Anyone got any procharger questions, just put one on yesterday AMA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jmiller78, Aug 12, 2022.
  1. Aug 12, 2022 at 12:29 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  2. Aug 12, 2022 at 1:01 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Lol, I was laughing too. It's like on the gun forums, "You shoulda bought a Glock". (should have)
    Ignore those comments. I've been pretty curious about the Pro Chargers as well. I have a buddy from college who worked for them for several years. If I ever find myself with about $6K that I don't know how to spend......
    Please report back after you've had a chance to shake it down!
    Jmiller78[QUOTED][OP] likes this.
  3. Aug 12, 2022 at 2:13 PM
    Jmiller78
    Jmiller78 [OP] Well-Known Member
    2010 Metallic Gray TRD 115K miles
    Procharger, 2" Leveling Kit, Cali Raised Rock Sliders, 1 1/4" spacers, Armordillo Bull Bar, Color matched bumpers/grille, New Clear Coat, 17" TRD Wheels
    387 lb ft of torque
    (HP TBD on tuesday around 350 using calculator, the dyno stopped collecting data after 3k revs)
    https://ibb.co/6WBjJmC
    Super flat curve for being centrifugal
    Edit- Its super flat because they ran it in 3rd after i told them 4th was my 1:1 will update on tuesday with actual results
    DG92071 and Torspd like this.
  4. Aug 12, 2022 at 2:16 PM
    Jmiller78
    Just running it on 91, i read that its easier to get bigger numbers on the procharger
    DG92071 likes this.
  5. Aug 12, 2022 at 2:32 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    If you don't mind how much you spend for procharger right now?
    241hp with procharger....not even break 300hp, any others mod you had done beside procharger?
  6. Aug 12, 2022 at 2:37 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    i think its a typo. if not somthing is very wrong considering stock is 236
  7. Aug 12, 2022 at 2:41 PM
    Jmiller78
    The dyno stopped collecting data after 3k revs
    Edit - due to them running it in 3rd gear not 4th
    DG92071 likes this.
  8. Aug 12, 2022 at 2:41 PM
    Ye Olde Rusty
    Ye Olde Rusty Well-Known Member
    Mac
    Tennessee
    09 TRD Sport DCSB
    3" Procomp lift, 285/70/r17 Toyo R/T, Mobtown Offroad rack over Softopper
    That's probably just wheel hp. With bigger tires and drivetrain loss it's probably closer to 300 at the crank. Even that seems low compared to the torque numbers tho
    Edit: When you plug in 381 lb-ft at 4500 rpm it does come out closer to 350 hp so that makes sense
  9. Aug 12, 2022 at 2:53 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Gas is back below $4.00 a gal.
  10. Aug 12, 2022 at 2:53 PM
    Jmiller78
    I called and asked about the scaling on the graph, he said it didnt collect data after 3k revs so im going back tuesday and theyll re-run it for free, esp on their chart it shows it making max hp at 3350 revs
    Edit - they ran it in 3rd instead of 4th after i told them 4th was my 1:1, no wonder my torque was so high and my HP was so low
    DG92071, Torspd and TnShooter like this.
  11. Aug 12, 2022 at 2:59 PM
    Oreo Cat
    its finally under $6 a gallon here haha
  12. Aug 12, 2022 at 3:44 PM
    Jmiller78
    The dyno stopped collecting data a little after 3k revs, so im getting it re ran on tuesday, procharger kit was 7k, it should be higher when they re run it tuesday in 4th and not 3rd
  13. Aug 12, 2022 at 4:02 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Does it make cool sounds? Can you video them?
    I'd be interested to see the follow up dyno chart when you redo the runs.
    Even though the torque was lacking down low, was there still noticeably more than stock?
  14. Aug 12, 2022 at 4:26 PM
    rnish
    Tacoma 2nd gen
    What gas are you running?
  15. Aug 12, 2022 at 4:40 PM
    #35
    Jmiller78
    91 octane, just filled it with 93
  16. Aug 12, 2022 at 5:55 PM
    #36
    Sarra
    Sarra Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    I've got questions... More than 7 PSI?
    Are you running a BPV, or are you running the TB on the SC inlet?
    Any problems with surge, flutter, or overpressure?
    Did you upgrade your exhaust?
    If you had to do this again, would you go Procharger again, or would you do a turbo, roots, or other setup instead?
    Oh, yeah, auto or MT?
  17. Aug 12, 2022 at 6:04 PM
    #37
    Jmiller78
    8 psi, BPV, no i havent upgraded exhaust, its the next thing on my list along with headers, the install was super easy and i couldnt find any good twin screws for our trucks so id def go procharger again, esp cause the torque maxes out at 2400rpm, i was expecting it to be much more delayed due to it be centrifugal, automatic
    DG92071, Mech_Eng and Sarra[QUOTED] like this.
  18. Aug 12, 2022 at 6:08 PM
    #38
    Sarra
    None yet
    I'm 90% sure my foray into forced induction with my Taco will involve two rather large turbos, hooked up to a LS3 or such, instead of a 1GR. Though, I'm stupid tempted to get a Holset variable vane turbo and try setting it up, but I'm too worried that I would turn my 6MT into a trail of parts in the road.
    I'm jelly. Your truck probably has the guts now that it would be able to keep up, on a steep hill, with my old Baja. I miss that... Well, I think it was a truck, but lots of people call it a car, but it wasn't really a car... Thing. I miss it, I wish the transmission hadn't blown up in it, but it did, and now I have more fun offroad, and almost no fun onroad... Maybe I'll get an AE86 and stuff a 2JZ under the hood for on-road shenanigans.
  19. Aug 13, 2022 at 12:07 AM
    #39
    Mech_Eng
    Mech_Eng Well-Known Member
    Birmingham, AL
    2009 TRD 4x4 DCSB
    See Build Page
    Did you go with prochargers tune or something different? I purchased a PD supercharger last year. I kind of regret not going centrifugal. Congrats on the new purchase.
    Jmiller78[OP] likes this.
  20. Aug 13, 2022 at 12:49 PM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The manual is pretty stout, until you get over 500wtq. At least the 4wd version.
