Anyone elses gas gauge horribly inaccurate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfrea, Jun 4, 2012.
  1. Jun 5, 2012 at 6:56 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If I really top off the truck, it runs on full about 80 miles before going down. When the light goes on, I have gone as far as 50 miles before filling up without running out. Sounds normal....:cool:
    (with a 3 gal reserve, @ 20 mpg your at 60 miles)
  2. Jun 5, 2012 at 7:04 AM
    badger
    badger Well-Known Member
    07 SR5
    Nothing to add to what Oz and Blueberry have said, except that a Scangauge is the best answer. Mine is well calibrated and is never off more than a couple of tenths of a gallon in a tank full. It also reads accurate water temp and other things. The factory gauges are all just ballpark indicators. I've had a couple of unplanned instances where the Scangauge has given me confidence to reach a station with just a few tenths to spare. I would never be without one again.
    The key though is to spend the time to thoroughly calibrate it.
  3. Jun 5, 2012 at 7:05 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I've noticed that as well. My old 74 Monte Carlo was a big block car (454) and when I would stand on the gas to pass someone, I could just watch that fuel gauge drop a little closer to "E"! ;)
  4. Jun 5, 2012 at 7:49 AM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    What's the other starting tsb other than the cold start? Cause it was def not cold out when I tried starting it...
  5. Jun 5, 2012 at 11:31 AM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    EG011-07 : Engine Controls - Intermittent No Start Condition
    EG043-05 : Fuel System - MIL ON/DTC's/No Start in Extreme Cold
  6. Jun 5, 2012 at 11:33 AM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Thanks for the info! Since this was the first time it has ever happened, I think i'll just let it slide for now. But it'll def be in the back of my mind.
  7. Jun 5, 2012 at 11:39 AM
    Blueberry
    Nick
    Newton, KS
    My pleasure sir. Hope it was just a one time deal for ya.
  8. Jun 5, 2012 at 2:20 PM
    20Jim12
    20Jim12 Member
    Jim
    Maine
    SR5 DC-4.0
    Any gas gauge is just an approximate reading, doesn't matter what brand you drive.
  9. Jun 5, 2012 at 2:27 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    And shorten the life of the fuel pump from lack of fuel to keep it cool. The best practice is to fill up when you hit a quarter of a tank. Besides the manufacturers purposely setting the low fuel light to come on and/or the needle hitting "E" so that people don't suddenly freak out it serves a mechanical purpose as well since fuel pumps are located inside the tank nowadays.
  10. Jun 5, 2012 at 5:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This is the # 1 answer. I have never seen my low fuel light come on. I fill at 1/2 to 1/4 tank. It doesn't cost anything more to keep it full than it does to keep it empty.
  11. Jun 5, 2012 at 7:34 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    FWIW - I've run my cars down to E for years - never replaced a fuel pump.
  12. Jun 6, 2012 at 2:14 AM
    dexterdog
    Oly WA
    2012 F150
    luck is on your side or your not quite running it low enough.
  13. Jun 6, 2012 at 7:56 AM
    2004TacomaSR5
    Jon
    Montana
    Gotta love our 4 bangers eh? I have gone close to 100 miles before mine moves, only once though.
  14. Jun 6, 2012 at 8:08 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Old wive's tale. Only actual documented cases of this happening, that I've found, is on the last generation Chebby trucks. Since then "everyone" seems to think this will happen on all makes/manufacturers.
    Just as a subjective experience, I had my last truck (02 Dakota) for 8 years and almost always ran the fuel down to a gallon or so before fill up. Lotsa Internet banter on "that's a guaranteed way" to ruin the fuel pump there too. Never an issue.
    Had the Tacoma for over 3 years now, still use the same fuelup method, I'll let you know if it fails :p
    As far as the accuracy of the fuel guage,,, it's as accurate as the fuel guages in any other vehicle I've ever owned or driven long enough to fill up.
  15. Feb 25, 2018 at 2:31 PM
    #35
    flyboy069
    flyboy069 New Member
    George
    2005 Tacoma Pre-Runner 4 Door
    Lift Kit
    With every auto I've had, when it filled full takes several miles before it moves down. That's because there is a float in the tank that stops when it hits the top of the tank and you then fill past the float. Then on the reverse it can so the same. IOW; gauges are approximate. Therefore, keep track of your mileage to know when your low instead of the gauge.
  16. Feb 25, 2018 at 2:36 PM
    #36
    flyboy069
    George
    Lift Kit
    I have a problem with my gauge being at an eighth of a tank and I ran out of gas. Believe it or not I coasted to right in front of my house. However, is that a symptom of a problem with the sensor, aka float, or the gauge? Anyone know?
  17. Feb 25, 2018 at 3:51 PM
    #37
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Reserve fuel for dummies (not you ) that keep driving there truck till the light comes on,a saftey measure if you ask me.
  18. Feb 25, 2018 at 8:53 PM
    #38
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Definitely a problem and not right... sounds like a good dealership visit question to me.
  19. Feb 25, 2018 at 8:59 PM
    #39
    jca
    jca Well-Known Member
    Engineers design the fuel gauge like this on purpose. People love seeing the marker at full for as long as possible, so they've been instructed to calibrate the gauge as such.
