Anyone get 20 mpg with 4.0L V6 ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Mar 9, 2008.
  1. Mar 12, 2012 at 2:54 PM
    #861
    Eurosport
    Eurosport Well-Known Member
    around the world
    14.1 mgp mostly city on this tank
  2. Mar 12, 2012 at 6:15 PM
    #862
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    In the winter time between engine oil and tranny gear oil it's an easy 2 mpg because dino oil gets so much thicker under 20F. In the warm weather the difference seemed to be maybe 0.5 mpg. Most of the benefit is cutting out the high fuel use at cold start.
    This truck is very picky with wind. All it takes is a 5 mph headwind and it starts dumping gas. Mine also has moods; if I push it really hard it won't let me back over 20 mpg for about 50 miles.
    Since I probably won't be pulling much more than a small jon boat this summer I'm starting an experiment with a stealthed upper grille block. Lower grille is still wide open. I wouldn't try this without the UG though, especially in the heat of summer. Need to more closely monitor temps (and listen for the fan) and the alarm feature means peace of mind.
  3. Mar 12, 2012 at 7:31 PM
    #863
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I was getting consistent 19-21 mpg for the last 5 years until I installed the front diff and axles...now i'm getting around 17-19 with the extra weight.
  4. Mar 13, 2012 at 3:46 AM
    #864
    divad94
    divad94 Active Member
    David
    Ivor, VA
    05 Tacoma PreRunner SR5 2WD
    K&N air filter
    Ive been getting this for the last year since I cleaned the fuel system and switched to non-ethanol gas. Just a little quirp of mine I check it every time I fill up and it has been consistant. I know it sounds crazy. I divide the miles driven by the gallons it takes to fill up and I never let the tank get below half full.
  5. Mar 13, 2012 at 7:07 AM
    #865
    soup1279
    soup1279 Active Member
    Anthony
    Pottstown, PA
    2018 TRD Off-Road MT Quicksand/Black
    First fill up on my newly acquired 08 4x4 TRD sport was 19mpg. I figure I could hit 20 if I had less idling and stop/go
  6. Mar 13, 2012 at 8:34 AM
    #866
    SeaThruLens
    SeaThruLens Veteran Lurker
    Bill
    Stuart, Florida
    08, TRD Sport
    Ever since getting the UG my mpg has jumped from barely getting 400 miles to a tank to almost 500. I commute 90 miles a day mostly on I-95. I slowed down from 75mph to 65-70 and try and follow the big rigs. That gives me and average around 28mpg. Of coarse it drops once you hit the stop and go traffic in town. The real time gauge is a game for me to see how high I can get it.
  7. Mar 14, 2012 at 3:48 AM
    #867
    divad94
    David
    Ivor, VA
    K&N air filter
    Now if you would drop to between 55-60 mph you would probaly get the 30 mpg im getting. But on I-95 I know thats almost impossible to do since you would get run over.
  8. Mar 14, 2012 at 12:40 PM
    #868
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    I call BS.. What is a UG?
  9. Mar 14, 2012 at 12:55 PM
    #869
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Drafting other vehicles on an interstate can significantly increase your mileage. I used to drive from Austin to Denton every Friday afternoon (my fiance, now wife of 20 years lived in Denton), a little over 200 miles. I had a '92 base pickup, and most of the time it would burn about 2/3 of a tank. On TX/OU weekend, it was basically a solid line of cars all the way to Dallas, and I only burned 3/8 of a tank!
  10. Mar 14, 2012 at 12:58 PM
    #870
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    28 mpg?! I doubt it
  11. Mar 14, 2012 at 1:01 PM
    #871
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What is your MPG on a tank ? Doesn't really matter what you get for a 5 mile stretch at a time .
  12. Mar 14, 2012 at 1:13 PM
    #872
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    I just had 381.2 miles/Tank. or 21mpg. Double checked my miles that I wrote down from my last fuel up. I have run 19-20 before but right after putting in the cleaner. This is the most Ive ever had.
    Been running Shell 91 E0 and Lucas oil fuel system cleaner every 1-2 months. I have been driving about 80% highway around 80-110 Km/h
    I use to run 87 E10-15 and averaged about 15mpg and at worst had 13mpg.
  13. Mar 14, 2012 at 3:31 PM
    #873
    iroh
    michigander
    tonneau
    Are E0 stations labeled as such? I haven't seen one not E10 for a number of years in my state so I'm curious.
  14. Mar 15, 2012 at 1:46 PM
    #874
    Eurosport
    around the world
    http://pure-gas.org/index.jsp
    click at the bottom of the page for your state to see stations ;)
  15. Mar 15, 2012 at 6:45 PM
    #875
    iroh
    michigander
    tonneau
    Oh snap! I'm going to be passing by one of those stations tomorrow!
    Thank you SO much for that link.
    edit: no wonder I didn't know. No labeling requirement in Michigan whatsoever unless it's E85.
    edit2: that place just went out of business. POO.
  16. Mar 16, 2012 at 8:07 AM
    #876
    FrankNasti
    FrankNasti Well-Known Member
    Frank
    Anywhere the Army tells my wife to go.
    Subaru Forester
    The toddler and baby seat mod.
    I've been getting 20 mpg combined lately.
  17. Mar 16, 2012 at 8:35 AM
    #877
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    21.2 mpg on my last tank, 10% ethanol Super 93 octane.
  18. Mar 16, 2012 at 9:28 AM
    #878
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  19. Mar 16, 2012 at 5:12 PM
    #879
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I just filled up today. 334.6 miles on 16.6 gallons = 20.16 mpg. This was probably 75% highway driving at 65 mph. I've been concentrating on keeping my right foot VERY light.
  20. Mar 16, 2012 at 6:15 PM
    #880
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    If I stay at or just below 2000 rpms I can get 21 to 22 mpg with mine ('09 Tacoma TRD, 4.0L with auto trans.) Checked this to and from Sacramento and Chandler AZ from San Diego, CA. Around town mileage is of course worse.
    Ray
