Anyone got any info on cutting 1/2 inch thick rubber mat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Jul 1, 2012.
  1. Jul 1, 2012 at 11:04 AM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    I got a 1/2 inch thick mat about 5 ft x 5 ft that needs cutting to fit in my box. It says it was made in Canada. Probably means it is old and quality made, since most products now sold in Canada are cheap crap made in China, but I digress. Now that I have finished my rant, what I was going to do is use a circular saw for the long straight cuts and a jig saw for the corners. Any advice would be appreciated. Thanks in advance.
    Mark
  2. Jul 1, 2012 at 11:05 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    scissors?
  3. Jul 1, 2012 at 11:06 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Box knife would be my best guess. Just have plenty of blades handy.
  4. Jul 1, 2012 at 11:07 AM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Grinder with cutoff wheel.
    Router maybe
  5. Jul 1, 2012 at 11:09 AM
    TacoDawgfan
    Georgia
    1/2 is thick for a box knife though. Maybe get an old knife you're not afraid to ruin and heat it with a torch or something? Use a board or something for a straight edge for the long cuts.
  6. Jul 1, 2012 at 11:09 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    box cutter FTW. thats what i used when i put d-rings in the front of the bed.
  7. Jul 1, 2012 at 11:33 AM
    Silver Streak
    Silver Streak Well-Known Member
    Westin Bull Bar
    Razor knife
  8. Jul 1, 2012 at 12:00 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Heat is obviously going to be the main problem with a power tool. How well equipped is your workshop? I'd use a bandsaw on a moderate speed setting since the longer blade would help control heat. In fact, I've done it before (with a thick mat to reduce noise from power tools), with pretty good results. However, that much material may be difficult to handle.
    A bandsaw and jig saw might work almost as well if you take breaks when the blades get warm. As you've probably guessed, a box cutter or similar will take too much time and effort, while a grinder will easily generate enough heat to melt the rubber.
  9. Jul 1, 2012 at 12:07 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Bandsaw with silicone spray for lube.
  10. Jul 1, 2012 at 12:10 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Utility knife used with a straight edge of some sort (long level, big square, etc...)
  11. Jul 1, 2012 at 1:35 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Don't use anything with heat or spinning blades. You will just end up with a mess.
    Just a razor blade. Do your first cut then slightly bend the rubber over the edge of something to open up the cut then cut again. If its a good sharp blade it might only take 2-3 cuts. You might even use two blades. I have never heard off the wd40 but I can see that helping on the 2nd, 3rd cuts.
  12. Jul 1, 2012 at 1:40 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    x2 on a box cutter, and change the blades every 6 inches or so. Use plenty of WD-40
  13. Jul 1, 2012 at 1:42 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Is this a hard rubber or pretty flimsy?
  14. Jul 1, 2012 at 1:44 PM
    medic2230
    Murph
    Bama! Roll Tide
    Air nibbler? Sawzall with a wood blade sharpened to a knife blade. Should cut right through it.
  15. Jul 1, 2012 at 1:50 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    sawzall
  16. Jul 1, 2012 at 1:51 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    saudering iron.....i win
  17. Jul 1, 2012 at 1:53 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    HD box cutter and something as a straight edge.
  18. Jul 1, 2012 at 1:56 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Be very careful using a power tool for this job. If the rubber catches the blade and decides to pull the mat it could be dangerous!! Think band saw here. If it pulls on the mat and you have a death grip on it it will pull your hands into the blade. I cut meat for a living and use a band saw.
  19. Jul 1, 2012 at 1:56 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    I had a old dodge bed mat that I found and used it for my Tacoma I used a metal blade in my sawzall and worked great I used my jig saw with metal blade for the rounds. Worked great. Use a long level and clamp it for nice straight lines.
  20. Jul 1, 2012 at 2:24 PM
    troy28
    troy28 Well-Known Member
    Capitol of Salty Roads
    Need help
    ^^ This
    I just cut a hoarse stall mat from Tractor Supply to fit an area. Mark your lines you want to cut on the mat. I used a wax marker/crayon. Do not try and cut through the whole mat in one swipe. Use the blade and score down 1/4 to half way down the mat. Then bend the mat so you see your score line start to open up. Then just repeat cutting that line. Changes blades often and you will be amazed how fast it really goes.
    good luck
