12:24 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    If they're oem as TartanEagle said there's sort of a metal nib/clip that you have to compress to get past the indents on the holder. Have a close look. Needs finesse not force.
  5. Oct 27, 2023 at 1:13 PM
    Williston
    New England
    I purchased the truck used, and recognizing the blades on it weren't OEM, I purchased the Toyota blade assemblies from the dealer soon after and with a spare set of inserts. I'll give it another try. Thanks!
  6. Oct 27, 2023 at 1:16 PM
    Tallwalker
    Tallwalker Too tall to hide, too old to run.
    Inserts here as well. I also use RainX on the windshield, clean the blades with alcohol, then while they are still standing up wipe them with 3m protectorent. Once dry wipe with paper towel to get any excess off and good for another year.
    JGO, michael roberts and TartanEagle like this.
  7. Oct 27, 2023 at 1:16 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I tried those latitude blades once had them on for a week they were horrible left streaks everywhere. Went back to just inserts way better and cheaper .
  8. Oct 27, 2023 at 2:44 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    What about the Toyota sight line wiper blades? The dealer sells them
  9. Oct 27, 2023 at 3:01 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    To be efficient really I think you need two sets of OEM blades and inserts. That way you can always have a fresh set ready to go. Changing the inserts isn’t hard- but it can be messed up easily. Then you would have a truck you can’t drive because you do not have a wiper on it. Seems like unnecessary stress.
  10. Oct 27, 2023 at 3:04 PM
    Williston
    New England
    I use them in the winter and I think they are pretty good. With the design they have I don't think they ice up as easily. I always liked either the Bosch OEM's or the Icon's too, but last time I checked they were approaching $30 each.
    Gfenza89[QUOTED] likes this.
  11. Oct 27, 2023 at 3:07 PM
    TartanEagle
    '17 ACLB 4x4 MT
    "3M"? or "303"? Just double checking.
  12. Oct 27, 2023 at 3:16 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Yes, and have been changing inserts on Bosch aka VW/Audi blade inserts since 1990.
  13. Oct 27, 2023 at 3:40 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    With the entire month of July 110-118 degrees mine melted to the glass - so I replaced with Bosch.
  14. Oct 27, 2023 at 5:02 PM
    Mike Z
    Mike Z Well-Known Member
    Subaru Hybrid wiper blades last much longer than Toyota or aftermarket blades. I used them on my 09 Tacoma and plan to use them on my 2023 when needed. They last years on a car that is not garaged. Reasonably priced.
  15. Oct 27, 2023 at 5:23 PM
    #35
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I like the OEM inserts and blades. Works well even with heavier snow build up.
    I live in the desert so the inserts get replaced every 2 years when they start to dry out.
    I clean them each fuel up and wipe them with silicone spray about once a month.
  16. Oct 27, 2023 at 5:32 PM
    #36
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    IPA on rubber doesn’t seem like the best idea. I’ve always just used dish soap on a rag when I’m washing the car to clean the blades. Never had an issue.
    Canadian Caber likes this.
  17. Oct 27, 2023 at 5:45 PM
    #37
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    I have used alcohol prep pads on wiper blades before if they get grease or something on them. Works really well in a pinch on the road but probably will shorten the life.
  18. Oct 27, 2023 at 6:23 PM
    #38
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Yep can vouch for this. Wife has an Outback. Those wipers last forever. And ever.
  19. Oct 27, 2023 at 7:04 PM
    #39
    Tallwalker
    yeah, sorry. 303.
    TartanEagle[QUOTED] likes this.
  20. Oct 27, 2023 at 7:08 PM
    #40
    Sinister184
    Just changed the inserts on my 2019 Camry for good measure as it’s running up on 5 years. Honestly I could have left them longer as they were still holding up to FL monsoons just fine. I wouldn’t see any need to seek alternatives personally.
    TartanEagle and cookiedough like this.
