Anyone experiencing tire pressure loss with no puncture?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crosis, Jul 24, 2020.
  1. Jul 24, 2020 at 10:26 AM
    Crosis
    Crosis [OP] Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    For years I have been slowly losing pressure on one of my wheels. 3 sets of tires and it still happens so it’s obviously not a puncture. I can’t see the rim being cracked since they don’t take a beating ever and I see no crack. That leads me to believe it’s the metal valve stem. Lately it’s gotten worse. In the past I would see the Tpms light come on after a few weeks. Now the tire is completely flat in 4 days. I tested the stem by submerging the wheel in water and see no bubbles from anywhere on the wheel. At this point I am looking on Craigslist for someone selling a wheel but I would rather find why it’s happening so as not to spend a lot for a new wheel.
    Biscuits likes this.
  2. Jul 24, 2020 at 10:34 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The rim(s) is porous. Try painting the inside of the rim.
    As I understand it, please, someone, correct me if I'm wrong; aren't the alloy wheels powdered and pressed in a mold, rather than molten metal poured into the mold?
  3. Jul 24, 2020 at 10:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Did you have an experienced tire repair shop do this?
    I've had leaks at the bead where the wheel had corrosion (unseen from outside). Just laying it flat and running dishsoap solution around the bead area made nice bubbles.
    Let me say it a different way. Try again. You can't have a leak and no bubbles. :D
  4. Jul 24, 2020 at 10:44 AM
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    I've had a tpms that loosened up a little and was leaking slowly, and i've had dirt get in the bead from wheeling and airring down cause a really slow leak too.
    06Tacooo likes this.
  5. Jul 24, 2020 at 10:45 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Bend in the rim probably
    RoughRder likes this.
  6. Jul 24, 2020 at 10:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get a tire shop to pop the bead off and look for corrosion/gunk where the bead meets the rim.
    Biscuits, Clearwater Bill and SR-71A like this.
  7. Jul 24, 2020 at 10:51 AM
    Muddinfun
    Muddinfun Well-Known Member
    It can also be a leak that only happens when there’s weight on the wheel and it’s turned a certain way. Either by a nail or corrosion at the bead. As others mentioned, I’m betting on wheel corrosion.
    Alexely999 likes this.
  8. Jul 24, 2020 at 11:04 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    If you've gone through three sets of tires, agree, they're not likely the culprit. That really only leaves two options, the rim inself (the bead) and the valve stem. If you saw no bubbles when you submerged the tire, I would guess it's not likely to be the valve stem, but rather the rim area, most likely (IMO) a "flat" spot on the bead somewhere. A new rim would certainly rectify the issue, but you could also check the rim; if you can get the tire off, mount the rim on the spindle and check the bead with a dial indicator for true.
  9. Jul 24, 2020 at 11:07 AM
    Crosis
    Dunedin Fl
    Last time I got new tires I checked for any bead issues. No corrosion no bend no nothing. Toyota did a leak test and found nothing. :notsure:
  10. Jul 24, 2020 at 11:16 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    tyre at proper PSI or at lest 40psi
    get a bucket pour Dawn into it....................Do NOT!! make it soapy!! (NO Bubbles )
    simply for liquid s l o w l y over sections of the beads............Both Sides
    soak the etire rim
    even over the TPMS
    a- the rim might have a stress crack
    b- i suspect the actual ' Valve Core ' is defective
    good luck
    Biscuits, Brownie_Man and SR-71A like this.
  11. Jul 24, 2020 at 11:18 AM
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    I work with a couple of guys from Cape Breton. If your neighbors, oops, neighbours are anything like them, I bet someone is sneaky around at night letting a little air out of your tires, oops, tyres! Those Capers have a warped sense of humor, oops, humour:canada:
    Fitz235 and Jimmyh like this.
  12. Jul 24, 2020 at 11:22 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    I would atleast rebuild The tpms with a fresh seal/gasket. Sometimes they can vibrate while the vehicle is at speed and leak but seal back off when your trying to find the leak. When I was working in a tire shop our local Dill representative told us about it and referred to it as a “ghost leak”. Worth a try and rebuild kits are cheap.
  13. Jul 24, 2020 at 11:54 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    this too ^^
    Ive seen hairline cracks in alloy rims that only leak when there's weight on it.
  14. Jul 24, 2020 at 12:08 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    My 2010 had stock aluminum alloy rims with new tires when I bought it. The rims showed their wear and corrosion was nasty. Two rims leaked air constantly, first one, then the other. It took two tries at a tire shop to get it to stop leaking, then the other one started to leak. During the winter months, I was adding air in it once a week. I found some new take-off steel wheels with full chrome hub caps on CL for $100. Replaced the alloy ones with the steel and haven't needed to add air since the changeout. Scrapped the aluminum ones for $45.
  15. Jul 24, 2020 at 12:24 PM
    Crosis
    Dunedin Fl
    Lol I’ve had this issue way before going to the Cape
  16. Jul 24, 2020 at 12:27 PM
    Crosis
    Dunedin Fl
    Ya know I have had a set of bushwhacker flares in my garage for years and didn’t install them because I didn’t want to use spacers. Maybe it’s time to buy new wheels with the right offset to kick them out an inch, whatever that offset would be.
  17. Jul 24, 2020 at 1:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    As a last resort, before I spent a lot of money, I'd try a half a can of fix a flat. I fought this on a couple of other cars and finally got tired of it. I know it's not the recommended method but it will plug some small leaks.
    And I got to the point that I didn't care if it was a mess for the next guy that put on my new tires.
  18. Jul 24, 2020 at 2:01 PM
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    Loose TPMS or crusty/loose valve core.. A wheel would have to be seriously out of whack to let air out... shy of being visibly cracked...
  19. Jul 24, 2020 at 2:02 PM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Fix-a-flat or similar kills the TPMS...
    Biscuits and b_r_o like this.
  20. Jul 24, 2020 at 3:20 PM
    Greenedmc
    Daniel
    Elizabethton TN
    It also makes it impossible for the tire to be balanced.
