Anyone ever upgrade to an SSD?
Discussion in 'Technology' started by bongwhisperer, Feb 21, 2016.
  1. Feb 22, 2016 at 2:31 PM
    bongwhisperer
    bongwhisperer [OP] Well-Known Member
    horn that plays "la cuka racha,"
    I'm still running 7, I've messed around at Best Buy with 10 on the computers, but I'm not a big fan. Maybe I need to mess around with it more?
  2. Feb 22, 2016 at 2:35 PM
    bongwhisperer
    I might do an e85 conversion with meth injection.
    SalmonTaco[QUOTED] likes this.
  3. Feb 22, 2016 at 2:36 PM
    Aw9d
    Aw9d That one guy
    :rofl:
    I'm going to be using that line for some of the people's laptops I work on.
    bongwhisperer[OP] likes this.
  4. Feb 22, 2016 at 2:49 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    +3 on Samsung 840-850 EVO SSD drive. They run cooler, use less power and allow much more responsive boot up and application launch times.
    Their downside however and this is where HDD's shine is their overall storage capability over SSD's so if space is a requirement to you for the cheap HDD is the way to go. Also if you run Photoshop and perform many benchmark tests on hard drives you will find that HDD's often beat out SSD's in conversion rates when it comes to converting movies, photos, and large files. (So I remember reading back in the day in 2012) Things may have drastically changed now so who knows, but regardless, I have switched to SSD already. I also dropped the drive bare once recently too and it's still alive and kicking because there is nothing to go bad basically.
    Be aware though that you should perform perodic backups because they can fail without warning unlike HDD's.
    If you aren't planning on using your laptop for intensive sort of stuff and more for pleasure and messing around the SSD drive is a great upgrade for it to really energize it.
  5. Feb 22, 2016 at 2:51 PM
    Aw9d
    Aw9d That one guy
    That's why you get an SDD for your OS/software and an HDD for storing music/photos/documents.
  6. Feb 22, 2016 at 4:10 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Win 10's better than 8.1 but takes some getting used to. I wouldn't say the interface is better than 7, but it does seem to boot more quickly and it's the way of the future. Don't wait too long to upgrade from 7 as "free" part goes away this summer.
    Or better yet, an online NAS. But I digress.
  7. Feb 22, 2016 at 5:14 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Fixed it for you...
  8. Feb 22, 2016 at 7:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Typically the HDD gives you an indicator that it is going to fail before it does. Usually clicking since it is a electro mechanical device. Unlike SSD which is all eletronic circuitry soldered onto a PCB.
  9. Feb 24, 2016 at 4:12 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    If you're going to continue to run 7, make sure you disable auto defrag. SSD drives do not require it and it will reduce the life of the drive due to limited read/write cycles.
  10. Feb 26, 2016 at 9:49 AM
    bongwhisperer
    Thank you
  11. Feb 26, 2016 at 5:33 PM
    vram74
    05 Prerunner SR5
    If you need good free cloning/imaging software, this is what I use:
    http://www.macrium.com/reflectfree.aspx
    Samsung or Crucial SSD's will probably include some drive cloning software though. I use the above to image my drive periodically. Damn good stuff for free!
    rmepilot and bongwhisperer[OP] like this.
  12. Feb 27, 2016 at 9:45 AM
    bongwhisperer
    Thank ypu
  13. Feb 27, 2016 at 10:01 AM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Hi OP. I'm not too sure about the e6400 but I'm figuring its not that much different. I have an e6440 that I just ordered a Samsung Evo 850 500gb msata. This will be installed as a second drive in the location msata slot right above (when laptop is opened and upside down) the wwan slot. I will be configuring it to be the boot drive and retain the oem HDD as either a backup or a data only drive.
    Just mentioning an possible option. I should receive and have the drive installed by the 3rd.
  14. Feb 28, 2016 at 3:22 PM
    bongwhisperer
    Let me know how it goes!
  15. Feb 28, 2016 at 3:28 PM
    #35
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Totally worth upgrading to ssd. Newegg has samsung evo 850 for $271. It was the single best upgrade to increase performance of my PC and my laptop.
    It's difficult to clone the drive over without a dedicated hard drive cloner which I got for $25 on Amazon. The software stuff that's available for free seem to be hit or miss reviews, while the dedicated hard drive cloner has worked 100% of the time in the past dozen or so clones I've done.
    I've run into issues that the laptop was too old to recognize an ssd, but the laptop has windows Xp on it and was from 2008. If you have a laptop that's less than 5 years old, go for the upgrade.
  16. Feb 28, 2016 at 3:29 PM
    #36
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    I will.
  17. Feb 29, 2016 at 9:17 PM
    #37
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Well the mSATA Evo 850 and Sabrent mSATA hard drive enclosure arrived today. After a 3 hour cloning of the drive using Samsung's Drive Mitigation software I can claim success! The Samsung software is a free download off Samsung's ssd website.
    I did run into some difficulties with the usb. A little research and I discovered that on my system there are power saving settings on the usb. I also went into the bios setup and unchecked the Enable USB 3.0. This was based on other information I found on the net. This worked and my usb worked constantly through the cloning.
    After the cloning, I installed the drive and selected it as the first drive to boot.
    I notice the boot speed, software, and page loading improvement right away. I ran the 'Windows Experience' test and it had gone from 5.9 to 6.7. Can't wait to see what happens when I double the RAM!
    As far as your e6400, the research I did does indicate that there is a WWAN slot next to the WLAN. If your are using the WWAN (cellular connection) you will have to find a different solution.
    You should open it up and verify that there is a vacant WWAN slot in your laptop prior to purchase.
    Good Luck!
  18. Mar 1, 2016 at 1:16 PM
    #38
    bongwhisperer
    what version of windows are you running?
  19. Mar 1, 2016 at 1:25 PM
    #39
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Absolutely worth it. About 3 years ago I upgraded a 2010 Macbook Pro with a samsung SSD and it was like night and day. Boots in about 10 seconds.
  20. Mar 1, 2016 at 1:43 PM
    #40
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    As an I.T. guy I have used this Laptop with an SSD max ram and an i7 processor. Its a pretty solid rig even for its age. Get an 850 EVO it has a 10 year warranty.
    Edit: May have been a newer E6500 model.
    Always keep backups!
