Anyone experience with Dash Cams?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluelyfe, Dec 3, 2014.
  1. Feb 1, 2015 at 3:57 PM
    #81
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I've got the Thinkware F550. Build quality is good. Daytime video is good. Night time is a tad dark. GPS function isn't all too useful as it doesn't show up in the actual video. Maybe a software/firmware update from Thinkware will change this, but as of now this camera is pretty much equal to the X300 I got my mom. Another note, you can see both bottom corners of my windshield.
    Use the videos for what you will, but I'd just use them and compare it to cheaper cameras.
    Daytime:
    https://www.youtube.com/watch?v=oLDVU7PJwj0
    Night (Skip to :50 and try and read the plate. I've since turned the brightness setting up a bit so I'll see if it improves):
    https://www.youtube.com/watch?v=0gZfTlBniIQ
  2. Feb 1, 2015 at 6:38 PM
    #82
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  3. Feb 1, 2015 at 7:34 PM
    #83
    andlours
    andlours Well-Known Member
    Andy
    Denver, CO
    09 TRD Offroad
    I looked at this one before I bought my Modius. I really liked the size of it, but after watching that video about 5 times, it just looked too cheap and plasticy. That's just my opinion though.
  4. Feb 10, 2015 at 4:04 PM
    #84
    xsteinbachx
    xsteinbachx Well-Known Member
    Victoria, BC
    2017 White TRD Sport DCLB 4x4
  5. Feb 11, 2015 at 3:53 AM
    #85
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    I'm interested in an easy hard wire too. My camera has a "Parking Mode" that the camera will start recording if someone walks in front of the lens or if the truck is bumped or jarred. It dose not operate because the power is shut off when the key is out. It also won't allow the battery to go below a certain voltage so as still be able to start. I don't want to hot tap in in a fuse that controls any important safety devises of the vehicle. When I say easy, I just didn't want to fish through the firewall and figure out how to pass into the motor fuse box without screwing up the water seal.
  6. Feb 11, 2015 at 4:24 AM
    #86
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
  7. Mar 19, 2015 at 9:16 AM
    #87
    xsteinbachx
    Victoria, BC
    Installed my dash cam and hard wired it too, Incredibly easy to do.
  8. Mar 19, 2015 at 1:34 PM
    #88
    Mr.Franko
    Mr.Franko Member #140853 Joined Oct. 22, 2014
    "send me location" K.Nurmagomedov
    '13 DCSB Baja TX
  9. Mar 19, 2015 at 1:40 PM
    #89
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  10. May 7, 2015 at 9:09 PM
    #90
    mbreid
    mbreid New Member
    Reider
    So. Cal
    2014 Tacoma TRD Sport
    Hey Mark! I just got the same dashcam and it looks like you did a great job with the installation. What installation kit did you go with so that the wiring was hidden? I want to be sure to get one that has enough cabling to route through the cab to the power source. I assumed you went with a hardwired setup directly to the fusebox?
  11. May 30, 2015 at 5:17 PM
    #91
    MikeinPA
    MikeinPA Member
    Southeast PA
    Pyrite SR5 DCLB
    Wonder why Gentex hasn't been able to squeeze a camera into its mirror and an alternative is a GoPro with windshield mount. At least you can use for other activities.
  12. Jun 2, 2015 at 10:37 AM
    #92
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    Hey - no I just got a super long USB cable and tucked it in the roof, then down the driver side door frame and ran it under the dash so that it can plug into a dual USB lighter adapter device I have. I was able to hide almost all of the wire so it's not too bad. I would like to hard wire it one day, but for now, this will have to do.
  13. Jul 15, 2015 at 11:57 AM
    #93
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Man, I wish someone would make a set with 2 tiny discrete cameras and an external DVR that you could place into the glove compartment/center armrest.
    This one seems pretty cool, though.
    https://dashcamtalk.com/sg9665gc/
  14. Jul 15, 2015 at 12:23 PM
    #94
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    i have had this G1W for a few months and its great.. havent captured anything cool or crazy yet but the picture quality is very good.
  15. Jul 15, 2015 at 12:27 PM
    #95
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  16. Jul 15, 2015 at 12:33 PM
    #96
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I have the G1WC by Spytec thru Amazon. So far it's a great camera. Cost $75 and picture quality is great. For the price I paid I couldn't be happier. I need to download a program so that I can cut out all of the uninteresting things in the videos. Captured a cop texting, countless stop signs being ran, a swerving drunk or they could have been texting but the neatest thing I've captured was a buck. He was about to cross the road but stopped short. As I slowed he started running down the shoulder of the road for maybe 50 yards then cut across in front of us. It was pretty cool. Date and time are correct. A few snap shots of him.....Apologies for the filthy windshield.
  17. Jul 15, 2015 at 1:55 PM
    #97
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    I found movie maker on my windows machine to be useful. Able to clip out frames before and after interesting video. Also haven't had much interesting happen in front of me.
  18. Jul 15, 2015 at 2:03 PM
    #98
    Toyotacrawler
    Cusseta/Opelika AL
    Cool I'll give it a try
