anyone get there rotors turned anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by montanacruiser, Jun 17, 2021.
  1. Jun 17, 2021 at 4:27 PM
    montanacruiser
    montanacruiser [OP] Well-Known Member
    2017 DCLB Off Road
    Hi all I have about 40,000 on the truck and I am getting the brake slap really bad. Also I am experiencing some pulsing when I am coming to a stop. Was wondering if new pads and may be getting my rotors turned might help?
    Thanks
    tacotoe likes this.
  2. Jun 17, 2021 at 6:20 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    what is the brake slap? 40,000 seems kinda early to be needing brakes. Unless you tow a lot.
    Chew, BSFord, Mai Toy and 2 others like this.
  3. Jun 17, 2021 at 6:27 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    What do you mean by "pulsing"? Typically when your rotors are warped, you feel a vibration shimmy in the steering wheel. Is that what you are describing?
    tacotoe and Junkhead like this.
  4. Jun 17, 2021 at 6:29 PM
    Bishop84
    Bishop84 Well-Known Member
    With tacoma if its shuddering while braking its too late, the runout is too large and cutting will just induce a future problem.
    I cut rotors using an on-car-lathe and it works really well on tacomas, but there needs to be minimal runout or hot spots.
    Simply put, you need rotors.
    tonered, tacotoe and Junkhead like this.
  5. Jun 17, 2021 at 6:38 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I do a lot of city driving and 30-40Kmi is typically when I end up doing brakes due to pulsation. (Not sure about the "slap")
    Getting rotors turned should help with the pulsing, but I'd consider just buying new rotors and pads.
    It takes too much time to run the rotors to a store, wait for someone to machine them, and then drive back to finish up.
    Cost of decent rotors is not much more than turning them. I've used Raybestos Element3 rotors/pads from RockAuto on several vehicles over the past few years and they seem about equal to OEM for ~$100 all in.
    tacotoe and CrufflerJJ like this.
  6. Jun 17, 2021 at 6:48 PM
    Shellshock
    Iowa
    Just put on new rotors and pads, way easier
    I’m at 115k and still on the originals with plenty of life left. About 15k of those miles are towing.
  7. Jun 17, 2021 at 6:52 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Even back in 1998 we rarely turned rotors, our Ammco brake lathe just collected dust.
    The only time we fired it up was for super expensive / rare rotors drums
    tacotoe likes this.
  8. Jun 17, 2021 at 7:10 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    I don’t. My reasoning is turning the rotors removes material and mass. Mass of the rotor is a major factor determining how much heat they can absorb before warping.
    If you warp a set of rotors, and turn them, odds are you’ll warp them again. I say rotors are cheap, pitch’em and get new ones when you change pads.
    Also, verify your calipers are in good working order and bleed your brakes while you’re at it.
    OvrlndBigAl, DingleTower and tacotoe like this.
  9. Jun 17, 2021 at 7:23 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Dont throw your old rotors away, they are worth money for recycling. Take them to your nearest shop, there will be someone who works there that collects scrap to bring to the recycler. Either give them to that person for free, or tell them to buy you a soda for them. Or you can bring them to the recycler your self and get a few nickels back.
  10. Jun 17, 2021 at 7:25 PM
    Philrab
    Phil
    Fair point.
    But don’t bother turning them. Discard, turn them into ash trays, throw them at the neighbors, tie one to the neighbor’s dog that keeps crapping in your yard, but don’t reduce the mass of them by turning expect them to work better.
    5nahalf[QUOTED] and tacotoe like this.
  11. Jun 17, 2021 at 7:30 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I am curious about this on car lathe set up. Are they expensive or hard to find? The reason I ask is a old Corvette I'm working on doesn't have a floating caliper.
    Sorry to hijack OP. 40k miles seems way early to need brakes.
    six5crèéd likes this.
  12. Jun 17, 2021 at 7:31 PM
    5nahalf
    Erik
    Minnesota
    Yeah, I agree generally turning is useless at this point. I have turned a few rotors, but it usually results in rotors warping right away again anyways and I have to do the job again.
    DanoTay, Philrab[QUOTED] and tacotoe like this.
  13. Jun 17, 2021 at 7:38 PM
    Bishop84
    Most larger dealers have them, they are extremely expensive. Most older cars you service the bearing anyway so you machine it on a standard lathe then repack bearings.
    tacotoe[QUOTED] likes this.
  14. Jun 17, 2021 at 7:39 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Yeah, I'm finding this rotor turning is pretty much pointless. At least on my daily driver car. The first brake job I just put replacement rotors on but kept the originals. Second brake job I had the original rotors turned and they warped in a short time.
    Philrab likes this.
  15. Jun 17, 2021 at 7:40 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Replace the rotors. Cheaper than turning.
    kahanabob and Philrab like this.
  16. Jun 17, 2021 at 7:57 PM
    Texas Aggie
    Texas Aggie Well-Known Member
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    King 2.5's Front and Rear 700# coil, 2" wheelers aal, 315/75R16 BFG KM3's Pelfreybilt Front and Rear Steel Bumpers, All Pro Sliders, 4.56 Gears
    I tried turning my rotors and it ended up ruining my new TRD pads less than three thousand miles later. A Tacoma with warped rotors is a miserable experience and makes you avoid driving anywhere. I ultimately ended up switching to cryo treated Brembo rotors after my second set of OEM rotors warped. My truck is very heavy due to all the armor, 35’s and pulling trailers regularly. That being said, if you’re close to factory tire size and don’t pull a trailer regularly just get some new OEM rotors and pads. They are cheap and work very well.
  17. Jun 17, 2021 at 8:16 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah likewise, and realistically if you are towing a proper setup, you are not putting any more strain on your brakes (think trailer brakes). I did 100k on my originals of 50/50 city highway driving and they had 10-15k more, but 100k seemed like a good time to just replace again with OEM stuff n call it good.
    If you are only getting 40k outta a set of brakes either 1. you are running way bigger heavier tires, or 2. in too much of rush.
    Chew and Shellshock[QUOTED] like this.
  18. Jun 18, 2021 at 9:38 AM
    montanacruiser
    2017 DCLB Off Road
    Thanks for all the replies. I will just get new rotors. The pulsing I am getting is when I am coming to a stop It feels like the brakes are engaging then letting off and engaging again. Its subtle but there. The brake slap is what really bothers me. Its loud and happens every time I go reverse to drive. I am sure I have plenty of life on the pads but I must have warped the rotors form over heating them. I remember seeing a thread about some slotted rotors and trd pads but think it was for the 2nd gen.
  19. Jun 18, 2021 at 9:45 AM
    eon_blue
    Azusa, CA
    A set of standard brake rotors are so relatively inexpensive I don't see the point in trying to turn them or resurface them, just grab a set from the local auto parts store and slap 'em on with new pads. Enjoy smooth braking afterward
  20. Jun 18, 2021 at 10:04 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Never for me. Always new rotors, pads, drums, shoes, wheel cylinders, rubber/braided stainless hoses, and a brake bleed/flush
