Anyone else have their LED daytime running light stopped working lately
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tocobob, Oct 6, 2017.
  1. Oct 6, 2017 at 2:49 PM
    Tocobob
    Tocobob [OP] Well-Known Member
    I just noticed mine are no longer working on my 2017 Offroad. Was curious if an online update might have changed anything. I did double check and make sure they were turned on in the head unit.
  2. Oct 6, 2017 at 3:13 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Yikes. I'll check mine before I leave work. I leave them on all the time unless I'm using the headlights on the way home.
    Are they all the way not working? or intermittent?
  3. Oct 6, 2017 at 3:16 PM
    Tocobob
    When the switch is on for just the day time lights they are off. Headlights on they are lit.
  4. Oct 6, 2017 at 3:25 PM
    nDub
    Lead Free Gasoline
    Are we talking about the DRL lights? I though those were on if you put the switch there.
  5. Oct 6, 2017 at 3:28 PM
    Tocobob
    Yes my DRL lights are not on with the stalk switch in the first position where they should be. When I put the stalk into headlights on the LED DRL part lights up but dim.
  6. Oct 6, 2017 at 3:44 PM
    bgoods
    bgoods Well-Known Member
    Brian
    Orlando
    2016 TRD Sport 4x4
    Check that they are not set to off on the head unit. Setup, Vehicle, light settings
  7. Oct 6, 2017 at 3:45 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    i unplugged mine, looks cheap
  8. Oct 6, 2017 at 3:48 PM
    Tocobob
    They are on in the head unit. I turn them on and off several times in there and did a battery reset.
  9. Oct 6, 2017 at 4:23 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You're not trying to check them with the truck in park right?
    Tocobob[OP] likes this.
  10. Oct 6, 2017 at 4:25 PM
    TacoLpastor
    TacoLpastor Well-Known Member
    NC
    2016 DCLB OR 4X4
    They don't turn on until the parking brake is off, I have noticed.
    jsinnard and Tocobob[OP] like this.
  11. Oct 6, 2017 at 4:30 PM
    Tocobob
    Good info! Just checked no go. Maybe mine just took a shit Thanks everyone. Fuse check in the AM.
  12. Oct 6, 2017 at 4:41 PM
    Tocobob
    Wait..I was checking with the key on engine off. Just started the truck and cycled the handbrake and restarted. It is now working!! Thanks again for ur thoughts!
  13. Oct 6, 2017 at 4:48 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yep, I run mine all the time and noticed a while ago they don't come on til the truck is on, in gear and the parking brake released.
  14. Oct 6, 2017 at 4:48 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Was the brake set? Perhaps maybe by just a click?
    Parking brakes aren't all that strong you could probably drive with the brake all the way set. If the brake was barely engaged you'd never feel it.
  15. Oct 6, 2017 at 4:56 PM
    Tocobob
    It's very possible. This is where this forum is awesome! I had my meter ready for the next day and definitely would have over thought it. Plus I have a bunch of LED lights ready to install. Thanks again everyone four great input and no bullshit
  16. Oct 6, 2017 at 5:14 PM
    batacoma
    batacoma Truck Wars
    I drove around for almost a month with the p brake barely engaged. This was a work truck so I never thought to check the pb since I never used the pb, and I didnt pay attention to the gauge cluster since all the service lights was already on.
