Anyone Else Think the Rear Glass is Not A Great Design
Discussion in '4th Gen. Tacomas (2024+)' started by MJB4450, Mar 1, 2025.
  1. May 12, 2025 at 1:25 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    One can't carry flimsy 16 foot long Trex deck boards like that, but 3 of them can be carried thru the back window and onto the dashboard wrapped in a blanket.
    The back end of the boards can rest on and pass behind the opened tailgate. They can then be strapped down, so as not to move forward into the windshield...for most stops.
    That loading method works with a shell/canopy, with the rear glass lowered.
    This is done when a person needs to return a few extra boards after building a deck.
    With a shell/canopy, passing items thru the back sliding window into the cab also works for carrying long, lightweight interior molding during wet, dirty winter weather when you want to keep it clean and dry for interior painting and staining.
    TurboDA6 likes this.
  2. May 12, 2025 at 1:32 PM
    OregontoBajaCA
    2025 OR DC iF Max
    If you spray water on the roof, you'll see that it exits from behind and under the corner of the rear window.
    There's a water channel under the sides of the rear window.
    nurp42[QUOTED] likes this.
  3. May 12, 2025 at 1:54 PM
    roalddahl
    roalddahl Well-Known Member
    2025 DCLB OR Terra (pending), 2011 Access cab OR Silver
    Glued/epoxied on or did you start drilling?
  4. May 12, 2025 at 2:01 PM
    nurp42
    nurp42 Well-Known Member
    SoCal
    '24 PreRunner
    Just the 3M double-stick adhesive used for many accessories.
    roalddahl[QUOTED] likes this.
  5. May 15, 2025 at 6:07 AM
    Bogeypro
    Bogeypro Member
    2024 Ice Cap TRD OR hybrid
    Some of y'all worry about the strangest things.
