Anyone get 20 mpg with 4.0L V6 ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Mar 9, 2008.
  1. Sep 2, 2011 at 3:40 AM
    #541
    nobigbro
    nobigbro Member
    Colorado and Texas
    2000 4WD V6
    Seems right to me. I get 21-23 on the hwy - stock with 31X10.5-15 Geolanders. Pulled a trailer from TX to MI and back and consistently saw 13-15 mpg during that trip.
    I wonder if something's amiss with your rig. There's no way you empty should match my trailer-towing number. :confused:
  2. Sep 2, 2011 at 7:57 AM
    #542
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Are you guys reporting over 20 mpg using the Scangauge, or are you actually burning a tank of gas and dividing by the miles your odometer gives? :confused:
    Stop and go (city/ town) driving really drinks the fuel... and I am not blasting off from the stop. Pure highway cruising gets me 2-3 mpg more, but that is doing 65-70, with the AC running... that still is never more than 19 MPG on Ca gasoline, however.
    I am about due for my 30,000 mile service, and new spark plugs may make a difference, yes?
  3. Sep 2, 2011 at 8:12 AM
    #543
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Ultragauge shows mid 18's, calculated I'm pushing 20 mpg. I usually average 19.7 - 19.8 mpg mixed driving, mostly backroads and some highway to and from work. If I'm 100% highway I only get 17 mpg.
    I changed plugs at 40k miles, no difference in MPG's. The old ones weren't in terrible condition though.
  4. Sep 2, 2011 at 8:24 AM
    #544
    joes06tacoma
    Joe
    Central Coast, CA
    Good to know it's not just me seeing a difference with California gas. The only way mine will approach 20MPG in California is on long trips on two lane highways where the posted limit is 55MPH. I get between 19-21 depending on the elevation gain or loss. Once out of California I can drive 80MPH with AC on and I still get 18-21. Try driving 70 inside Cali and I drop down to 17-18 even on flat ground.
  5. Sep 2, 2011 at 8:28 AM
    #545
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    FWIW, until i got about 15k miles on my truck, my mileage was horrible (14-17 mpg). Now I get 17-21 consistently.
    And as I mentioned before, if you have the stock tires (265/70/16 stock on TRD OR) your actual mileage and speed is approximately 3-4% too low, so your actual mileage would be lower than you think. I am not sure what the difference is on the other tacoma models.
    For example:If you drove 300 miles (according to your truck odometer) on 15 gallons you would have acheived 20mpg, but in actuality, you have really only traveled about 290 miles on that tank or 19.3mpg.
    I don't know if there is a standard the auto industry can be off and still be considered in spec. I do know that the odometer was off by about 5% in my other car (honda accord) and there was a class action which resulted in an increase in mileage on the warranty.
  6. Sep 2, 2011 at 8:30 AM
    #546
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i drive mostly highway (70%) at 80mph every day and average 19-21mpg, the rest is backroad, town driving
  7. Sep 2, 2011 at 9:11 AM
    #547
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    You sure about that? I had heard that the fed allows the speedo to be off by 5% but not the odometer and believe they run from a different source?
  8. Sep 2, 2011 at 9:19 AM
    #548
    Nolazach
    Nolazach Well-Known Member
    New Orleans
    An ARE camper shell, a 1000w power inverter.
    Just bought my truck and took it right away on a 1600 mile trip.
    85-87 Octane Gas, in high heat (85-115) it averaged 21 MPG.
    I was impressed. 2006 Access Cab. 4.0V6 prerunner
  9. Sep 2, 2011 at 9:27 AM
    #549
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Durrr, you just derailed my theory on why I'm getting bad gas mileage right now. Hot as hell here, the power loss is noticable, but I guess good mileage can still be had. Guess if I could keep my foot out of it around here, that or it truly is the quality of gas.
