Anyone get 20 mpg with 4.0L V6 ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Mar 9, 2008.
  1. Feb 28, 2010 at 7:48 PM
    #361
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    I haven't checked it closely but I do know I've gotten 17.5 before and the truck is relatively new. I'd say 20 is possible but you would have to be very light on the go pedal! :)
  2. Feb 28, 2010 at 9:50 PM
    #362
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    I've calculated my running average since purchasing my Taco last May at 18.36 MPG. That's city and highway combined mileage and with the truck being run through four full seasons of Canadian weather, including some VERY cold temps.
    My worst tank yielded 13.32 MPG and that was at -30 to -40. My best tank yielded 21.72 MPG and that was pure highway driving in the summer. Most of the time I'm 18-19 MPG in mixed driving. Heck, I even get that same 18 MPG on the highway towing my boat.
    As for there being "no excuse for a small truck getting the mileage the Tacoma does", I think people need to realize that the Tacoma isn't exactly a small truck. Compared to today's 1/2 tons it is, but my Tacoma isn't that much smaller than my 1997 1/2 ton was. The 4.0 isn't exactly a small engine either. It's a big V6 with allot of grunt and sorry folks, it's going to use gas. It uses a heck of allot less fuel than the 4.6 V8 in my old F-150 did and it delivers a much more performance oriented package in doing so. What's the problem again?
  3. Feb 28, 2010 at 10:01 PM
    #363
    billyjoe
    billyjoe Taco Fever - I've got it bad!
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Extang Trifecta Tonneau
  4. Feb 28, 2010 at 10:22 PM
    #364
    genuinejesse
    genuinejesse Member
    Texas
    10' Black SB Prerunner
    Seat belt chime mod, trimmed front mud flaps, FJ wheels with 265/75 BF Goodrich AT KO
    Ive seen as high as 23 all highway with the stock steels. But since the upgrade to fj wheels highest is 20.7. Compared to my previous vehicle (5.7 Tundra) never saw 17 driving all highway. I think anywhere around 20 for a V6 truck is fine.
  5. Feb 28, 2010 at 11:08 PM
    #365
    baditz
    baditz Active Member
    FBI or From Big Island HI
    06 Tacoma Access Cab 4x4 TRD 6spd V6
    I dunno about the Ford getting 24mpg. Is that correct 600 miles on a 25 gallon tank. The last time I seen a test done by Ford it got the sticker and they compared it to other full size trucks (Like the Tundra, Ram, Sierra and Titan). My friend has one and gets way less than whats on the sticker. I dunno if it's becuz the Hawaii air but I think V8 are great if you really need them. As far as mine Tacoma, at the beginning for some reason the mileage stank really bad (Like steady 15's). But recently I have been getting a solid 17-18 which is close to what the sticker says. I don't do highway because everything in where I live is close, but I can image getting 20-21 if I did. btw that's with 265-70-16 BFG's. The only reason I would buy a Ford right now is if I needed a Diesel. I am the daily driver who works in retail, so I don't need to tow anything around and the weekend warrior who goes camping and offroading once in a while. I hope that helps you.:)
  6. Feb 28, 2010 at 11:43 PM
    #366
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Yes, to answer the OP's question. I am getting 20
  7. Mar 1, 2010 at 5:10 AM
    #367
    dbarn
    dbarn Well-Known Member
    Texas
    Tacoma 4X4 V6
    My 2010 auto was shifting a little rough. When I turned the corner slowly without stopping and begun to accelerate it would hang up in first gear before shifting at a higher rpm. Took it to the dealer and had them reprogram the computer. It seems to drive and shift much smoother since this has been done. Prior to this was averaging around 19 mpg combined driving. Will be interesting to see if mileage improves.
