Anyone ever notched the side of their frame for bigger tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForestRunnerFrank99, Dec 18, 2021.
  1. Dec 20, 2021 at 8:15 PM
    #41
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I see no issue with notching it there. Just plate with 3/16 at minimum and watch for cracks. Probably be stronger than the existing frame. I cut my entire front frame off and moved it and made a new frame rail section with no issues
    if you plan to sas, I would plan on cutting and remaking the frame as well. I’ve done both now and the benefits of cutting it off out weigh the grinding. More uptravel. Stronger. Less welding. Less grinding etc.
  2. Dec 22, 2021 at 10:27 AM
    #42
    ForestRunnerFrank99
    ForestRunnerFrank99 [OP] Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    This is exactly why. And I have a cold air filter so it was just out in the open. Whats funny is I knew it would be an issue so I was going like 5mph through the puddle and I STILL got water in the intake. I thought it was hydro locked so I pulled all the spark plugs and when I tried to crank it, it still wouldn't turn. Upon further inspection I noticed a chunk of my block on the starter. And that's when I knew I f@#$%÷ up
    eon_blue[QUOTED] likes this.
  3. Dec 22, 2021 at 10:29 AM
    #43
    ForestRunnerFrank99
    Josh
    So I have this exact pre cover. It didn't do anything. I think they are better at repelling like rain drops but not splashes. And it makes sense cause if it was 100% waterproof it would not be able to suck air through it.
  4. Dec 22, 2021 at 10:32 AM
    #44
    ForestRunnerFrank99
    Josh
    Yeah my buddy used to work at EST Fabrication and now works at Nguyen Works. He knows a thing or 2 about frame plating and welding, even he is against notching it... he doesn't think we'd be able to cut enough and make it strong enough to fit the tire.
    RoaminRoman likes this.
  5. Dec 22, 2021 at 10:35 AM
    #45
    ForestRunnerFrank99
    Josh
    So I think after some thought and reading this thread I won't notch it. SAS is still a bit away but it'll make everything much easier when that time comes because I won't have to deal with a modified frame. If I was planning on IFS forever I would go for it, but again, since I have the axles sitting in my garage, notching it just doesn't seem like a good idea at the moment. I'll just deal with the rubbing until then.
  6. Dec 22, 2021 at 10:39 AM
    #46
    ForestRunnerFrank99
    Josh
    This is why I asked in the 1st place. My motor was already out.
  7. Dec 22, 2021 at 11:16 AM
    #47
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I would reinforce your engine perches while your engine is out. If you were staying ifs a long travel kit would help.
  8. Dec 22, 2021 at 12:36 PM
    #48
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Good move, you'll be happy when you do the SAS to not have the notch if you decide to chop the frame and build a new one. It's a PITA to get in there around brake lines and fuel lines on the driver side.
    malburg114 likes this.
