Anyone else have squeaks in A/C blower assembly?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SlurpeeBlueMetallic, Dec 6, 2009.
  1. Dec 6, 2009 at 4:20 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic [OP] FFFFFFUUUUUUUUUUUUUUU...
    Two days ago I started to hear an intermittent cricket-like chirp coming from behind the glove box when the fan blower was on to #1 or #2 speeds. (Not to be confused with the "behind the glove box buzz" which I fixed up prior.)
    I dropped the glove box (I'm becoming rather practiced at this since fixing the buzz :rolleyes:) and took out the cabin air filter and cleaned it (1 leaf, 1 pine needle, something I couldn't identify but looked to be insect-like) but the noise persisted.
    It only happens with the blower on #1 (lower speeds) or #2 positions. If I set the blower to #3 or #4 (higher speeds) the noise stops. So I took out the cabin air filter again and watched the blower fan (#87103B on this diagram). On speed #1 or #2 there appears to be a very slight wobble in the blower... higher speeds straightens it out so that it rotates level. I figure this has worn a bearing or is just rubbing somewhere in the assembly as whomping it with my hand moderately on the bottom of the assembly (the part that pokes out from under the passenger-side dash) makes the noise stop momentarily.
    I'll likely take it in for the dealer to look at as I'm still under warranty but that's a pain - dealer is an hour away - so it'll be a few weeks before I can spare the time. Anyone had this problem before and know of something I can do (other than keep the blower off or on high :rolleyes:) in the meantime?
  2. Dec 6, 2009 at 4:35 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    yes, its very common
  3. Dec 6, 2009 at 4:36 PM
    SlurpeeBlueMetallic
    hmm.. I tried searching before posting, guess I must have used the wrong key words. Hopefully it's common enough that the dealer Service Manager won't look at me like I'm speaking Portuguese and have three heads.
  4. Dec 6, 2009 at 4:41 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
  5. Dec 6, 2009 at 4:42 PM
    gtokarski
    gtokarski Well-Known Member
    George
    Dublin, CA
    06 4x4 xtra cab silver
    OME 886, AAL, ARB Bumper, XRC8 Winch, Sony MEX-N5000BT, and one angry beagle.
  6. Dec 6, 2009 at 4:44 PM
    SlurpeeBlueMetallic
  7. Dec 6, 2009 at 4:47 PM
    SlurpeeBlueMetallic
    I hear you... I just got the damn buzzing noise fixed and then this crops up. Although it was probably always there but I assumed it was related to the buzzing... now that it's gone I can hear this chirping in all its glory.
  8. Dec 6, 2009 at 5:15 PM
    Artiz
    Artiz This space is in BLANK mode.
    IMHO the A/C serves no purpose (you don't need to flame me, it's my opinion only), but you should be happy with the Toyota, imagine what the squeaks would end up being on a Ford, a blown-up motor assembly or tranny. :D
  9. Dec 6, 2009 at 5:19 PM
    gtokarski
    George
    Dublin, CA
    Going without AC here is like going without a heater in the great white north.
  10. Dec 6, 2009 at 5:24 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    i have crickets too but im starting to get used to them. or sometimes i just turn my music up so loud i cant hear them
  11. Dec 6, 2009 at 5:27 PM
    JAG
    JAG Well-Known Member
    Sometimes even leaves get down in there... might need to clean it out.
  12. Dec 6, 2009 at 5:32 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    this mostly fixed it for me, theres just a few leaves left in there
  13. Jan 4, 2010 at 6:08 PM
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    Thanks for posting this! It's been bugging the crap out of me for a couple of weeks. I'll fix it this weekend.
  14. Jan 4, 2010 at 6:12 PM
    busatodd
    busatodd BUSATODD
    whiteland
    2016 limited mgm
    3rd gen 5100 bilstiens set at 0 with ome 888s, LR UCA, 5160 bilstiens in back with icon 3 leaf aal with 1" block. Fuel savage wheel wrapped in nitto ridge grapplers 285/70/17
    mine was blower fan, and had it replaced under extended warrenty. easy to replace.:D
  15. Jan 4, 2010 at 6:40 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    Mine has the squeak too, along with a short somewhere in the fan. It works most of the time, then I hit a bump and it stops. I have to reach down and tap the bottom of it with the end of a maglight to make it come back on. One day I'll get tired of it and fork out the $145 to replace it...
  16. Jan 4, 2010 at 7:36 PM
    HARDSHELLTACO
    HARDSHELLTACO HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I want to do this right now, but it is 19 outside. Maybe tomorrow. Good info anyway.
  17. Jan 5, 2010 at 4:35 AM
    911-3.2
    911-3.2 Well-Known Member
    CT
    Sold - 2010 Access Cab 4x4 I4 SR5
    Curt Receiver Hitch, Access Literider Tonneau
    I had the same issue and it turned out to be the blower motor. The dealer replaced it under warranty without a hassle and it has been silent ever since.
  18. Jan 5, 2010 at 7:57 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    Mine has done it since I bough the truck new. Once I had the dealer adjust the balance screws, but the crickets came back. Sometimes it does it, sometimes it doesn't, but usually it does and drives me crazy!!! The dealer ordered a new blower motor and getting it replaced on Monday. Hopefully fixes it!
  19. Jan 5, 2010 at 12:09 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
  20. Jan 5, 2010 at 7:58 PM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I followed these instructions from post 19
    http://www.toyotanation.com/forum/sh...14#post2143214
    You can see what he is talking about by looking at pics below. However i figured out you really don't have to take the blower out. The black cover will come off the bottom of the blower by taking the four phillips screws out of the bottom. First undo the two clips that hold the wiring in place and then carefully pry the black cover off. You can adjust the two screws on the bottom of the motor from here. It helps if you have a stubby Phillips head as there is not much room. I just played around with it until the sound went away. Re-assemble and enjoy.
    This is the blower assembly.
    This is a bottom view with the black cover on.
    This is the bottom view with cover off. The two gold colored screws are what you adjust.
