Anyone else develope a seep/leak at front valve cover?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Feb 11, 2019.
  1. Feb 11, 2019 at 9:45 AM
    TnShooter
    TnShooter [OP] Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
    Seems I had a seep since around 70k.
    It is where the timing cover and valve cover meet.
    Sarted on passenger side and now @ 114k the driver side has started.
    I wouldn't call it a leak yet. As there aren't any drips. ...yet....
    I noticed the passenger side a few years ago.
    I'm not too worried about it currently.
    But I am guessing I'll have to do gaskets eventually.
    Any one else seen this before?
  2. Feb 11, 2019 at 11:19 AM
    Tcomaboy
    Tcomaboy Well-Known Member
    TX
    2010 PreRunner Sr5 TRD LongBed
    Your year is known for gasket problems. Looks like you may have one.
    TnShooter [OP] likes this.
  3. Feb 11, 2019 at 12:41 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    the timing cover is the valve cover.
    mine started at 115K miles, give or take. easy fix.
  4. Feb 11, 2019 at 1:09 PM
    TnShooter
    STOCK
    Does it require you to take the front timing cover off.
    Or just remove valve cove and replace the gasket?
  5. Feb 11, 2019 at 1:20 PM
    TnShooter
    STOCK
    After some research:
    It looks like you only need to remove the upper intake.
    Then install new gaskets.
  6. Feb 11, 2019 at 4:03 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Front of the passenger side valve cover? My 08 has had that for years. Tightened it up a few years ago and it slowly came back. Not worrying unless it's really leaking.
  7. Feb 11, 2019 at 4:05 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Port Arthur/Lubbock, Tx
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yeah. Mine plus 2 other people I know have leaky valve covers.
    2011, 2005 and 2008
  8. Feb 11, 2019 at 5:31 PM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    Yep, my '06 too! I just cranked the couple of bolts down a bit right there on the pass front corner. I noticed when I purchased @ 122K miles.
    Watching to see how it goes.
  9. Feb 14, 2019 at 10:29 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I just had my passenger side valve cover gasket done. The drivers side is still dry. Passenger side was leaking for probably the last 7 years/45K. My mechanic actually told me I'm too particular and could have left it alone, wasn't leaking onto exhaust and didn't show low on the dipstick.
    I would watch the driver's side pretty close, the alternator is directly underneath that front corner area, not good to get that wet.
    No need to pull timing cover to change valve cover gaskets.
