Anyone else’s headlights “peeling”?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Aug 27, 2018.
  1. Aug 27, 2018 at 7:29 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    was washing my truck this weekend and noticed the protective film is peeling off of one of my headlights.
    Tacoma_SR5Pro likes this.
  2. Aug 27, 2018 at 7:35 PM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Is it the actual UV hardcoat?
    Scary to hear and the 2016s are about the age where the headlights turn yellow if not regularly waxed/coated.
    These headlights have alot of plastic exposed to the sky. I dont see them aging well, Nor do I get why manufacturerd make bulging lenses with so much plastic exposed to the sky.
    I recomend Optilens. Apply 3 coats 2 times a year and you can triple the life of the original UV coat on the lens. I did this on my 2002 lexus and never really had any fading or yellowing. And that car was exposed to the sun alot here in south florida.
  3. Aug 27, 2018 at 7:38 PM
    Rujack
    Good tip. I’m going to take it to the dealer next week to have it documented. Should be covered, I’m thinking.
    RIDER34 likes this.
  4. Aug 27, 2018 at 7:40 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    No headlights don't Pee Silly man
    NickleCityTaco likes this.
  5. Aug 27, 2018 at 7:53 PM
    ICrazyChrisI
    ICrazyChrisI Well-Known Member
    San Diego, CA
    2016 TRD Off Road DCSB
    BT17 likes this.
  6. Aug 27, 2018 at 8:12 PM
    Rujack
    Nope, I’ve waxed them a few times but not regularly.
    This time I did apply Wolfgang sealant, which is when I discovered the peeling area.
  7. Aug 27, 2018 at 8:15 PM
    Rujack
    Thanks,
    I’ll look into that.
  8. Aug 27, 2018 at 8:20 PM
    Rujack
    Optilens is expensive stuff!
    Burro09 likes this.
  9. Aug 27, 2018 at 8:35 PM
    Burro09
    Miami, FL
    Yup pretty pricey. You can treat the headlights multiple times with it though. A little goes a long way. I had spectacular results on my IS300. Each headlight is about 800 bucks from the dealer...
    :spending: I think the money is well spent if the truck is outside all day. The sun here in south florida is brutal.
  10. Aug 27, 2018 at 8:37 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    I put 3m on my lights. Wonder if it helps
    kgilly likes this.
  11. Aug 27, 2018 at 8:37 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I used a clear protective wrap on my headlights, keep them looking new and if they fade I just replace the film and the headlights look good as new
  12. Aug 27, 2018 at 8:39 PM
    Rujack
    If it works, it’s definitely money well spent.
    Does it replace the UV coating that has worn away? Or is it more of a preventive measure?
  13. Aug 27, 2018 at 8:40 PM
    Rujack
    How on earth did you get it to fit well?
  14. Aug 27, 2018 at 9:08 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    I have a second gen:anonymous:
    RIDER34 and Rujack[QUOTED][OP] like this.
  15. Aug 27, 2018 at 9:25 PM
    Burro09
    Miami, FL
    To me, its a preventative measure to keep the original coating intact. You can also use it on restored uncoated headlights. If you get deeper into headlight restoration, you will find more expensive and probably superior UV cured OEM style coatings normally applied by professionals.
  16. Aug 27, 2018 at 9:58 PM
    madmanxing
    madmanxing Well-Known Member
    2017 Cement Tacoma Trd Pro
  17. Aug 27, 2018 at 11:19 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    wow.....chemical guys pretty expensive........1 gal, $349......and the wax, $1400....i would just replace the headlight
    happy_trails likes this.
  18. Aug 27, 2018 at 11:26 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Or you could spend like $60 to have them covered in PPF and never worry about fading again.
  19. Aug 28, 2018 at 12:15 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Just keep them clear (don’t wait until they are yellow) and take them to a body shop and have them cleared with auto clear when they start to fade. I had to do it on my FRS. It was $80 and the clear will last as long as your paint will if taken care of. Took a pair of slighted hazed lights and they looked brand new again until I sold it
    JoeManji and db2 like this.
  20. Aug 28, 2018 at 1:37 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It’s not good to wax your headlights, actually progresses the aging and yellowness from what I’ve always been told. I used to restore headlights. We used to 5 stage sand them then spray them with a clear and hit them with a Uv light for a while. Could make the yellowest of headlights look almost brand new.
    suaveflooder likes this.
