Anyone experiencing tire pressure loss with no puncture?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crosis, Jul 24, 2020.
  1. Jul 24, 2020 at 3:28 PM
    JStarr
    JStarr Life Off the Road
    Jonathan KH6X
    Kaupo Southeast Maui, Hawaii
    Tacoma 3rd Gen 2017 quicksand TRD OR, T4R 5th Gen TRD ORP silver , Tundra 2000 TRD OR silver, Deere 5300 4wd, Wrangler 1994 ARB air lockers, 1998 BMW R100RTL.
    Start with a new valve stem. Most likely culprit and cheapest to fix.
    06Tacooo likes this.
  2. Jul 24, 2020 at 3:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't put fix-a-flat in it. That shit is nasty, it won't do anything and it'll throw the tire out of balance
  3. Jul 24, 2020 at 3:40 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Valve stem probably just worn out. Pretty typical replacement item, especially if they have never been serviced before
  4. Jul 24, 2020 at 5:25 PM
    Crosis
    Crosis [OP] Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Ok I will try the valve stem first. It’s original and my tpms light is always on anyway.
    RoughRder likes this.
  5. Jul 25, 2020 at 8:17 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I've experienced that with Bridgestone tires on two different vehicles. Only Bridgestone tires, and only those towards the latter end of their lifespan.
    I tried replacing the valve stem to no avail. The only thing that fixed it was a new set of tires.
    I now have Michelins on my Tacoma and BFGs on my Acura. I might try Bridgestone tires again, but it would have to be a really killer deal.
  6. Jul 25, 2020 at 12:21 PM
    JStarr
    Jonathan KH6X
    Learned long ago that after checking air pressure always put a bit of soapy water or saliva on the valve stem and check it after a minute or so for bubbling. If it bubbles or you otherwise suspect a problem, take a valve tool and screw out the core and screw in a new one. You can do this quickly without deflating the tire too much.
    The cores do loosen up or the tiny o-rings degrade or a bit of grit gets in them. They are less than a buck apiece, and every glovebox or tool kit should have a tool and spare cores. Some old-style metal valve caps have a tool built in.
    spitdog likes this.
  7. Jul 25, 2020 at 1:11 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Do the tpms take any special valve cores? Or will and basic valve core that fits a rubber valve stem work?
    JStarr and 06Tacooo like this.
  8. Jul 25, 2020 at 6:19 PM
    UncleRick
    UncleRick Well-Known Member
    Rick
    2012 Tacoma Prerunner
    For my 2012 it's a normal valve stem. I got mine from Wally's
    06Tacooo and spitdog[QUOTED] like this.
  9. Sep 20, 2020 at 1:46 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    It's a standard valve core.. see if it's just loose first. Usually I just need to tighten one. I'm exact about setting PSI just for that reason.. so when tpms comes on, and only one tire is off a bit, that's the first thing I check. Last time, my right rear was 5lb. lower. Sure enough, gave the valve core about 1/8 turn, and aired up. it's fine. Not always the case though. May be a slow leaker. Keep some extra cores. Replacement can be done on the truck. Be ready when you remove it. Jack up the rear end, if you want to remove all the air first, but not needed.
    Keep the valve caps on, keeps crud out, especially winter crud. I like the green ones, even though I don't use nitrogen, just compressor air. I even have green caps on my air bag valves. Easier to see at a glance, more noticable at a distance if one's missing.
    JStarr and spitdog[QUOTED] like this.
  10. Sep 20, 2020 at 5:09 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You know, that makes sense. I've never considered that before and the old Corolla I used it on, didn't have TPMS. Noted for future reference!
  11. Sep 21, 2020 at 2:08 PM
    JStarr
    Jonathan KH6X
    Same as all!
  12. Sep 21, 2020 at 2:12 PM
    JStarr
    Jonathan KH6X
    I like the green ones, too. Though I think they signify that the tire has goo in it. Metal ones with the stem tool built into the top are handy, and my Taco has fancy ones with the TRD logo on the top.
    Ultimately, it's good to have any kind caps to keep the grunge out.
  13. Sep 21, 2020 at 4:07 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    I use these. Keeps me from losing them....
    BillsSR5, 06Tacooo and JStarr like this.
