Anyone Good at Rust removal/painting?
Discussion in 'Northern California' started by RockLobster1106, Oct 9, 2011.
  1. Oct 9, 2011 at 10:57 PM
    RockLobster1106
    RockLobster1106 [OP] Well-Known Member
    Northern California
    2002 Tacoma SR5 4wd
    So heres the deal. I have some rust on the roof of my toy that I want to get fixed and ideally I don't want to pay the $600-$1000 the local shops are saying it will cost to repair.
    So I have 3-4 large rust spots on the roof that have not broken through. There are also some rust spots by the windshield because the windshield was replaced at some point and the shop that did it sanded off the paint to put in the new windshield but didn't seal or paint it.
    I can provide pictures if needed but, what I plan to do is sand the rust off, put on POR-15 or some other rust inhibitor/destroyer and repaint. I am not very experienced and the 1st time I tried the paint bubbled after a few weeks.
    Or is it just best to drop the money and have the shop do it right but have it be "un-guaranteed".
  2. Oct 9, 2011 at 11:18 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    hmm.. let's see some pics
  3. Oct 10, 2011 at 7:33 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    what are you reffering to as TOY? crawler truck? If the rust isn't eaten throught, just sand down a bit, or use rustolium for metal, you can just spray that on the rust. Best is to sand a bit, use a cleaner, tape off, and rattle can it with rustolium.
  4. Oct 11, 2011 at 12:36 PM
    RockLobster1106
    Northern California
    2002 Tacoma SR5 4wd
    my toy is a 2002 tacoma sr5. That is the cheapest option but I do not know here is a little video of the rust because I do not have a camera
    http://s25.photobucket.com/albums/c78/pyroschnook/?action=view&current=VID00042.mp4
  5. Oct 11, 2011 at 12:41 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    When I did rust repair on my corolla, I used a wire wheel on a half inch air die grinder to knock the rust and paint off. Then coated with a rust neutralizer and let that sit over night. Sanded down the rust neutralizer and in your case you could just start painting. The windshield area I think i would have done professionally though.
  6. Oct 11, 2011 at 3:26 PM
    05sctaco
    Ken
    Santa Cruz
    silicone the window area, to get it air tight, and water proof. But yeah your gona need to sand it down to metal. and repaint.
  7. Oct 11, 2011 at 7:59 PM
    RockLobster1106
    Northern California
    2002 Tacoma SR5 4wd
    Do you have experience with this kinda thing sctaco? I am also in sc
  8. Oct 12, 2011 at 5:53 PM
    RockLobster1106
    Northern California
    2002 Tacoma SR5 4wd
    yea I think I'm just going to bring it to a shop.
  9. Oct 12, 2011 at 8:44 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You're gonna have to remove the window I fear to get the ones up front. That could be interesting.
    The rest would only take 15 minutes with some sand paper and 5 minutes with a cheap can of primer to at least STOP the rust for now.
  10. Oct 12, 2011 at 9:22 PM
    05sctaco
    Ken
    Santa Cruz
    it looks like they never sealed your front window right, I've painted metal, it's not hard, you can do it right but i'm pretty lazy. I need to hit my sliders with some more paint, the area's that didn't get enough paint have rusted through. But it's easy, just sand, clean, and paint. (obviously you'll need to tape off the areas.) I have a guy that can sand, the whole roof, and color match, but the thing with new paint, and old paint on the other area's is that you can tell it's new and old due to oxidation. I would just try to sand under the window seal, and take some metal cleaner to clean the area after. THEN take clear silicon and silicon under the window seal since you can actually lift it up from the video. and then apply pressure press the silicon in place and wipe off the excess that comes out with a wet rag.
  11. Oct 12, 2011 at 9:25 PM
    05sctaco
    Ken
    Santa Cruz
    they should just do a mod day in the bay area again. I'm going to help someone do a suspension install hopefully next week in San Jose.