  10. Sep 2, 2011 at 9:33 AM
    #550
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    You got that right. I just ran 3 tanks of 91 oct with no Ethynol. I was driving 70-80 MPH got 18.5 MPG. When using 93 oct with Ethynol ant 65 MPH I was geting 16.5. All illinois gas has that crap. In Wisconsin you can get 91 oct with no Ethynol. I even stoped to fillup I had driven 320+ miles and the gauge read about 1/8 tank left. I took 17.4 gal.
  11. Sep 2, 2011 at 9:35 AM
    #551
    David K
    Yep... that is 'normal' or close to what I have experienced with all three of my 4WD automatic Tacomas ('01 3.4 V6, '05 4.0 V6, '10 4.0 V6)... although, I have never got 20 mpg or more in any of them... 19 point something was always the best.
  12. Sep 2, 2011 at 9:52 AM
    #552
    bamma
    Spokane, WA
    As I said, I assume the odo is off too. It may have a different source. My experience with older cars is they are tied together.
  13. Sep 2, 2011 at 9:59 AM
    #553
    Pugga
    Massachusetts
    Your assumption is incorrect, odo should be dead on, the speedo reads low with stock size tires.
  14. Sep 2, 2011 at 10:17 AM
    #554
    lmcc007
    lmcc007 Well-Known Member
    Charles
    Northern CA.
    2006 SR5 PreRunner Doublecab Longbed
    Tube steps & tonneau cover.
    California gas is the worst and their roads are horrible as well. I got 2-3 more mpg's going through Oregon & Washington than I do driving in California. California gas "might" burn cleaner, but you burn more of it so is it really better for the environment?
  15. Sep 2, 2011 at 10:30 AM
    #555
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    When I drive through Iowa, in some places there are pumps that have ethanol and some that don't, or at least there used to be. I avoided the ethanol-diluted gas like the plague for the same reason.
    I had a Ford that was flex-fuel, meaning it could run on E85... they don't tell you that it lops 30% off your fuel economy...
  16. Sep 2, 2011 at 11:26 AM
    #556
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I'm not lying or fibbing numbers. When my first few tanks were 20-22 I was surprised myself. But I've run the numbers, and tracked with Fuelly, it's right.
    But it's also about the perfect scenario. I drive 80 miles round trip, keep the cruise control at 65ish, 40 miles in mostly no traffic. 40 miles home has 20-25 miles of stop and go. I keep the windows cracked just a bit and the back window opened. No AC. Right now I'm at 370 miles and my light just came on today. I'll drive home and fill up and it will take somewhere around 18.5-19 gallons. So 410/19 = 21.57
  17. Sep 2, 2011 at 11:31 AM
    #557
    elatacoma
    elatacoma Member
    SoCal
    Double Cab TRD OR SR5
    I just completed a my first semi-full fill up on a V6 Prerunner, TRF Off-road package, fully stock, with 36 PSI on tires. I traveled 370.5 miles on 17.5 gallons. That's 21.2 MPG. Averaged 70 MPH on highways, with 30% use on city streets. I replaced the air filter just after filling up. It was awefull, very dirty. I don't think a clean air filter will improve my MPG much cause it seems pretty "high" already. Will post update on next fill-up.
  18. Sep 2, 2011 at 11:35 AM
    #558
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I just recently started getting over 20mpg once I took off my BESTOP. On my most recent 1700 mile trip I was averaging about 22mpg going through the mountains. I am curious to see what I get on my way back down on my next trip next week.
  19. Sep 2, 2011 at 11:36 AM
    #559
    colder
    MN
    My average is about 20mpg, and given the 21.1 gallon tank, that puts our theoretical range on a tank of gas at 422 miles.
    I have a road trip next weekend that Google says is 416 miles, all interstate highway. It would be fun to see if I could coast in on fumes, but... I'm not brave enough to try it ;)
  20. Sep 2, 2011 at 11:45 AM
    #560
    Fightnfire
    Marysville, WA
    I am. Throw a 5 gallon can in the back and try it :D
