Anyone ever snap a wheel stud?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04trd, Dec 6, 2013.
  1. Dec 6, 2013 at 4:57 PM
    04trd
    04trd [OP] Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    So the other day my brakes started to squeal while I hit the brakes so I brought it home to check it out. Took the tire off to realize I needed brakes, no big deal. So as I'm putting my factory rims on I put all the lugs on and started to tighten them. They all got snugged down with an impact like I always do. ( I have a winter set and a summer set of tires.) they all got snug so I let the truck down to torque the lugs to 115 foot lbs. before I even got them remotely tight one snapped!? I've never snapped a lug before. So now today I'm doing brakes on my truck got everything done and the same damn thing happened!! I snapped another lug. I can't believe it I snapped two of them in two different days. Replaced one with factory ones from Toyota. I know how to change a tire I've done plenty as I worked as a mechanic for a construction company. Any reason this could be happening?
  2. Dec 6, 2013 at 4:58 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I believe 83ft-lbs is the torque spec. That may be the reason they're snapping. ;)
  3. Dec 6, 2013 at 5:06 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Hmmm can anyone else verify this? But it's weird it wasn't like it was over tight than snapped. I was just getting started to torque them. So if it was like I was cranking on it than snapped it would make since.
  4. Dec 6, 2013 at 5:07 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    And I've had them at 115 for about 3 years. I change my tires twice a year and rotate them every 5k miles. So it just seems odd
  5. Dec 6, 2013 at 5:08 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    83 lb ft of torque is the spec.
    Bolts get old and break.
    They age faster when overtorqued.
  6. Dec 6, 2013 at 5:09 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Toyota studs are the only ones I've snapped on 2 models. Never snapped any other manufacturer studs and I've had many cars.
  7. Dec 6, 2013 at 5:10 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Shit. Guess they are way to tight. That explains everything!
  8. Dec 6, 2013 at 5:13 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Most likely whoever put them on before you over torqued them as well.
  9. Dec 6, 2013 at 5:15 PM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    did the same exact thing on my 2003. no clue why though
  10. Dec 6, 2013 at 5:16 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Since I've owned the truck since 60k it's all on me. That's what I get for listening to the dealer. Called about torque specs the first time I changed my rims and tires. So now that I realized they are over tight do I change them all or change them as they snap
  11. Dec 6, 2013 at 5:17 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    :facepalm: You overtorqued the wheel studs by almost 40%.
    Replace them all. Would rather not see a wheel fall off when you are going fast around a corner.
  12. Dec 6, 2013 at 5:22 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Took three years To snap. Guess I'll get them replaced tomorrow
  13. Dec 6, 2013 at 5:38 PM
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Yeah, fatigue over time. I have five exhaust studs Time-Sert'ed in my MR2 because of repeated overtorquing, stripped the (aluminum) threads in the head. They won't strip now (and I torque them properly now, heh). :thumbsup:
  14. Dec 6, 2013 at 5:44 PM
    Bgt51ridescr
    Bgt51ridescr Active Member
    Brian
    CA
    '16 Tacoma TRD Offroad 4x4 longbed
    bed cover, method wheels, BFG all terrains, blacked out exterior chrome
    My truck is actually missing one. I need to replace it, but yup over torqued = snapped
  15. Dec 6, 2013 at 5:46 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Lol lesson learned. Never trust a stealership. Always trust tw
  16. Dec 6, 2013 at 5:53 PM
    KenLyns
    Belly of the Beast
    ^We also offer medical advice, career help and relationship counselling. :thumbsup:
  17. Dec 6, 2013 at 5:57 PM
    tomtom
    The Desert SW
    2012 FJ
  18. Dec 6, 2013 at 5:59 PM
    KenLyns
    Belly of the Beast
    Good thing OP doesn't drive a Subaru - wheel studs are torqued to just 72 ft-lbs.
  19. Dec 6, 2013 at 6:13 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
  20. Dec 6, 2013 at 6:57 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Probly 99% of dealerships use impact guns with torque sticks improperly, so everyone's lug nuts are most likely getting over tightened.. Even if a little bit. I'd replace all the studs just to be safe!
