Anyone else coated the bed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by First Taco, May 22, 2012.
  1. May 22, 2012 at 12:05 AM
    First Taco
    First Taco [OP] Well-Known Member
    Robert
    Wa
    TRD Sport 4by4 4.0
    The plastic bed. I like the light weight but hate when stuff slides.
    I have another truck that has the spray liner. So I bought two cans of Herculon from o'rielly's. It did the job and looks great plus added some toughness to it. I just did the bed not the side or gate.
  2. May 22, 2012 at 12:38 AM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    got any pics? how did you prep it? i want to do the same thing
  3. May 22, 2012 at 12:44 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I got the oem bed mat and nothing really slide around.
  4. May 22, 2012 at 12:49 AM
    aznutx
    DFW Texas
    2011 White TRD
    been in the market for a bed mat but at 60-120 bucks, figured a can or two of spray would/could do the same thing
  5. May 22, 2012 at 1:29 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    ^^ This.
    The difference is that the bed mat can be removed.
    No prep required for the mat, other than get your shit out of the bed first.
    Frank
  6. May 22, 2012 at 2:17 AM
    First Taco
    Robert
    Wa
    TRD Sport 4by4 4.0
    Just masted it off with the blue masking tape. Around the outside of the bed on the inside about 1/4 inch up off the bed all the way except I opened the tail gate. np preping but washing it out with a little soap rinse and dry. 1 can per coat two coats so 2 cans.
    Stuff is way better than a mat!
  7. May 22, 2012 at 2:41 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
  8. May 22, 2012 at 2:46 AM
    Highland Logan
    Frank
    Nova Scotia, Canada
    I'm glad it turned out for you... but better than a mat? Mats come out, liner does not.
    Agreed!
    Frank
  9. May 22, 2012 at 6:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The spray-in or brush-on (off the shelf) liner won't last forever. If its exposed to the weather, you'll have to re-apply it in a few years - plus, if you drag anything heavy across it, it will scratch off.
    (I coated my 96 tacoma bed with Herculiner)
    My 07 tacoma has a Protecta Bed mat in it and I absolutely love it!! You can buy them for like $50
  10. May 22, 2012 at 7:21 AM
    aznutx
    DFW Texas
    2011 White TRD
    yeah bed mat is removable but how often do you remove it or want to? also at 15bucks for two cans is another +, weight maybe insufficient but over time it could add up in gas, just saying, i would also like a bed mat but at the price... spray liner could be the way to go
  11. May 22, 2012 at 8:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The weight of a bed mat will not play into the equation even in the slightest bit...
    I like the rubber mat because it's softer than the spray in liners. I have a shell so can end up on my knees loading and unloading stuff and the spray in liners can cure very hard and actually cut you or the bottom of a cardboard box if you're not careful. I'm still a big supporter of the rubber bed mat, it takes a LOT of abuse, doesn't tear, never needs to be reapplied, 0 maintenance and can be removed (say if you buy a new Taco).
  12. May 22, 2012 at 8:24 AM
    Janster
    Jandy
    Lancaster, PA
    Make sure you read the instruction on the cans..... application might not be 'as easy' as you think. Prep work may be needed and could be a royal PITA. Especially - make sure its compatible with the bed (plastic).
    When I installed Herculiner on my 96 - We put the stuff in a couple foam cups so we could paint the edges and get ready to roll it. The Herculiner ATE right thru the foam cups.....
  13. May 22, 2012 at 8:37 AM
    aznutx
    DFW Texas
    2011 White TRD
    well weight is a logistical thing, weight = more gas, so even if it's 5cents a year, it's still 5 cents a year, ya i know moot point but a point nonetheless
    definately agree it is softer and the main reason for me wanting one, the removablity is only second, so i might still go this route
    i agree with everything here but i got a folding tonneau so sun wont be an issue so im hoping it lasts more than a couple years, prep work should be easier than what i did with my first truck so im good with that
    haha in the end ill probably just buy a cheap mat i find on craiglist if i ever do.
  14. May 22, 2012 at 8:45 AM
    Janster
    Jandy
    Lancaster, PA
    It's not the sun I'm referring to....
    It's the chemical composition of the spray-on liner that may react with the plastic. Read the warning labels and make sure the stuff is GOOD to apply on the composite bed/plastic. Just to be safe....
  15. May 22, 2012 at 10:19 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Paint/Liner adds weight too.
    Mats also tend to have better grip with less chance of damaging soft materials (finished wood for example)
    I hope the stuff sticks to the composite bed well. I wanted to get my wifes 4R fenders and bumper LineX'd and the shop didn't want to because those types of coatings are not made for and do not bond well with plastic.
    Hope it turns out like you want and better than I think it will...but I'd be ready to get a bed mat if I was you...
  16. May 22, 2012 at 10:32 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Brunes, I just did the step pads & bar ends on my nerfs (well the whole bar actually).
    I scuffed it up pretty good, wiped down with a promoter then sprayed with rustoleum bed coating, 2 light coats.
    It covered great & adhered very well to the plastic, was very surprised & if it does chip would just touch it up. It was $7 a can at lowes.
    I think Will (tacomaman06) did his with herculiner & it held up.
    As far as the mat or liner, I loved my mat & was able to take it with me.
    It is in the back of the tundra on top of the line-x ;)
  17. May 22, 2012 at 11:40 AM
    First Taco
    Robert
    Wa
    TRD Sport 4by4 4.0
    You are right that is the difference. Since the mat gets water and dirt under it and then the dirt wears the bed material be it plastic or painted metal.
    Plus the mat shifts around. Had them before and there not for me.
    The spray on or in this case. The brush on liner is right for me.
    If you like the mat better use it!
  18. May 22, 2012 at 2:05 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    No need to be snarky.. I've yet to see my mat shift around the bed, or anything I put on it. As to dirt, that's why we wash them. Enjoy your spray on, really. But post some pictures however.
    Frank
  19. May 22, 2012 at 2:06 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    this is a loser thread.
  20. May 23, 2012 at 6:38 PM
    LexusIS808
    LexusIS808 Well-Known Member
    my bed is herculined, bed mat on top and a tonneau cover.
