Anyone get the random popping noise?
Discussion in 'Suspension' started by macgyver, Apr 6, 2010.
  1. May 17, 2010 at 8:19 PM
    nighthawk87
    nighthawk87 Well-Known Member
    any update on this issue?
  2. May 17, 2010 at 8:45 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 07 Offroad makes a noise once in a while when I back out of the driveway in reverse. The driveway is at a bit of a slope... If I roll backward in neutral first, stop, then put it into reverse it doesn't happen. I always just figured it was the drive-line or automatic transmission engaging and never gave it much thought.
  3. May 17, 2010 at 9:02 PM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    mine was doing this a couple weeks back i could not tell what it was. Well I went under the truck and noticed a screw on my skid plate missing so I think it was just that banging up and down. I tightened it up but have not really checked for the popping yet.
  4. May 17, 2010 at 9:14 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I had a popping/clunking from the front end on reversing and some turning a little bit ago. Turned out to be a loose bolt on the lower control arm. I didnt pay attention to it and sure enough the LCA broke while driving. check those out just for precautionary measures
  5. May 26, 2010 at 4:43 PM
    jhmartin
    jhmartin Member
    Mebane, NC
    Grillcraft black mesh grill,LED taillights,emblems removed, Wet Okole seatcovers, K&N air filter, Herculiner bed, Access tonneau, more to come...
    Hi guys, New here. I just bought an '04 DblCab Tacoma Prerunner. I've noticed the same noise when I back out of my driveway or have to turn the wheel to back out of a tight parking spot. I also noticed today that if I have to brake suddenly, when I get back on the gas it will do the same thing. It doesn't do it everytime, but often enough for me to be concerned.
  6. Sep 14, 2010 at 6:57 AM
    macgyver
    macgyver [OP] Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Update...sound is still here, I tried pin-pointing it again last night with no luck. I had my sister back up the truck and pull it forward a few times to see if I could find it..No luck. I backed the truck up and forward a few times and she couldn't pinpoint it either.
    I checked the LCA bolts and they are tight. I'm wondering if its one of the mounts to my front diff or something.
  7. Oct 26, 2010 at 8:35 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Any update? I think I may have the same noise, and my LCA bolts are tight too... :confused:
  8. Oct 26, 2010 at 11:59 PM
    skyedtacoma808
    skyedtacoma808 Member
    97 tacoma
    6" fabtech suspension, 3" body lift, 33 by 14.5 trexus, headers
    It may be the inner cv joint. Usually it'll only make a pop sound if u accelerate or decelerate or goin over a bump. Mines was doin that a few weeks ago n I change them n problem was solved. Let me know if this helped at all mahaloz
  9. Dec 2, 2010 at 6:17 AM
    macgyver
    Brad
    Canton, GA
    A CV joint would make a continous popping noise. Mine only pops once. for example..put the truck in first...ease off the clutch...POP...then keep moving. Put it in reverse...ease off the clutch...POP. or if I'm inching along in traffic and I abruptly push in the clutch and unload the drivetrain...POP then if I abruptly give it gas it will pop again.
  10. May 2, 2011 at 4:18 PM
    Tacoma Joe
    Tacoma Joe Member
    Joe
    Maryland
    09 Prerunner
    Total Chaos
    Mine makes the popping noise too. Only when I first get going in the morning when I turn the wheels coming out of the driveway. I have checked everything on the front twice and it is tight. I have the Total Chaos UCAs and Bilsteins on the front. Any updates on a cause or fix ?
  11. May 3, 2011 at 11:15 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I have a bang/popping noise on the drivers side too. How can I tell if its the CV joint? Also can I just tighten everything on the LCA, or will I change the alignment?
  12. May 3, 2011 at 11:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Are you lifted ?
  13. May 3, 2011 at 11:30 AM
    Canadianboy
    James
    Vancouver, BC
    Yes, Icon stage 3, coilovers set about 2.25" in the front.
  14. May 3, 2011 at 11:50 AM
    macgyver
    Brad
    Canton, GA
    Holy thread revival.
    Still popping...
    Nothing has fallen off yet so I suppose I just have to continue to deal with it.
  15. May 10, 2016 at 12:51 PM
    #35
    03tundra4.7
    03tundra4.7 New Member
    Got the same single "hollow" pop sound when moving very slowly in either direction- any more info on this?
  16. May 11, 2016 at 11:50 PM
    #36
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Had this issue finally occur some years ago. Discovered it was the lower control arm bushings. They are pressed into the arm from the factory and may become loose. Tightening the bolts does not help. Only way to tell is point a camera at them and make some turns backing up and pulling forward. Nothing you can do to fix it permanently except buy new arms or replace the bushings with poly replacements and it's a bitch.
    ready6delta likes this.
  17. May 12, 2016 at 12:24 AM
    #37
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Original brakes? The factory brakes are notorious for making noise once they are all dried up when changing direction of travel. The pins in there that hold the upper and lower part of them supposedly wear out over time. The fact that they aren't held in there very well in the first place due to the lack of an upper brake retention spring doesn't help either. I used to get horrid clunking before I swapped out my brakes. Once I did the swap out and added proper lube to the pins then added an upper retention spring as they should had come from the factory (but did not) the clacking went away for good.
    How it came from the factory (minus the yellow pad replacements):
    After my upper retention spring install and proper lubing of the pins, much better now:
    If it is coming from your rear end check your u bolts to make sure they are tight, they come a bit under torqued from the factory. Additionally, you could check your center pins on the leaf springs to make sure they are tight. If all of that is good and it is indeed coming from your rear, I would consider axle wrap as suspect.
  18. May 12, 2016 at 12:40 AM
    #38
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    I too am chasing a clunk/clank. Only started after lift install. Mine also did the brake pad shifting noise, but that"s not it, it's something different and louder. I've went over all suspension components and everything is as it should be. I'm thinking it's this in the video attached.
    https://www.youtube.com/watch?v=QaNR6qwsVDI
  19. Feb 9, 2018 at 11:41 AM
    #39
    matt 157
    matt 157 Well-Known Member
    California
    2003 Black Xtra Cab 4WD SR5 TRD
    Pioneer DEH 8400 head unit/deck, Crunch 1100 watt amp, 12" Kenwood subwoofer, Kicker mids & tweeters, AllPro front tube bumper, Smittybuilt tow hooks, (welded pipe for muffle) straight-pipe, 4 orange "Raptor" lights in grill, Duratrac tires, American Eagle rims, ProComp 2" front leveling kit, Plasi-Dipped black on chrome trim, PIAA fog lights w/ in-cab switch, Unidin CB/Firestik II/8 ohm PA speaker, TRD leather 5-speed shifter knob
    Did we ever figure it out because I get the same noise under load coming off the clutch
  20. Feb 9, 2018 at 11:52 AM
    #40
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    That sounds like brake pad float.
