Anyone else have this much of a factory rake? Also, leveling options.
Discussion in 'Suspension' started by TACK, Mar 8, 2015.
  1. Mar 8, 2015 at 1:11 PM
    TACK
    TACK [OP] Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    My truck is stock and the rear is 2.5" higher than the front (measured directly up the center of the hub to the fender). Anyone else have this much?
    From everything I've read on here, I know you don't necessarily lift the front as much as the front-rear difference to achieve a level stance. With my measurements, how much should I lift the front to sit close to level, and how would you recommend doing so?
    My truck: 2010 prerunner, trd off road, access cab, 3 leaf pack, 34k miles.
  2. Mar 8, 2015 at 4:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you just buy the truck?
    Doesn't sound like it has the stock springs. That's highly unusual that the stock springs are 2.5" higher than the front. Are they new springs?
  3. Mar 8, 2015 at 4:48 PM
    TACK
    Nevada
    No, I bought it new in October 2009.
  4. Mar 13, 2015 at 5:26 PM
    TACK
    Nevada
    Anyone? :(
  5. Mar 13, 2015 at 5:28 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Nope almost everyone here has bro lean from crappy stock leafs haha
    Edit: going off your measurements all you have to do is lift the front 2.5...
    This would be incredibly easy to accomplish. You can get bilstein 5100s and set them at 2.5 It will rather stiff though. Or you can get a toytec lift for 2.5.
    OR if you wanna be fancy most quality coilovers (fox, king, icon, sway-a-way) come preset at 2.5.
    The good thing about keeping your lift under 2.5 is you don't need new UCAs to correct allignment
  6. Mar 13, 2015 at 5:40 PM
    TACK
    Nevada
    LOL, I definitely don't want to end up with bro lean. I want to be careful not to lift the front too much.
    Thanks for the reply. I will check out those options.
  7. Mar 13, 2015 at 5:42 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'd do 5100s up front at 1.75 with stock coils and call it a day.
  8. Mar 13, 2015 at 5:45 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    This is what I would do in your situation as well.
  9. Mar 13, 2015 at 5:52 PM
    TACK
    Nevada
    That's exactly what I was expecting to hear, haha :p
  10. Mar 13, 2015 at 5:55 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Where are you measuring from. Almost positive you are not measuring right.
  11. Mar 13, 2015 at 5:55 PM
    T4RFTMFW
    It makes the most sense IMO. $200 will get it done, minus alignment.
  12. Mar 13, 2015 at 5:56 PM
    T4RFTMFW
    I'm kinda curious if he somehow has a 4 leaf pack.
  13. Mar 13, 2015 at 6:06 PM
    TACK
    Nevada
    I went out and measured again, from the top of the rim center cap straight up to the fender. I'm getting around 2 1/4" difference.
    And definitely a 3-leaf pack, not 4.
  14. Mar 13, 2015 at 6:07 PM
    T4RFTMFW
    Crazy. What are your actual measurements?
  15. Mar 13, 2015 at 6:10 PM
    TACK
    Nevada
    If I remember correctly, passenger side was front 18.5" and rear 20.75". Driver side was similar, but 1/4" lower on both (I think).
  16. Mar 13, 2015 at 8:36 PM
    T4RFTMFW
    I think your front is a bit low and your rear is normal.
  17. Mar 13, 2015 at 8:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Even with my lift set at 2.5 in front my rake is still 2" in difference front to back. I kind of like it and because I threw in a AAL on both sides in the rear I can see why it is as much rake as it is. My rear is at 2.25" BTW.
  18. Mar 16, 2015 at 5:02 PM
    TACK
    Nevada
    I think I'm going to go with 5100s set at 1.75". I'll post pics and measurements when it's done.
    What's the best place to buy from?
  19. Mar 16, 2015 at 5:18 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    I think this is the cheapest place.... not positive though
  20. Mar 16, 2015 at 5:21 PM
    T4RFTMFW
