Anyone got the long travel kit from allprooffroad.com?
Discussion in 'Long Travel Suspension' started by harrison20, Jan 7, 2018.
  1. Jan 7, 2018 at 10:39 AM
    harrison20
    harrison20 [OP] Well-Known Member
    If so what do you think of it?
  2. Jan 7, 2018 at 10:40 AM
    harrison20
    trying to decide what kind of suspension I want to fit 33's or 35's
  3. Jan 7, 2018 at 11:42 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    What’s all proof froad?
  4. Jan 7, 2018 at 12:26 PM
    harrison20
    ollproofroad.com. Tire size and long travel. Not too considered about cost. More about flexibility.
  5. Jan 7, 2018 at 12:28 PM
    harrison20
    allprooffroad need 2 inch longer axles. can use standard sides. Chaos need 6 inch longer axles I think. Need aftermarket sides.
  6. Jan 7, 2018 at 12:31 PM
    Blue_Heeler13
    Blue_Heeler13 Well-Known Member
    Kirk
    North Carolina
    2017 TRD OR 4x4
    You might wanna post this up in the suspension forum since it relates directly to LT. I have no experience with LT stuff, but i did have Allpro UCA's and Allpro bumper on my old 2nd gen tacoma and liked the product.
    BlueFalconActual likes this.
  7. Jan 7, 2018 at 3:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  8. Jan 14, 2018 at 8:19 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I have their old style kit that they no longer produce.
    Buy Total Chaos.
    Coot83 and Dalandser like this.
  9. Jan 14, 2018 at 8:25 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I've seen a few switch from the allpro (+2 kit only) to total chaos. TC make a +2 & +3.5 kits. I will definitely be going TC or solo
    Dalandser likes this.
  10. Jan 14, 2018 at 8:27 PM
    Oreo Cat
    Baja kits also makes one, haven't seen very much about it tho
  11. Jan 14, 2018 at 8:29 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Oreo Cat[QUOTED] likes this.
  12. Jan 25, 2018 at 8:56 AM
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    I have the All Pro +2 new LT/Fox 2.5's on 35's. Have a thread about LCA tolerances being off when I received it. Still waiting on replacements to arrive. I've been beating it up in the meantime though and it's held up well. Other than the fitment being off, which is destroying the bushings, it rides great.
    Wish I'd have went with LT sooner. If I could do it again I'd just go with the Total Chaos +3.5 and 4" mcneil fenders. Got the McNeil 2" fenders and they fit and look amazing. Have to shim the stock bump to keep them from getting destroyed. I knew it was a bit too close and first time I stuff them at speed it crushed the passenger side and cracked it up.
    Right now I'm contemplating just buying the TC 3.5 race kit since I need to re-order fiberglass anyways.
    EDIT: Here's that thread.
    https://www.tacomaworld.com/threads/all-pro-long-travel-help.520312/
  13. Jan 25, 2018 at 10:31 AM
    Oreo Cat
  14. Feb 19, 2018 at 8:54 PM
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    If I hadn’t happened upon a set of King extended travel coilovers at a decent price, I was going to pull the trigger on the TC Race kit +2. Reason being comes down to what they claim as having 2” more ground clearance on the lower control arms. Comparatively, between all the kits, they will pull the same numbers, with the exception of AllPro’s. The difference (.5”) comes from the UCA uniball (what they claimed). The .5” and cheaper price tag was tempting, but if the LCA gives you 2” more ground clearance, I’d take that all day over .5” of wheel travel (confirmed they measure at the wheel).
    Just my $.02 from a non long travel guy.
  15. May 21, 2018 at 11:04 AM
    bmoorefree
    bmoorefree New Member
    Josh
    2006 Tacoma Quad Cab 4x4
    My truck has the AP long travel kit (about 7 years ago). Its still on there, but am slowly having to replace heim joints and now CV's. I have been looking around at whats next, from my research on TW, AP is not the way to go based on other peoples experiences. I have had to contact them several times over the past few years and I have nothing bad to say about the service I received. all I can say, is that some of the parts from my kit were discontinued. For example, they told me that the tie-rods are now setup to use stock ends on the extended tube. --it was sold with the heims (I had to order heims through them from another MFG).
    The kit they offer now is slightly different than mine. For example, the solid LCA where mine is just tubes.
  16. May 28, 2018 at 10:53 PM
    Mxpatriot
    I have had their older style 2nd gen kit for the last 6-7 years.
    Buy a TC kit. The AP kit's geometry and tolerances are just not up to par with TC.
  17. Sep 26, 2018 at 7:06 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Old thread I know and I really hate to just bash on a company but AP's products are plain and simply imitation. If you're just after the look of long travel, they may be what you want, depending on your budget. If you want to actually use the suspension, I would highly advise against AP as a whole.
  18. Sep 27, 2018 at 5:43 PM
    Blandino
    Damien
    Whistle Tip Exhaust
    Agreed. Their kit was a pretty major headache overall. Haven't had any issues with the TC +3.5 Race kit w/ heim uppers yet. The bushing deflection on the AP kit due to poor fitment is just ridiculous.
    Clay_916[QUOTED] likes this.