  8. Mar 1, 2010 at 5:13 AM
    #368
    madcatter
    madcatter Well-Known Member
    western pa
    2010 tacoma
    jl audio stealthbox jl audio slash g2-500/1v2 good year dura-tracs jl audio g-class 50wattX2amp mb quart 5 1/4" rear matted mb quart 6.5 comp.set lotsa dynamat 4ga amp kit 16 gauge wire kit control knob on dash pioneer avic-x910bt in dash navigation dvd playback sirus tuner/bus interface built in blue tooth toyota environmental package leaf tsb weather tech floor liners yellow wire mod gray wire mod compartment bed lights added tie down d rings
    i seem to be averaging 19.8
    the last tank averaged 17.3 and most of that was all off-road in 4wheel drive.
  9. Mar 1, 2010 at 5:33 AM
    #369
    wolfgang
    wolfgang Active Member
    south USA
    12 4 door prerunner
    Air Intake system
    I get 20.5 at least all the time got 23 a few times---seems to be better in the winter with the AC off and I run reg. gas and avoid E85 which seems to give less gas mileage. I drive like an old guy even my 8 year old grandson says so. My 2005 double cab short bed 2WD is stock with 105000 miles on it and runs well. Just removed the secondary filter which has a weird kind of corrision on it ??? and it seem to run smoother I was very careful taking it off in case I want to put it back. I'll be checking the mileage to see if it has any effect.
  10. Mar 1, 2010 at 5:50 AM
    #370
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    I average a little over 19...so Im close.
  11. Mar 1, 2010 at 7:15 PM
    #371
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    My 05 DC LB gets 18-19 in town and 20-21 on the interstate. Pretty close to the sticker, and that is with 110K miles on it.
  12. Mar 2, 2010 at 4:22 AM
    #372
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Exactly. And some of the people bitching about low mpg or calling people like you and me liars don't even have 5,000 on it to fully break it in. :rolleyes:
  13. Mar 11, 2010 at 9:15 AM
    #373
    kctacoma
    kctacoma Member
    kurt
    morgantown,IN
    10 tacoma sr5 TRD offroad
    hey fellas im totally happy w/ the fuel mileage im getting with my 4.0l. past three previous fill ups were w/ the oil from factory and was consistently avging 20-20.5 mpg. went to mobil one 5w-30 and first tank was 21.6. filled up today;396 miles on 18 gallons! 22mpg. no complaining here. i wud say the engine is getting more broken in as well
  14. Mar 11, 2010 at 10:33 AM
    #374
    phoneguy44
    phoneguy44 Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Well, I got mine sunday, 5.5 hours away. I filled it up and when I got home filled it up again. I got 22.6 mpg with tonneau cover on. Havent burned enough gas to know what I'm going to get in the city yet.
    4x4 double cab
  15. Mar 11, 2010 at 10:39 AM
    #375
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i can get a little over 20mpg on the highway.
  16. Mar 11, 2010 at 10:42 AM
    #376
    fau8823
    fau8823 Well-Known Member
    Tom
    Hampton Roads, VA
    2010 Tacoma Sport 4x4
    Tint-20%, Kenwood 2 meter radio, firestik 2 meter antenna on a BAMF tailgate mount, Extang Solid Fold , Pioneer bhs-3500 HU, clazzio leather seats, Scangauge II
    Dont you guys watch Mythbusters??? lol.
    Seriously though, they did a special where they tested tailgate down vs tailgate up, and the truck with the tailgate up actually got better mileage. I'd assume it would be similar with a tonneau cover, though they didn't go that far with the experiment.
  17. Mar 11, 2010 at 10:44 AM
    #377
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    Wow. I have yet to break 18mpg, even last fall...
  18. Mar 11, 2010 at 10:59 AM
    #378
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    DAMN! new spark plugs and my MPG's dropped. i'm at 18-19 now, no matter what i do. it is running smooth as silk..maybe the smoothnest makes me drive faster. dunno.
  19. Mar 11, 2010 at 11:27 AM
    #379
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    maybe consider a 1st get tacoma with the 3.4L. I used to get 22MPG!
  20. Mar 11, 2010 at 11:33 AM
    #380
    BlackTide10
    BlackTide10 Member
    Charleston SC
    2010 DC TRD Off-Road
    I'm getting approximately 21-22 mpg. 2010 DC TRD Offroad. BUT.....I drive like the old guy that I am.
