Anyone else running an oil catch can?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lavrishevo, Nov 30, 2023.
  1. Nov 30, 2023 at 5:24 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Wrong side... Catch can should be on the PCV hose on the driver's side cylinder bank:
    The 3.5L head design can cause oil to pool near the back of the head on inclines and get pumped up through the PCV valve. This can cause a lot of smoke during steep off-road climbs. That's the real reason for a catch can on our trucks. Millions of pavement-princess Tacomas do just fine without one.
    Since you put the catch can on the vent hose upstream of the throttle body, which side of the can sees vacuum? ;)
  2. Nov 30, 2023 at 5:28 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    this ^^^^^^
  3. Nov 30, 2023 at 5:29 PM
    Bishop84
    Bishop84 Well-Known Member
    From my experience there’s no benefit shy of the steep angles.
    The v6 ring lands have been awesome thanks to the d4s.
    The up coming 4 banger I’d consider a catch can but it’s realm hard to say how effective it will be.
    The out going port injected four cylinder rav4s are all burning oil and I blame recirc for most of it.
    musicisevil, Junkhead and 3JOH22A like this.
  4. Nov 30, 2023 at 6:00 PM
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
    Not really a need for a catch can. Our engines are D4S which has port injection to help keep the valves clean
    Jakerou and Junkhead like this.
  5. Nov 30, 2023 at 8:16 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Had a catch can on my DI GTI, not bothering on the 3.5
    Junkhead likes this.
  6. Dec 1, 2023 at 2:55 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I use a JLT as he is local and builds quality parts.
  7. Dec 1, 2023 at 12:36 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Could someone please explain this deficiency with the V6. Is it limited to just one side of the V6 heads or both. Pictures of the inside of the head(s) would be appreciated.
    Currently, I have a vision of some oil collecting at the back of the head(s) on inclines that somehow collects deep enough to be routed somewhere it shouldn't be. My ignorant thoughts are: wouldn't a pipe from the back of the head(s) directly down to the oil sump get rid of the problem on inclines?
    Thefear87 likes this.
  8. Dec 1, 2023 at 12:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The PCV valve happens to be at the rear of the bank 2 valve cover. Oil may collect at the rear of bank 1 head in an incline, but there isn't a vent hose there connected to the intake.
    Drainage pipes would solve this problem, but it requires drilling and tapping both heads and the oil pan. It's prone to introducing leaks. A catch can is easier.
    Jeeps with the 3.6L V6 have the same problem, and there's a plethora of catch can kits available, some even with factory-style quick-connect fittings.
    Toycoma2021[QUOTED] and bulalo like this.
  9. Dec 1, 2023 at 6:21 PM
    Toycoma2021
    So, Toyota failed to take into account the attitudes these trucks would be operated under and did not provision oil galley drains in the most rear position on the heads & block down to the sump. I wonder if Toyota originally designed this engine for transverse mounted applications.
    One more question for those in the know: Does the oil being introduced into the intake manifold cause any long-term problems other than a possible carbon buildup on the intake valves? I recognize the D4S fuel injection may in time remove the possible carbon buildup making it all moot.
    Otherwise, if I do not mind the occasional smoke out my tail pipe when loitering on steep hills do I need to be concerned?
  10. Dec 1, 2023 at 6:40 PM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    I believe some other threads that talk about gen 3 engines pointed out that the engine was originally used in the Sienna van which is front wheel drive and uses a cvt to boot.
  11. Dec 1, 2023 at 6:42 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Look at this OP's intake. But valves look fabulous.
    bulalo likes this.
  12. Dec 1, 2023 at 6:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Toyota used the 2GR family in both longitudinal and transverse applications. Lexus IS350 and GS350 had it since 2005, and RC350 since 2015. The Tacoma is the first off-road application.
    Burning too much oil will poison your catalytic converters more quickly.
    I consider the catch can to be just another off-road mod where Toyota came up short, like the diff breather relocation or removing the front airdam.
    Toycoma2021[QUOTED] likes this.
  13. Dec 1, 2023 at 7:00 PM
    MGMDesertTaco
    I think that motor's toast.
  14. Dec 1, 2023 at 7:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Click through his posts in that thread and you see a lot of dirt and sand buildup in the intake. That engine was killed by his K&N filter.
    Jakerou likes this.
  15. Dec 1, 2023 at 7:43 PM
    #35
    Vlady
    Issy, WA
    It is not about his intake. Look at his intake valves. Even in that situation, d4s does its job
    3JOH22A[QUOTED] likes this.
  16. Dec 2, 2023 at 7:02 AM
    #36
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    The catch can will keep that oil residue out of the intake. That is one positive……about the only one.
  17. Mar 20, 2024 at 4:31 PM
    #37
    lavrishevo
    lavrishevo [OP] Well-Known Member
    2023 Trail Edition
    faawrenchbndr likes this.
  18. Mar 20, 2024 at 4:42 PM
    #38
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    I have one and like it for the dirty oil that doesnt get cycled through my engine.
    faawrenchbndr and lavrishevo[OP] like this.
  19. Mar 20, 2024 at 4:44 PM
    #39
    lavrishevo
    2023 Trail Edition
    I don’t think it makes it back into the crank case. It cakes up the intake manifold if anything.
  20. Mar 20, 2024 at 4:45 PM
    #40
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have the jtl setup with canister extension. Been running most of 231k+ miles works great . Does it job ,catches all that crude that will not make it back threw the intake manifold. Highly recommend these for our trucks .
