Anyone else with a 20/21 with leaking diff problems?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myn75, Jul 27, 2021.
  1. Jul 31, 2021 at 8:55 PM
    #41
    myn75
    myn75 [OP] Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    lol with a full undercoating anyone can sleep easy, they'll never know its even seeping or leaking under there!
  2. Aug 1, 2021 at 7:32 AM
    #42
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    That's what I thought after reading my OM for my SR. I had 3 quarts of diff oil but had to go buy an extra qt. at the parts store to top it up. Not sure but now I'm curious about my rear gear ratio...
    Not curious enough to verify though, I've been driving it for 2.5 years now....
    I added the extra quart with no problem, had to stick my pinkie in the fill hole to make sure the oil was near the top....it was.
  3. Oct 15, 2024 at 10:06 AM
    #43
    johnnytwotimes
    johnnytwotimes Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    Just checking in, has this issue been resolved? Crawled under the truck to find seepage around the rear diff no leakage yet. Cleaned it with degreaser and will be monitoring from here on out. Called toyota to express my concerns but after reading a few threads on here about this issue the dealership will absolutely be last resort.
  4. Oct 15, 2024 at 12:17 PM
    #44
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    My weeping went away after a few hundred miles. But I also did a two way diff breather/relocation so not sure if that helped or is related. There is a TSB to retorque the nuts.
    johnnytwotimes likes this.
  5. Oct 15, 2024 at 3:43 PM
    #45
    myn75
    Nor Cal
    I would disregard and accept the seepage rate provided it doesn’t increase. The diff gasket for the mating surface is a paper-like material and if you think about it some seepage is expected. Mine seeped in the beginning but now it does not.
  6. Oct 15, 2024 at 3:50 PM
    #46
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Try retorquing the nuts before anything else.
  7. Oct 15, 2024 at 4:37 PM
    #47
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    Called the dealership for this but no TSBs opened.
