Anyone else ever get code P106B Secondary Air Injection Pressure Sensor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hexnutter, Nov 22, 2021.
  1. Nov 22, 2021 at 10:42 AM
    hexnutter
    hexnutter [OP] Well-Known Member
    doug
    Tacoma
    Hey guys. This looks like a tricky one I may just take to the mechanic.
    Got back from advanced auto and got three codes, all p106b which means I need a better scanner as they are one of these
    Vapor Pressure Pump sensor
    Air Pump Pressure sensor (Absolute)
    Air Pump2 Pressure sensor (Absolute)
    2012 reg cab 2.7l 140,00 miles
    Any thoughts people?
  2. Nov 22, 2021 at 10:58 AM
    optysite
    optysite Well-Known Member
    ‘15 TRD OR Magnetic Grey
    Does the 2.7l have an air injector like the v6?
  3. Nov 22, 2021 at 12:02 PM
    hexnutter
    doug
    Tacoma
    Oh yea I just put a uni filter on it. One pressure switch is in the carbon canister and two are in the air valves, but this is in the fuel/air mixture system not the secondary air injection system which is separate, but Im not sure. Emissions stuff if any one given part of the mixture is out of wack you get a cel, that way it works optimally or it doesnt at all.
  4. Nov 22, 2021 at 4:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    P106B means the pressure sensors for the Secondary Air Injection System and the EVAP system don't agree when the engine is off, you will need a scan tool that can display data for both sensors to see which one is not reporting correctly and then troubleshoot that sensor.
    TnShooter likes this.
  5. Nov 22, 2021 at 4:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes the 2.7L 2nd gens all had Secondary Air Injection, it wasn't added to the 4.0L until 2012.
  6. Nov 23, 2021 at 6:25 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Is it in limp mode?
  7. Nov 24, 2021 at 7:23 AM
    hexnutter
    doug
    Tacoma
    Oh no not in limp mode. I can disconnect the battery and it seems to go away for a month maybe.
    Cool thanks. Im guessing a canister then, but Ill take it in, could be the secondary air injection valve (yes I only have one) sensor.
    It started doing this after I cleaned the throttle body, coincidence I guess.
