Anyone else get the axle shaft separation recall?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fourfourone, Feb 27, 2024.
  1. Apr 15, 2024 at 6:46 AM
    #321
    dietcokefiend
    dietcokefiend Well-Known Member
    Interesting they would go to a file flat method. I know its not a huge amount but you'd still get some measurable angle applied to the flat surface manually filing it. Surprised they didn't figure out some sort of device that uses the bolt hold as a guide and a tool like a deburring thing to remove it in a more precise manner.
  2. Apr 15, 2024 at 8:09 AM
    #322
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    I went to my appointment to dealer this past Saturday at 9:40 am, I got out at 11:44 am. 2 hours, I could have taken shuttle home, but still cannot go anywhere, so I waited.:rolleyes:
    Faster way would be changing nuts, but they said have to order. I looked at ends of rear axle, they look clean both sides. I don’t see file marks on axle nuts.‍♂️
  3. Apr 15, 2024 at 9:03 AM
    #323
    NewEnglandMayMay
    NewEnglandMayMay Active Member
    2023 White Taco OR
    None
    My app indicated 2 days ago that I should call for an appointment...did that today. The contact person scheduled me for April 25. She seemed to be in a foul mood...don't know if it was work related or a bad hair day!!!
  4. Apr 15, 2024 at 9:46 AM
    #324
    STEELeR43
    Hawaii
    Probraly both. Dealer service department can get zillion calls for service, whatever. But never know. Dealer must all tide up if schedule for next week Thursday.:D
  5. Apr 15, 2024 at 12:07 PM
    #325
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Dealer told me they needed my VIN to order parts but didn't say which, and will call me when they arrive to schedule an appointment. Haven't gone in for them to see anything either, I wonder what parts they plan to replace
  6. Apr 16, 2024 at 12:43 AM
    #326
    STEELeR43
    Hawaii
    Nuts for flange side ends of rear axle, how many got welding debris, I do not know.
    My coworker's work 3rd gen Tacoma got the same recall notice. Toyota dealer told my work, they have to order parts, then schedule, I assume.
    fiftysix[QUOTED] likes this.
  7. Apr 16, 2024 at 2:52 AM
    #327
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I checked mine the paint marks applied by the factory are all still lined up correctly and torque is good. I will probably just check mine each time I change the oil. I can’t see taking mine to the dealer to just have something damaged when I leave there.
    I have had bad luck with dealer service department. I can take my truck in for one issue and leave with two more.
  8. Apr 16, 2024 at 3:44 AM
    #328
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    STEELeR43, they’re eight each retaining nuts four on each side on the hub assembly flange.
    fiftysix likes this.
  9. Apr 16, 2024 at 4:21 AM
    #329
    newguy88
    newguy88 Member
    Took the truck in yesterday to a local Toyota dealer here in Raleigh NC, I will say they are a top notch outfit. Very good mechanics. I know many of them personally. They inspected both rear axles up on lift. All 8 nuts passed the toyota recall inspection specs. Not much slag and all nuts were inspected underneath, retorqued to factory specs. Test drove, sent me on my way. 2:55 pm drop off done and in truck at 4:35. So i'm now done with this recall. I can load repair ticket if anyone is interested.
    MagicToolbox, apipeguy and fiftysix like this.
  10. Apr 16, 2024 at 4:37 AM
    #330
    fiftysix
    Midwest
    Thanks sir
  11. Apr 16, 2024 at 5:41 AM
    #331
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Does your repair ticket give the torque spec they used? The service manual indicates 33 ft. Lbs. I’m just curious have they increased the torque for the recall.
  12. Apr 16, 2024 at 5:46 AM
    #332
    newguy88
    newguy88 Member
    I talked to the tech. Back to factory Spec. 33 Pounds. All good .
    t0p_d0g[QUOTED] likes this.
  13. Apr 16, 2024 at 6:19 AM
    #333
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Thank you!
  14. Apr 16, 2024 at 8:09 AM
    #334
    STEELeR43
    Hawaii
    I know how many retaining nuts on rear axle sides. But my bad, typo. I should have wrote, “I don’t know how many rear side axle nuts have welding debris, or no more.”
  15. Apr 16, 2024 at 8:18 AM
    #335
    nucl3ar
    nucl3ar 2021 White Tacoma Limited 4x4
    Raleigh, NC
    OVTune Meso Total Tail Stage 1 tail lights BAKFlip MX4 Tonneau Cover
    I am down in Fuquay, which dealership did you go to?
  16. Apr 16, 2024 at 8:54 AM
    #336
    newguy88
    newguy88 Member
    Fred Anderson Raleigh, you could go down to Sanford also
    nucl3ar[QUOTED] likes this.
  17. Apr 16, 2024 at 9:08 AM
    #337
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    No problem.
  18. Apr 16, 2024 at 1:43 PM
    #338
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    I got the recall taken care of today.
    Took the dealer two hours. They were doing an overall vehicle inspection then inspecting the recalled part.
    They said they didn't find any weld spatter there and retorqued the axle nuts. I got told I was good to go and the recall is now taken care of.
    If the part has to be recalled though, I would have needed to take my truck back home while they order the part, then take my truck back in again once that part arrives
  19. Apr 16, 2024 at 3:08 PM
    #339
    STEELeR43
    Hawaii
    I got call from my Toyota dealer. Parts for recall came in for my 2023 Tacoma, so I made appointment for this weekend. Recall suppose to taken care of.:D
  20. Apr 16, 2024 at 6:49 PM
    #340
    apipeguy
    apipeguy Member
    David
    2023 Tacoma TRD Pro
    I’ve been speaking to the assistant manager of the service department on this. He told me that Toyota would not just send them bulk parts and that the inspection had to be done that then they could order the parts needed. I was told they could get them in a day or two.
