Anyone ever had to check their flexplate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grenade187, Mar 17, 2014.
  1. Mar 17, 2014 at 6:52 PM
    Grenade187
    Grenade187 [OP] Well-Known Member
    Eric
    Vancouver, BC
    07 TRD Sport 4.0L V6 SR5 DCLB
    Camburg +3.5 Long Travel kit, Fox 2.5" Body 8" Coilovers with Remote Res, Radflo Air Bumps, Total Chaos coil bucket gussets, cam tab gussets and spindle gussets; All-Pro front bumper and IFS skid; All-Pro standard leaf pack; Ubolt flip; shackle flip; Timbren bumps; Radflo 2.5" body extended travel rear shocks, remote res with comp adjust; Magnaflow cat-back; Doug Thorley long tube headers, and off-road Y-pipe; URD TCAI
    Hey there, exactly what the title says. I think I'm having flexplate symptoms, just wondering if anyone's ever checked/replaced theirs. Some vehicles have easy-access panels to check torque, but some vehicles you can't get to it unless you pull the trans.
    Symptoms I'm having are very slight shudder in neutral, and there's a definite shudder when I turn off the engine. Also, I think I can hear it, especially right when I hit the accelerator as I'm passing 1500RPM.. but hard to say, it could just be tacoma tick.
  2. Mar 17, 2014 at 7:59 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Haven't really heard of flexplate issues with the tacoma's. Now my old chevy k5 is a different story. You could here the torque converter bolts whenever they got loose. One day i shined a flashlight up there and saw a crack about 3 inches long on the flexplate. But that was an old 700r4 transmission, it was to be expected!
    I've had 3 tacomas now, 1 being auto with over 130k on it when i sold it. No flexplate issues/symptoms. Does it have any rattle or noise? or mimic an exhaust leak?
  3. Mar 17, 2014 at 8:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is a small access cover where you can get to the bolts to attach the Torque Converter to the flex plate.
    I have never seen a vehicle that you have to pull the transmission to get at the flex plate bolts. How would that even work?
  4. Mar 17, 2014 at 8:18 PM
    reece13
    North Carolina
    good question.
  5. Mar 17, 2014 at 10:24 PM
    Grenade187
    Eric
    Vancouver, BC
    yeah, I misunderstood something I read about flexplate issues. I have limited experience with automatics. Thanks for the help. There is a bit of rattling, but I'm fairly sure it's an exhaust leak. I'm replacing stock manifolds with stainless magnaflow ones as soon as my DT ypipe shows up. If it still makes noise I'll check the flexplate.
  6. Mar 17, 2014 at 10:31 PM
    Grenade187
    Eric
    Vancouver, BC
    also worth mentioning my truck is getting up around the 130k mile mark. I just bought it last July with about 120k on it.
  7. Mar 18, 2014 at 7:32 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If the flex plate is cracked it will rattle like crazy and change sounds in and out of gear and switching from forward to reverse.
  8. Aug 4, 2017 at 9:18 AM
    mstgeer
    mstgeer Well-Known Member
    My son's (new to him) 08 AC, auto, 4x4 with 102k has these exact symptoms. Anyone know of a diy for changing the flex plate?
  9. Aug 14, 2017 at 12:26 PM
    mstgeer
    Determined a DIY for this was going to be too difficult to perform my garage, without a lift. Sent it to the local 4x4 shop. They just called, confirmed flex plate cracked in 3 places. $700 repair for a $25 used part :annoyed:. Had them replace the rear main seal while they were in there.
  10. Aug 14, 2017 at 1:03 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Tranny and torque converter will have to be removed to access the flex plate.
