Anyone find themselves leaving the turn signal on?
Discussion in '4th Gen. Tacomas (2024+)' started by Hossdawson, Jul 31, 2025 at 12:59 PM.
  1. Jul 31, 2025 at 12:59 PM
    Hossdawson
    Hossdawson [OP] Well-Known Member
    Hoss
    Harrisburg, Pa
    2025 TRD Sport Underground
    You can barely hear it when you are sitting at an intersection without the radio on. Is there any way to turn it up? Possible safety issue and could cause an accident!!
    Hoss
  2. Jul 31, 2025 at 1:04 PM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
  3. Jul 31, 2025 at 1:08 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    No...might want to get hearing checked
    shakerhood and tclavell like this.
  4. Jul 31, 2025 at 1:08 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I changed mine to max volume via Carista. Bad hearing. Too many rock concerts. :headbang:
    Vidman, porterx and bbartol like this.
  5. Jul 31, 2025 at 1:18 PM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    How to say that you are getting old without saying that you are getting old.
    Vidman, Motor Away and wilcam47 like this.
  6. Jul 31, 2025 at 1:30 PM
    Hossdawson
    Hoss
    Harrisburg, Pa
    My hearing is fine. My passengers barely hear it when I ask them if they can hear it.
  7. Jul 31, 2025 at 1:32 PM
    Hossdawson
    Hoss
    Harrisburg, Pa
    What is Carista?
  8. Jul 31, 2025 at 1:37 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    What are you doing behind the wheel that you completely forget you engaged your turn singnal a few moments ago.
  9. Jul 31, 2025 at 1:44 PM
    wilcam47
    Will
    Bourbon state
    Exactly
  10. Jul 31, 2025 at 1:49 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    https://carista.com/en
    Allows you to change and customize more settings that don't show up in the instrument cluster. I used it to turn off the noise cancelling, turn off fake engine noise, turn off seat belt reminders, adjust turn signal volume, adjust turn signal flashes to 5, etc...
    EDIT: here are the options for the Tacoma https://carista.com/en/supported-cars/toyota/tacoma/4th-gen
  11. Jul 31, 2025 at 4:15 PM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    I’m was the opposite. I turned the signal volume down using Carista.
  12. Jul 31, 2025 at 4:32 PM
    Hossdawson
    Hoss
    Harrisburg, Pa
    I don’t see how mine could go any lower!!!
  13. Jul 31, 2025 at 4:44 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I can't hear shit, but my eyes work, and I check the dash often.
    It isn't a real problem for me; it rarely happens and only briefly when it does because I keep a check on the gauges.
    Every other vehicle I've owned for the last 20 years will only blink 3 times then shut off automatically if I just tap the stalk. Great for changing lanes on multi-lane roads. If I actually move it then it flashes until I turn it off. My Tacoma doesn't have that feature and if I've been driving one of the other vehicles I sometimes forget briefly when I get back in the Tacoma.
    batacoma and Vidman like this.
  14. Jul 31, 2025 at 6:30 PM
    Stringburner
    Stringburner Well-Known Member
    West Virginia
    2025 Toyota Tacoma TRD Off Road 6MT
    My hearing is perfectly fine. I've never had a vehicle with that low turn signal volume. Like others, the tone is almost imperceptible even with the radio muted. I turned it to maximum volume when I turned of the seat belt alarm (that they made damn sure you could hear), & it's still lower than any other vehicle I've owned.
    Old Trucker likes this.
  15. Jul 31, 2025 at 6:40 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I solved that problem by never turning.
    wilcam47, batacoma and gasgasman like this.
  16. Jul 31, 2025 at 10:34 PM
    chuychanga
    chuychanga Well-Known Member
    2000 LX470, 2006 Tacoma Prerunner, 2023 Tacoma Off-Road
    Are you using the soft push when you change lanes or exit the freeway? A soft push of the blinker stalk makes it blink just three times and then goes off on its own.
    I won’t say I’ve never left mine on before, but using soft push eliminates 99% of the times when you might accidentally leave it on.
  17. Aug 1, 2025 at 2:33 AM
    hagglethorn
    hagglethorn Member
    Russellville, AR
    2025 Tacoma OR Prem Hyb
    Mine will do the 3 blink and then stop as well. Or after a turn it self cancels. No issue with it staying on. :confused:
  18. Aug 1, 2025 at 3:45 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I'm only 54. Ask me if it's a problem 10 years from now.
  19. Aug 1, 2025 at 4:20 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    If you see a red Tacoma driving around NE Ohio with its turn signal on that is just me. I am hearing impaired and have to visually see the turn signal light on the dash before I will turn it off. I try to hold on to the signal lever making turns so this doesn't happen but once in a while it does. Sorry
  20. Aug 1, 2025 at 4:24 AM
    batacoma
    batacoma Truck Wars
    There's been the occasional lane change where I left it on and didn't realize only to see the indicator on the dash flashing, usually if the windows are down and cruising at highway speed. There's also the potential where you make a turn that isn't enough to cancel on its own. I tend to cancel the signal myself the majority of the time. There are some vehicles that will alert you that the turn signal has been on for an extended period of time but I think the last time I saw that was a commercial truck.
