Anyone else have transfercase troubles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WCoyne, Jan 27, 2016.
  1. Jan 27, 2016 at 7:25 PM
    WCoyne
    WCoyne [OP] Well-Known Member
    EastTN
    2016 F150 Platinum Fx4
    Fuel Nutz blacked with milled 2 piece wheels, 285/65/20 BFG KO2 tires, Icon Stage2
    I am asking because my nephews 2016 Trd OR would not come out of 4lo and has been sitting at the local dealership now for over a week because the actuator is backordered. We tried everything to get it to come out and nothing worked. The dealer told him to drive it in and he was lucky that we had snow covered roads or a tow truck would of been needed.
  2. Jan 28, 2016 at 11:51 AM
    WCoyne
    EastTN
    Nobody else? I guess this is just a fluke incident and toyota doesn't have any actuators because of that
  3. Feb 3, 2016 at 6:43 PM
    WCoyne
    EastTN
    Bump
    The truck has now been at the dealership for two weeks and promised to be fixed on 8 different dates now. I went today to check on the status and was told the 16th. I mentioned this in another thread but I figured I would hopefully hear someone else experience with this problem in my own thread.
  4. Feb 3, 2016 at 6:50 PM
    2016spicytaco
    2016spicytaco Spicy Kitty
    Al
    Denver, Colorado
    Turd Gen for Life
    I haven't had any issues. I have already used the truck in 4H, 4L and 2wd without any issues.
  5. Feb 3, 2016 at 7:00 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    @Mike330R had some early rear diff issues that sound a bit like this
    Edit: doh sorry mis-read this as a diff problem rather than a t-case problem.
  6. Feb 3, 2016 at 7:07 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Mine has been fine so far
  7. Feb 3, 2016 at 7:09 PM
    WCoyne
    EastTN
    His truck is the second one at this dealership to have this problem. The first one came off the trailer and wouldn't come out of 4lo.
    The dealer says its an actuator that toyota doesn't have or won't ship them. Service manager says he will try for a new transfer case tomorrow but I don't see that happening. The truck was ordered because none of the local dealers are getting the premium, tech, jbl pkg around here.
  8. Feb 3, 2016 at 7:10 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Also, not sure if this would help, but you might try to see if they can manually turn off the locker and disable it, so that you can at least drive the truck in the meantime.
    If they're not being amenable, and you have other dealerships around, you might also call around on service departments. Toyota Care pays for towing, hopefully between dealerships as well.
    Hope you get things sorted out shortly.
    B.
  9. Feb 3, 2016 at 7:15 PM
    WCoyne
    EastTN
    I know nothing about the new tacoma's transfercase so what does the differential lock have to do with the transfer case? I asked today if this could be only a problem with the trd off road and whether the other models had the same transfer case since they do not have crawl control
  10. Feb 4, 2016 at 12:29 PM
    WCoyne
    EastTN
    Well I don't know what changed but they just called and his truck is ready. I don't know if you can believe anything you hear at a car dealership and my family has been in the car business since the 40's.
    I guess they don't like confrontation in the showroom when they are trying to make sales
    MacToma likes this.
  11. Feb 4, 2016 at 1:31 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Mine was in the rear diff, had issues going into 4LO. Actuator switch thats PULLS the gears together was not working.
    How do you know it's the T-case and not the rear diff?
  12. Feb 4, 2016 at 5:25 PM
    WCoyne
    EastTN
    They said it was an actuator switch inside the transfer case. This was the second tacoma to have this issue at the same dealership. His truck would not come out of 4lo no matter what. I tried 15-20 times to get it out and he tried after talking too me and the service dept in how to get stout when he couldn't.
    Was your problem part of the rear locker? I am use to the way 4wd's worked years ago and not so much on all the electrical controlled 4wds. I have had Eaton E-lockers and Arb air lockers on vehicles in the past but have no knowledge of toyotas new system other than how to use it
    Does the rear diff lock once you put it in 4lo? I thought you still had to turn the locker on and according to the sales guy only once you're already stuck which sounds stupid. Anytime I have been stuck it was time for a winch or someone to pull me out. Turning the locker on at the point would be useless
  13. Feb 4, 2016 at 6:58 PM
    Gutt Pile
    Gutt Pile Well-Known Member
    2016 Blazing Blue TRD Offroad
    Had this happen once to mine but restarting the car and putting it into neutral worked . Have not tried putting it into low since.
  14. Feb 4, 2016 at 7:31 PM
    Mike330R
    Far West Phoenix
    Yes mine was rear diff/locker.
    No it doesn't lock when you put in 4LO. You have to push the lock button.
  15. Feb 4, 2016 at 7:41 PM
    WCoyne
    EastTN
    Its great that yours came out of 4 low after restarting. We tried everything except unhooking the battery to see if it would reset back to 2wd. That probably wouldn't work either but who knows with all the electronics in newer vehicles these days.
  16. Feb 4, 2016 at 7:42 PM
    WCoyne
    EastTN
    Thats what I thought but when you mentioned the locker and not being able to go into 4lo i wasn't sure
  17. Feb 7, 2016 at 11:33 AM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    I'm having an issue with mine right now with it being stuck in 4 Low....V6 Auto
    Fixing to go try again.
  18. Feb 7, 2016 at 7:52 PM
    WCoyne
    EastTN
    They had to order an actuator to go in the transfercase to fix my nephews and the dealer or toyota one took their time getting it. Its a 2-3 day turn around at the least unless they have the part in stock. The transfercase has to come out to replace the actuator
  19. Feb 8, 2016 at 2:38 AM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    I had mine towed to the dealer Sunday before the Super Bowl....Hopefully they can fix it before the snow hits...
  20. Feb 8, 2016 at 5:42 AM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Hopefully they gave you a loaner while youre waiting.
