Anyone ever put bench seats into their first gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Emlev, Mar 31, 2024.
  1. Mar 31, 2024 at 8:04 PM
    Emlev
    Emlev [OP] New Member
    2002 Silver Tacoma TRD Manual
    I have an '02 and I'm curious if it's a possibility. Would love bench seats.
  2. Mar 31, 2024 at 8:52 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    You can pretty easily swap between Tacoma buckets and benches. Most people go the other way, swapping out their bench for buckets + console.
  3. Mar 31, 2024 at 8:53 PM
    Emlev
    I'm in an '02 that has bucket seats. You know where I can find compatible bench seats? Maybe a pick and pull would have a Tacoma with bench seats?
  4. Mar 31, 2024 at 8:54 PM
    time623
    James
    AZ
    That would probably be the cheapest route, or finding someone local who wants the opposite swap. Seems like tacomas are pretty rare to find in most pick n pulls
  5. Mar 31, 2024 at 8:57 PM
    time623
    James
    AZ
    I see part outs on my Facebook marketplace fairly regularly as well. Seems like seats are one of the first things to go though
    Emlev[QUOTED][OP] likes this.
  6. Mar 31, 2024 at 8:57 PM
    Emlev
    When did Toyota stop putting bench seats in? I'm super new to the Toyota 4x4 community, so I didn't even know Tacomas had bench seats at one point
  7. Mar 31, 2024 at 9:06 PM
    time623
    James
    AZ
    I’m not sure, they probably stopped entirely when they stopped offering a single cab. In extended and double cabs I don’t believe a true bench was an option, but many such as mine have a “60/40 bench” like this
    This would be a drop in replacement as far as I know
    These are what I thought you were talking about, but I believe single cabs had a true solid bench option
  8. Mar 31, 2024 at 9:09 PM
    time623
    James
    AZ
    This is the single/regular cab bench seat.
    Never seen anyone put one of these in an ext or dbl cab so not sure if you can
    grizzlypath likes this.
  9. Mar 31, 2024 at 9:39 PM
    Emlev
    Thanks for all your help, man, I appreciate it. Do you think a '95 T100's seats would fit? Someone has one up and I wanna see if he's willing to part it out because it needs a new engine.
  10. Apr 1, 2024 at 5:35 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    you also need to account for the center console you have. the solid bench does not work with it. would need to remove the part with the cup holders entirely.
    the T100's would be wider in general so the mounting points may not line up.
  11. Apr 1, 2024 at 8:13 AM
    time623
    James
    AZ
    'Fit' could mean two different things depending on your tools and skills. I've never done it, but I don't think mocking up some seat mount adapters is very complicated, if you are able to weld and fabricate. If you need it to just be a drop in replacement, I highly doubt anything outside of a 1st gen Tacoma (and maybe 3rd gen 4runner I cant remember if they use the same mounting locations) will fit.
    So if you can weld and fab some mount adapters, then any bench you find that physically fits inside the cab could work.
    I would also be worried that the T100 seats are too wide to even fit in the cab, since the T100 is a generally larger truck.
    dannybubbles likes this.
  12. May 23, 2024 at 4:38 PM
    thebiggestbongo
    thebiggestbongo Active Member
    North Georgia
    2004 Tacoma Prerunner DCSB
    I had the same question. Have you made any progress on this?
  13. May 24, 2024 at 12:10 PM
    dannybubbles
    dannybubbles yada yada
    Daniel
    Chico, CA
    01 3.4 auto 4x
    You can absolutely put a bench seat in your extra cab, are you looking for a 'true' bench seat or would you be ok with the 60/40 that came in a lot of models?
    either way
    You should be able to find a straight across trade, or make money in the process, since you have buckets and presumably a center console currently. They are the more desirable of the two, as previously mentioned.
  14. May 24, 2024 at 12:15 PM
    dannybubbles
    Daniel
    Chico, CA
    01 3.4 auto 4x
    fwiw, the bench seats have a silly low headrest thats not adjustable. The 60/40 will be easier to find, have adjustable headrests, be slightly more comfortable, and not force you and a passenger to compromise on legroom.
    Not sure how far forward the bench seats fold, 'backseat' access may also suffer
    cruxofthebisquit likes this.
  15. May 24, 2024 at 4:05 PM
    stodgy
    stodgy New Member
    2003 4cyl 2WD
    Emlev,
    Where are you located?
    I am looking to replace my bench with seats that can individually be adjusted. My 6'1" teenager sits like a pretzel when my 5'4" wife drives him to school.
