Anyone find an available '24 Tacoma mud flap/guard solution?
Discussion in '4th Gen. Tacomas (2024+)' started by NoCa95862, Jul 17, 2024.
  1. Feb 17, 2025 at 10:33 AM
    #41
    magnitude7138
    magnitude7138 Member
    Was looking at getting the weathertech mud flaps for my 25. Did you ever get these? They look like they'll give good coverage, better than OEM at least, but haven't seen many reviews so hesitant to pull the trigger yet.
    WeatherTech 2025 Tacoma Mud Flaps
  2. Feb 17, 2025 at 11:56 AM
    #42
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    No, I bought the Husky mud flaps.
  3. Mar 1, 2025 at 3:14 PM
    #43
    Stitz
    Stitz Well-Known Member
    South Jersey
    2024 TRD OR Supersonic
    Curious how yours turned out. Mine came with no screws and the rear flap holes didn't even line up. 2 of 4 were off at least 1/4 to 3/8", enough to miss the screw grommet. Had to use piece cardboard to map out the correct bolt pattern and re-drill the mudflaps. Installed with some oem screws I also had to buy separately. One had big chunk of plastic from the mold not properly trimmed off. Really poor quality for what they are charging.
  4. Mar 1, 2025 at 5:06 PM
    #44
    CrispyTacoLover
    Mine were fine. It only had one hole slightly off. Sorry you had a bad experience. I usually buy weathertech but there’s weren’t out yet when I bought Husky.
  5. Mar 2, 2025 at 3:13 AM
    #45
    BaltimoreMD
    BaltimoreMD Well-Known Member
    4gen Taco Ltd HV
    The USA factory mud flaps are pretty disheartening. I do wonder what led them to creating that refined shape (extra margin in EPA tests for airflow dynamics?)
    Having just installed them, I can attest that OEM part:
    Tacoma Mudguard & Hardware Set
    Part Number: PK389-35R00-P1
    Fits 1:1 on all mounting points and is wide enough to cover out to the sidewall for both OEM 18x7.5 +55 (LTD wheel) and the OEM 18x8 +45 (TRD wheel).
    This is the set that you see in all the marketing materials where "Tacoma" is stamped into the rear guards. 3 screws each front, 4 on each back. Took less than 15 min.
    For the +20 wheels of the TRD Pro and Trailhunter, change the part code to PK389-35R50-P1 to get the even wider version.
    These two come as a kit of all four and the #500 set came with screws as well (I just reused from the factory set)
    And to finish off the OEM options, here are the past numbers for the angular factory flaps:
    76621-AK010 front right
    76622-AK010 front left
    76625-AK010 rear right
    76726-AK010 rear left
    BC Hunter, Storm52 and snickers like this.
  6. Mar 2, 2025 at 7:10 AM
    #46
    Storm52
    Storm52 Member
    MN
    2024 Tacoma TRD OF Premium
    I too just installed the Canadian OEM version on my TRD OF. The coverage is way better and they look good!
  7. Mar 2, 2025 at 12:42 PM
    #47
    synfinatic
    synfinatic Well-Known Member
    San Jose, CA
    2024 Trailhunter
    Running the Canadian OEM on my TH. No complaints here- definitely is keeping the side of the truck a lot cleaner than without.
    BC Hunter likes this.
  8. Mar 23, 2025 at 4:40 AM
    #48
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  9. Mar 31, 2025 at 8:47 AM
    #49
    codeblue!
    codeblue! Active Member
    Codeblue
    2019 OR sold, 2021 OR, 2023 OR, 2025 TrailHunter
    thank you this is the exact post I was looking for guess I will be retracting the order for the standard ones and getting the Canadian version.
  10. Mar 31, 2025 at 8:56 AM
    #50
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    I posted photos in the "Mud Flaps" thread yesterday. OEM USA vs OEM Canada on TRD OR Premium iForceMax
  11. Mar 31, 2025 at 9:59 AM
    #51
    codeblue!
    Codeblue
    sweet let me see if I can find that unless you have a quick link I typed in trailhunter mud flaps.
  12. Apr 4, 2025 at 8:22 PM
    #52
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    The RallyArmor kit is spendy but they fit so well. Lots of coverage, very flexible, easy install. No regrets.
    Co_TRD, richietaco and PUMPKINKING like this.
  13. Apr 5, 2025 at 10:17 AM
    #53
    TH_Don
    TH_Don Active Member
    2024 Bronze Oxide Trailhunter LWB
    Removed the standard Canadian wide mudflaps on my Trailhunter and replaced with RallyArmor flaps which hang about at least two inches lower front and rear so that's blocking a lot more of what the wheels throw up. The other important thing with the RallyArmor flaps is they eliminated the v-notches where a lot of splash was coming through onto the sides of the truck.
  14. Apr 6, 2025 at 9:05 AM
    #54
    PUMPKINKING
    PUMPKINKING Member
    I have the full-sized Ark flaps and I like them. I had rally-armor mudflats on my Subaru and they are much nicer than Arks but also more expensive.
  15. Apr 6, 2025 at 9:38 AM
    #55
    roalddahl
    roalddahl Well-Known Member
    2025 DCLB OR Terra, 2011 Access cab OR Silver
    Can you perhaps quickly measure from ground to the bottom of the flaps? I like that height and might try to replicate it DIY.
  16. Apr 6, 2025 at 10:17 AM
    #56
    wfxt
    wfxt Well-Known Member
    The Empire State
    2025 Underground THLB (2021 MGM T4R Pro)
  17. Apr 6, 2025 at 12:51 PM
    #57
    BearWithMe
    Four Corners
    Prior: '18 OR 6MT
    For sure. I installed the RallyArmor flaps my 3rd day of ownership. Ordered them even before I took delivery of the truck!
  18. Apr 6, 2025 at 8:46 PM
    #58
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    I don't know, seems like anything coming from through the notch would hit up higher where it looks clean. Mud and rocks don't sling off the tires perpendicularly.
  19. Apr 7, 2025 at 8:44 AM
    #59
    TH_Don
    This gap elimination is for spray coming off the tires flowing back through the gap (with some salty spray starting to be seen in front of the body side moulding), not necessarily rock chipping. The body sides are less “white” now from salty wet spray drying on it when snow melting occurs.
    On a Trailhunter with stock size Goodyear Wrangler Duratrac RTs ~33” tires and factory lift my front RallyArmor flaps are about 8.5” above ground and the rears are about 9.25”, both are at least 2” closer to the ground than my stock Toyota Canada mudflaps.
  20. Apr 7, 2025 at 11:20 AM
    #60
    gasgasman
    gasgasman Well-Known Member
    I have these on mine also. The side of my truck is not covered in mud, like before.
