Anyone ever notice this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChrisGralnic, Mar 18, 2013.
  1. Mar 18, 2013 at 1:23 AM
    ChrisGralnic
    ChrisGralnic [OP] Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    With a 4cl tacoma, does your fuel gauge go down noticeably faster in some areas than in others? For my truck personally, my gauge will start dropping faster a little above the halfway mark then once I hit a little over a quarter tank it goes back to dropping really slow. One time I drove to school and back ( maybe 5 miles to and fro) at a little under half a tank and it dropped to just a little over a quarter tank. But then the quarter tank will last forever! Maybe my gauge is funny. Is any one elses like this?
  2. Mar 18, 2013 at 1:32 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Mine seems opposite. Seems to drop pretty quick once I hit 1/4 tank.
    Your gauge probably seem to go down slowly once you hit 1/4 tank because you realize you are running out of gas, and unwittingly start driving more conservatively :D
  3. Mar 18, 2013 at 1:39 AM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    for me, gas goes faster between 3/4 and down to a 1/4 tank. its the 1st 1/4 tank and last 1/4 tank were i get the most mpg.
  4. Mar 18, 2013 at 1:55 AM
    ChrisGralnic
    Southern cali
    me too. Sometimes it depends on the gas i use too. Chevron seems to take me about 40 miles longer per tank than discount gas. But its expensive and i use the discount stuff anyway lol.
  5. Mar 18, 2013 at 1:56 AM
    ChrisGralnic
    Southern cali
    One time i was on fumes and only had enough cash on me to get 1 gallon. I used valero and went like 10 miles before i was on fumes again. never used Valero since. Our town Valero turned into a mobile station so i use that.
  6. Mar 18, 2013 at 2:00 AM
    ChrisGralnic
    Southern cali
    Wait a sec, maybe cause its more expensive i conserve more by driving slow... hmm. Hahaha.
  7. Mar 18, 2013 at 3:39 AM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
  8. Mar 18, 2013 at 4:23 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Not to come across as a smart ass ... :cool: ... it is a gas gauge ... it gives you an idea of the amount of gas in you tank.
    As far as some saying they get better mileage out of 1st half of their tank vs. the 2nd half, I believe that can't be possible. As small of a weight loss there is as the gas is burnt, your truck is lighter than it is when you top it off ... hence, better gas mileage as long as everything else stays consistent.
    It seems that the most of us do share a constant ... when the light comes on we have about 3.5 gallons in the tank. 17.5 gallons is about the average to top it off.
    Stepping back from the :crapstorm:
  9. Mar 18, 2013 at 11:24 AM
    ChrisGralnic
    Southern cali
    Mine took 18 and a half once and I overfilled it. Stayed at the full line for 80 miles. Didn't move at all... hope I didn't damage anything. Probably not.
  10. Mar 18, 2013 at 11:28 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Mine drops normally till half... Then tanks. There are also times it won't move for days, then in the course of 10 miles it drops a very very noticeable amount
  11. Mar 18, 2013 at 11:31 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Well if your truck took 18.5 then you only had about 2.8ish gallons (arond there) left on the tank...I dont see you damaging anything :notsure:
  12. Mar 18, 2013 at 11:38 AM
    miacevedo
    miacevedo Well-Known Member
    SoCal
    SuperWhite 4X4
    All Pro Hybrid front bumper. All Pro rock sliders. Warn Winch. Icon 2.5 Remote Resi Coilovers & Rear Icon 2.0 Extended Remote Resi's. AP Standard leafs. Rear SuperBumps. OEM bed mat and All Weather floor mats. Pelfreybilt IFS Skid. Method NV wheels on 285/75/16 Toyo Open Country AT2.
    I think my gauge might be a little off... mine can go 100 miles and still be at "Full". It goes down much faster once I hit 3/4.
  13. Mar 18, 2013 at 11:49 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    I definitely notice this, I can get about 80 miles on a full tank until the needle starts to move. Usually it moves down just above 3/4's of a tank. It will stay that way until I hit 120 miles, then the needle will move just below the 3/4 line...
  14. Mar 18, 2013 at 12:30 PM
    ChrisGralnic
    Southern cali
    I am wild about my truck. I notice every little thing. Its a compulsion. Also being on the road to be an technician doesn't help. I like trucks, I like to look at them, work on them, talk about them, and learn about them. I have 3 posts. Geeze that's a lot. I'm just crazy about tacomas and anything else with a toyota symbol on it. Call me a nut, I'll sport it. I'm going to be an intern for a toyota dealership service and repair shop in october. Just soaking up info! From here, and anywhere else.
  15. Mar 18, 2013 at 1:43 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    once the niddle starts moving, meaning it burnt whatever you top it off with…. it should move at the same rate if you were to drive tru the entire tank at the same driving conditions…
    ***Im trying to pick on you or anything…. but the tittle of this thread its just not right!!! mention the topic or objective of the thread…. its like a trap…lol
  16. Mar 18, 2013 at 1:45 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Same
  17. Mar 18, 2013 at 2:10 PM
    ChrisGralnic
    Southern cali
    Lol! Gotcha! I'll post an objective next time!
  18. Mar 18, 2013 at 2:16 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    lol...but back to topic….
    i think its an illusion… the niddle doesnt move whle its above the top line but it starts counting below the last empty line….
    ***just some logic IMO
  19. Mar 18, 2013 at 4:03 PM
    ChrisGralnic
    Southern cali
    I respectively disagree. I have watched the needle move much faster in some spots than in others. And its always in the same spots. I don't think its a problem. Just a quirk. I still get my mpg regardless. (375-450) per tank,
  20. Mar 18, 2013 at 4:24 PM
    biglinc
    biglinc Well-Known Member
    linc
    maine
    07 tacoma
    I was noticing that mine stays full or a little over full and as I am driving it drops to 3/4's its never 7/8 or there abouts, I thought that was odd it doesnt seem to afect milage, it's either full+or 3/4.
