Anyone else not satisfied with their 6 MT?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EH530, Dec 4, 2018.
  1. Jul 29, 2019 at 11:08 AM
    #401
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Maybe the dealer botched the bleed. Il try bleeding it myself.
    tonered[QUOTED] likes this.
  2. Jul 29, 2019 at 11:15 AM
    #402
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It sounds like it? In the end, it should either leave it the same or improve the situation, as long as you don't get more air in there. :D
    I always advise against using a vacuum bleeder on clutches. I failed miserably twice, but others have posted successes in the past. I stick to the helper method. Some folks around here have done the gravity bleed after doing the ADM.
    If doing the helper method, the clutch pedal will not spring back after you close the nipple. You have to manually pick it up and pump it a couple times.
    CygnusX191 likes this.
  3. Jul 29, 2019 at 11:21 AM
    #403
    Burro09
    Miami, FL
    Yeah, this is exactly how i have bled clutches before. With a helper. Never had issues and yea, you gotta manually lift the pedal because once the bleeder gets closed, it stays down there.
    Il see if the heat/rain allows me to get under the truck this afternoon.
