Anyone ever heard of this happinin?
Discussion in '1st Gen. Tacomas (1995-2004)' started by KdF, Oct 22, 2014.
  1. Oct 22, 2014 at 12:32 PM
    KdF
    KdF [OP] Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    #1 timing belt pulley snapped right off.
  2. Oct 22, 2014 at 2:11 PM
    BamaToy1997
    Bill
    Navarre, FL
    Can't see where it snapped. Everything initially looks normal except for a lot of belt wear.
  3. Oct 22, 2014 at 2:42 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    is there a crack in the pulley on the left side? I think I see something that looks like it might be a crack but everything else looks normal so what are you trying to show in the picture? when you said it snapped right off we expect to see something missing from the picture lol.
  4. Oct 22, 2014 at 2:53 PM
    Karlow
    Karlow Active Member
    Karl
    So CAL
    Box Stock 03 PreRunner
    none
    Somebody did not change their belt ever 100K?:confused:
  5. Oct 22, 2014 at 2:56 PM
    KdF
    East-ByGod-TEXAS!
    Well if you look where the belt is twisted out on the left, the lower Idler Pulley broke off it's metal and is laying sideways. the thing sitting right behind the twisted belt in the Pic. There is metal spinnin around freely where it broke off the holding bolt from the Pics I've seen in the parts manual. I was lucky I heard some kinda rattlin while I was fixin to go on a 70 mile round trip to BBQ in Lockhart. Thought it was the AC , but I started putting my hand around and the massive rattle was behind the Timing Belt cover, and that is a brand new belt only 4 months old. Thanks Stealership, I'll do it myself from now on.
  6. Oct 22, 2014 at 3:38 PM
    keakar
    karl
    louisiana
    maybe a picture with a better angle, im just not seeing it, though I understand the area you are talking about
  7. Oct 22, 2014 at 3:44 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Dang man. As much as it hurts to take it back to that dealer again I would say that is where you are headed to have them fix it. Not to be to picky but you have a belt not a chain like the title. I know you fixed it later on in your last post.
  8. Oct 22, 2014 at 3:46 PM
    KdF
    East-ByGod-TEXAS!
    (FIXED THE POST!)
    Not fixed yet, got to get the parts, and waitin on a new Radiator.
  9. Oct 22, 2014 at 4:53 PM
    KdF
    East-ByGod-TEXAS!
    The top idler pully is good, the bottom idler pully is laying on it's side.
  10. Oct 22, 2014 at 6:34 PM
    keakar
    karl
    louisiana
    ahh ok, still not easy to see but i do see it
    damn the bad luck, i bet the bearings cam apart in it and it tore itself off the shaft
    first picture in post #10, that shiny thing under the belt is the edge of the pulley and the rest is under it and that's what is holding the belt twisted in that position, the belt is on top of most of it and you can just see the open bearing end of it sticking out the left side of the belt
  11. Oct 22, 2014 at 7:02 PM
    BamaToy1997
    Bill
    Navarre, FL
    I see it now. I will say this though, you cry out "Thanks stealership", but we don't know the whole story. Do you know for a FACT that the dealership made a mistake? Maybe the part that was installed had a fracture that was missed since it was a new part and it broke? Not saying that the dealership DIDN'T make a mistake, because we don't know the whole story, but just saying, before you go bashing a dealership, can you prove that it was their fault?
    I will say that I do not see anything wrong with the center, top idler pulley though.
  12. Oct 22, 2014 at 7:32 PM
    keakar
    karl
    louisiana
    yep probably just a freak defective part is all
  13. Oct 23, 2014 at 5:12 AM
    KdF
    East-ByGod-TEXAS!
    I do not believe the Stealership did anything to the lower Idler pulley. it's most likely original. I circled the top idler to show the difference. I'm just lucky as hell that with my bad hearing I could hear the rattle before it let go on a lonely stretch of Hwy. But I also believe that after 2 major screw-ups with those people that I was pissed that this would happen only after 4 months of a complete timing belt service (water pump, tensioner and seals) that maybe they should have caught it. I was just pissed that it's sitting until I get the parts and try my hand at it. I will need the lower Idler, a new belt and a gasket for the lower cover. Just another thing I really did not need at this time having never done this before. I'll get hot when the radiator shows up, as I'll have to remove that also to get at it. The Beast also has 220 K on it now.
  14. Oct 23, 2014 at 5:59 AM
    BamaToy1997
    Bill
    Navarre, FL
    OK. Well the pulley that is broken there IS the tensioner pulley. I won't say either way if it was a defective part, or bad workmanship until I could see it with the lower cover off. Either the new tensioner was defective, or the installer did not tighten the nut and it fell off. One of the two. So until we see more, it would be hard to tell.
  15. Oct 23, 2014 at 6:04 AM
    KdF
    East-ByGod-TEXAS!
    So you are suggesting that it IS something the Dealership should fix for free????? If that IS the tensioner that they replaced, it should be? If so I'll make them tow it in and same some Ducketts!
  16. Oct 23, 2014 at 6:27 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It might be worth a tow job to the dealership.
  17. Oct 23, 2014 at 6:41 AM
    BamaToy1997
    Bill
    Navarre, FL
    I would say that if they did a timing belt, and the belt came off with a broke loose pulley that THEY installed, then yes, it should be fixed for free from them. I will say that they MAY ask you to pay for the tow, and then reimburse you if they cause of the failure is them. And that is just normal business sense.
  18. Oct 23, 2014 at 6:43 AM
    KdF
    East-ByGod-TEXAS!
    Thank you, callin them Now!
    Daymn, this is a good site.
  19. Oct 23, 2014 at 3:59 PM
    BamaToy1997
    Bill
    Navarre, FL
    Make sure to update this as things progress so that we can find out what happened, and the end result.
  20. Oct 24, 2014 at 10:30 AM
    KdF
    East-ByGod-TEXAS!
    Update:
    The Service Mgr. got involved from the Git-Go. He gave me the number for the Towing Co. , And they picked it up around Noon Yesterday. Called them this am and it was ready. They replaced the Timing Belt, tensioner pulley, Gasket and Anti-freeze. Total Cost to me....ZERO. The only thing is the wire attachment clip to the Upper timing cover was eaten off by the belt, and they are looking for a replacement. Sounds good to me. He also told me that Toyota guarantees those parts for 12 months, so it's on Toyota's dime. Thanks Bill, would never known to let them have it back.
