Anyone get the eBay plug & play switchback turn signal kit to work?
Discussion in '1st Gen. Tacomas (1995-2004)' started by snopyro, Mar 27, 2023.
  1. Mar 27, 2023 at 9:09 PM
    snopyro
    snopyro [OP] Well-Known Member
    California
    '03 Limited 4x4 - Black n Tan
    Snugtop shell
    I bought this kit and it seemed straightforward to install. I wasn't quite sure what would trigger the white light to come on since the stock socket has 2 wires. In any case, I tested it out and only the dynamic amber turn signals work. The white lights that should come on with the parking light is not working- but how can it without a parking light trigger wire from the front corner lamp? Thought I'd ask this group for their input (besides- do the proper 1157 wiring/socket mod with a switchback LED). Thanks!
    https://www.ebay.com/itm/403716634903?fits=Year:2001|Model:Tacoma
  2. Mar 28, 2023 at 10:45 AM
    snopyro
    California
    Snugtop shell
    eBay vendor messaged me back and told me to cut the white wire into the aftermarket wiring and tap it into the corner parking (positive) light for it to work as expected... so NOT plug and play, but should be doable to make it work using wire taps to bring the wire down from the corner lights to the turn signal sockets.
  3. Mar 28, 2023 at 10:51 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
  4. Mar 28, 2023 at 10:54 AM
    snopyro
    California
    Snugtop shell
    Thanks Toyoda213! I would have probably went this route if I knew that the eBay turn signal lamps were NOT plug and play. Since I have to splice to make the white DRLs turn on- it is basically doing the same work you mentioned above. Live and learn...
  5. Mar 28, 2023 at 11:07 AM
    Toyoda213
    Jimmy
    SoCal
    Yea im not sure what they listed it as plug and play. I guess if your turn signals were damage it was worth getting the ebay ones
    snopyro[OP] likes this.
  6. Apr 22, 2023 at 2:33 PM
    2.4taco707
    2.4taco707 Member
    Emiliano
    California
    1997 Tacoma 4X4 2.7L 5Spd Reg Cab
    Got any pics of it on? I just ordered these too.
  7. Apr 23, 2023 at 11:37 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
