Anyone ever swap out the 4banger in 2nd gens?
Discussion in 'Street Trucks' started by Mr.Schertz, Feb 23, 2013.
  1. Feb 23, 2013 at 9:42 PM
    Mr.Schertz
    Mr.Schertz [OP] Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    I have a 2008 base model single cab 5 lug four banger. Ive toyed with the idea of pulling out the 4banger and dropping in a 2nd ten 6cyl like the ones in the runner. The single cabs look so much better than the extended cab x runner. It would be cool to build this up.
  2. Feb 23, 2013 at 9:44 PM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    it would be cool but I haven't heard of anyone doing it yet.
  3. Feb 23, 2013 at 9:46 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    Engine mount locations are most likely different. and you may have to do new trans as well?? idk if it’s the same or not.
  4. Feb 23, 2013 at 9:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    shouldn't be too bad, just need to fab some custom engine mounts and a trans cross member. Then figure out the wiring.
  5. Feb 23, 2013 at 9:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    X-Runner is a 5-lug, so the frame is going to be identical.
    Only difference would be the same as the differences between the Access Cab 5 lug 2.7 vs 4.0
    Would need a new engine and trans, and the electronics will be a PITA, but I'm sure it'll be possible.
  6. Feb 23, 2013 at 9:57 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    hmm didn't know that. Sorry for the misinformation OP.
  7. Feb 23, 2013 at 10:18 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    your best bet would be to get a totaled truck from an insurance auction. This provides you with the engine, transmission, and most importantly and hardest part, the wiring.
  8. Feb 23, 2013 at 10:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Agreed.
    I believe the XRunner has an "X" brace in the frame, someone correct me if I am wrong, but I am wondering if there are any other differences that may come into play.
    I have seen a 4.0 swapped into a first gen Tacoma. I didn't look very close at the details, but I know the frame mounts were custom built.
    I would guess that custom frame mounts would be needed, and the rest would just be having the needed parts available. A wrecked truck would be best for donor parts.
  9. Feb 23, 2013 at 11:14 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The "X-brace" is at the rear, runs across the rear bumper at the hitch area and sweeps forward around the spare to the area of the shock mounts.
    It stiffens the rear of the frame.
    Hellwig swaybar is more noticeable ;)
