Anyone had issues with the airbag light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sramirez1516, Jun 4, 2019.
  1. Jun 4, 2019 at 7:25 PM
    sramirez1516
    sramirez1516 [OP] Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    My 02 prerunner 2.7 light went off today it blinks a few times stops and it doesn't it again. How did you fix it?
  2. Jun 4, 2019 at 9:04 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    The only time I've ever had the airbag light is when I was messing with the seatbelt retainers. So, two things you can look at:
    - unplugging the passenger airbag sensor under the passenger seat (two-wire plug, should be white connector with black plastic shield). This will deactivate it all together (default off)
    -take your rear side panels off to get access to the seatbelt retainers. Ensure that the little yellow connectors on the side of each (driver and passenger) are secure and haven't wiggled loose somehow. I'd be surprised though since I'm pretty sure there's a metal latch over those...unless that car's been in a bad accident before
  3. Sep 27, 2019 at 3:25 PM
    TacoMan1207
    TacoMan1207 Well-Known Member
    Charles
    2017 DCSB TRD OR
    Cooper AT3/4S
    I had issues with mine when I hit a nasty pothole. Wound up having to hit the dealership and having to have the sensor recalibrated.
  4. Sep 27, 2019 at 6:16 PM
    Funkensour
    Funkensour Well-Known Member
    Vincent
    Columbus, OH
    2004 Prerunner SR5 Tacoma 2WD
    scion xb seat swap/ 3rd gen 4 runner swap in progress
    I have problems with my 04 prerunner. Got code B0101 ordered new clockspring. Haven't taken it apart yet
