Anyone get 20 mpg with 4.0L V6 ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Mar 9, 2008.
  1. Mar 22, 2012 at 3:15 PM
    #901
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    For the tank I mentioned above, light came on at 378 miles.
    Can't go this far unless you know you can best 20. Final avg 22.4, enough to bring my fuelly avg up a tenth.
  2. Mar 22, 2012 at 3:27 PM
    #902
    tacowestley
    tacowestley Khmer Member
    Wes
    562/626, CA
    05 DC Prerunner OR
    8k HIDs, flowmaster, bora wheel spacers 1.25'', debadged tailgate, DRL and foglight anytime mod, BHLM, 09+ LED tailights, painted valence black, mickey thompson classics 16'', switchback LEDs, reverse LEDs, tailgate clamp
    My light usually comes like right before the last line
  3. Mar 22, 2012 at 3:34 PM
    #903
    Honey Badger1
    Honey Badger1 Well-Known Member
    Trip
    New Hampshire
    2011 Tacoma TRD Sport
    Fuzzy Dice, Fighter pilot mod, power ports always on, GPS wired to come on as key is turned, LED Map/dome lights, all weather mats, bed liner, tool box on rail system, Tinted tail lights, repainted badges, Home made grill, Light mounting bracket with two 6 inch. PIAA Drive lights, Stealth mod DTRL on/ off, leather arm rests, door and center.
    love the pic^^ never thought of doing that. I do about the same, I live in a hilly town sometimes pushing 65mph mainly 55 and under. also newer rigs need some time to loosen up.
  4. Mar 22, 2012 at 3:54 PM
    #904
    lmcc007
    lmcc007 Well-Known Member
    Charles
    Northern CA.
    2006 SR5 PreRunner Doublecab Longbed
    Tube steps & tonneau cover.
    My fuel light usually comes on when there is about 4 gallons (17 gallon mark) left in my tank. I try not to run it too low because I don't want to suck up all the dirt and stuff that has settled at the bottom of my gas tank over the years.
  5. Mar 22, 2012 at 5:05 PM
    #905
    iroh
    michigander
    tonneau
    I'd concur with that. My fuel (trip) on the ultra-gauge read about 17 gallons when it lit up. I was wondering if I would miss it but there was no way; that fuel light is dang bright at night time.
  6. Mar 23, 2012 at 10:15 AM
    #906
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    21.24 mpg on my last tank, but much of it was on higher tire pressure due to warmer weather. I lowered it, we'll see how we do on the next tank.
  7. Mar 23, 2012 at 12:35 PM
    #907
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    According to Torque on my Droid X2 and a BT OBDII adapter I got 35mpg on my 20 mile commute today. :eek: Doesn't seem right, but I tried going easy on the skinny pedal, and shifting to neutral on the down hills. I want to see what happens on the way home. lol
  8. Mar 23, 2012 at 3:37 PM
    #908
    Honey Badger1
    Trip
    New Hampshire
    Downshift down hills and let the road turn your engine which uses no fuel, unlike idling which uses fuel. :)
  9. Mar 23, 2012 at 4:09 PM
    #909
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Your fuel pickup is always at the low point in the tank, there is no dirt and stuff settled at the bottom of your gas tanks, any dirt that gets in gets sucked up as soon as it gets near the pickup.
  10. Mar 23, 2012 at 4:18 PM
    #910
    worthywads
    That works great on long steep downgrades. On short mild grades neutral is usually better. If you are in neutral and have to use the brakes, in gear is usually better.
  11. Mar 23, 2012 at 5:50 PM
    #911
    piercedtiger
    Jon
    Southern Tier, NY
    I get better mpg shifting to neutral than down shifting and pushing the RPMs up.
    Still not sure I believe the numbers though. It said I got 38 mpg driving the same route in reverse on the way home, and 35/34 on the out/return 30 mile trip to meet my mom. Seems a bit high for a truck rated at 17-19 mpg highway. :notsure: I think I'll play with it some more.
  12. Mar 23, 2012 at 8:31 PM
    #912
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Does Torque let you adjust to fit real world calculated MPG? My adjustment for my SGII is ~11% on summer gas, 13% otherwise... prior to adjusting it was showing I averaged 25+ mpg.
  13. Mar 23, 2012 at 9:42 PM
    #913
    iroh
    michigander
    tonneau
    Same with the Ultragauge. Had to raise fuel calibration to 1.11 and distance to 1.01 to get it close.
  14. Mar 23, 2012 at 10:16 PM
    #914
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    This Tacoma 2012 V6 4L is two weeks old and getting 20.7 mpg. Daily commute is total 64 miles (16 of this 3,200' descent, climb that back home, with 32 miles of flat in between).
  15. Mar 23, 2012 at 10:19 PM
    #915
    worthywads
    Ward, Colorado - an automobile graveyard where you can live. ;)
  16. Mar 23, 2012 at 10:38 PM
    #916
    1980
    1980 Well-Known Member
    The Dust Bowl
    Your gauge is probably not set right (or they mistakenly sold you a mileage-enhanced prototype truck) but you can get significantly better mileage one way than another. My niece's boyfriend asked me why he always got better mileage driving from college to his parents' place than he did going back. I told him it was because the first trip was downhill with the prevailing wind at his back. In "flat" states you might not notice it but even Kansas drops 3000 feet from west to east.
  17. Mar 24, 2012 at 7:27 AM
    #917
    piercedtiger
    Jon
    Southern Tier, NY
    Not that I've found. It's my phone so it uses GPS for speed and distance calculations along with the ECU. Not sure how it works though since there's no option to adjust for tire size. I'm going to read up on the app some more.
    Not a lot of settings to screw up. Displacement, and C/F, mile/km type things.
  18. Mar 24, 2012 at 7:58 AM
    #918
    iroh
    michigander
    tonneau
    In that case you'll likely have to up the displacement setting until fuel use matches what you read at the pump since that's the end number that really matters.
    It's a computer model, so it'll never perfectly match real life, but a little effort can make it close.
    The calculation for instantaneous mpg is miles/hr divided by gallons/hr (and the calculation for avg mpg is obvious) so if it calculates speed and distance from GPS then the tire size issue won't matter.
  19. Mar 24, 2012 at 8:15 AM
    #919
    Thighmaster
    Ward, Colorado
    There is some truth to that.
  20. Mar 30, 2012 at 1:29 AM
    #920
    lmcc007
    Charles
    Northern CA.
    Recently I've been averaging about 15 mpg with city driving. I still get 20-21 mpg on the highway when I go on a long trip, but I've been getting noticeably worse city gas mileage this winter. I wonder if California is adding more ethanol into the gas now. Ethanol tends to evaporate fairly quickly, especially if it takes you a few weeks between fill-ups. Is there anyone else out there that has been experiencing abnormally bad gas mileage this winter?
