Anyone ever use TPMS straps from Discount Tire?
Discussion in 'Wheels & Tires' started by TacoTitan11, Nov 29, 2011.
  1. Nov 29, 2011 at 5:21 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    just wondering how reliable they are....
    hahahaha, you said strap!
  2. Nov 29, 2011 at 7:14 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Pretty straight forward a metal strap that goes around the center section of the hoop. It holds the tpms sensor internally so it can read PSI and use regular valve stems.
    They work.
    Why are you switching to them did you break a stem off or aftermarket wheels?
    I am not sure which brand discount uses but they stand behind their products
  3. Nov 30, 2011 at 3:44 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    anyone else have any experience?
  4. Dec 2, 2011 at 4:03 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
  5. Dec 2, 2011 at 7:25 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
  6. Dec 2, 2011 at 8:21 PM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    You have to make sure you let them know every time you have work done because if thy dismount the tire without knowing they will most likely break the sensor. I worked there for 6 years, the straps are fine.
  7. Dec 3, 2011 at 6:12 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I have had them for 40k miles with no issues
  8. Dec 3, 2011 at 6:21 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Is there a supply of aftermarket TPMS sensors that will work with those? I would like them for my winter tires.
    Howard
  9. Dec 3, 2011 at 6:40 AM
    Hayes
    Brandon
    Denver, CO
    They will work with any and all sensors.
  10. Dec 3, 2011 at 8:13 AM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    so my steel wheels should work perfectly fine with discount's bands? thanks
  11. Dec 3, 2011 at 10:08 AM
    Hayes
    Brandon
    Denver, CO
    Is there a reason you aren't just putting them in the valve holes?
  12. Dec 3, 2011 at 2:26 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    hayes,
    i dont think they will work will they? the angle degree is different on the steelies than the factory alloys, i have heardof some people using the factory ones but reversing them 180 degrees....does that really work?:D
  13. Dec 3, 2011 at 2:39 PM
    KPT
    09 Prerunner
    Discount will try that first, and then will use straps if the 180 doesn't work out. That's what they did for me.
  14. Dec 3, 2011 at 3:08 PM
    Hayes
    Brandon
    Denver, CO
    The angle is slightly different but if you use the rebuild kits for aluminum wheels they seal up and work fine. Done that many many times.
    if you tell them you want the steel bands they will do that first. The bands are more expensive than the rebuild kits and if you want to pay for them, they will gladly put them in for you.
    Op, do you have steel rims and stock sensors? I fail to understand why you need the bands.
  15. Dec 3, 2011 at 5:42 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    Hayes, I currently have stock steel wheels 16" with the original sensors in them.
  16. Dec 3, 2011 at 6:29 PM
    KPT
    09 Prerunner
    You are the first one I've ever heard who has said that using the 40 degree steel sensors works with the alloy wheels.
  17. Dec 3, 2011 at 6:43 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I've read where the steel 40's can be turned to fit alloys, but don't know anyone personally, that has done it.
    Maybe that's part of the kit fix.
  18. Dec 3, 2011 at 6:44 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    so the 40 degree sensors can work? or not?
  19. Dec 3, 2011 at 6:45 PM
    KPT
    09 Prerunner
    Yeah I have heard that they can be flipped 180, but that's not what hayes was suggesting above, the way I read it. Sounds like he was saying you just mount them normal and you can live with the mouthing angle difference of 20 degrees.
  20. Dec 3, 2011 at 6:46 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    KPT...would you suggest instead using the strap kits? seems like you have had good luck
