Anyone had low diff fluids?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RmikeD, Mar 8, 2016.
  1. Mar 24, 2016 at 11:57 PM
    #101
    madcop94
    madcop94 Well-Known Member
    Northern Maine
    2016 TRD SPORT 4x4 DCLB Silver Mist
    Window tint, BF KO2's
    Had front diff-rear diff and t case checked yesterday and all were fine. U joints were bone dry though.
  2. Mar 26, 2016 at 7:28 PM
    #102
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Both mine were full. Drained and filled with Amsoil Severe Gear.
    The hammer likes this.
  3. Mar 30, 2016 at 8:32 PM
    #103
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    My trd offroad 4x4 built mid December 2015 from Texas plant. Transfer case full, rear axle about 3 ounces low probably within minium spec. Front axle way low at least 20 ounces. Now to get the guts to check the automatic. I have the tow package so I am guessing I will find it low. Shame on Toyota I expect better than this from a new truck.
  4. Mar 30, 2016 at 9:26 PM
    #104
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I wanted to use redline but even with 30% discount it was $28 a quart. I went with Lucas for $13 a pop.
  5. Mar 31, 2016 at 5:40 PM
    #105
    Glenn141
    Glenn141 Well-Known Member
    Glenn
    Central Florida east coast
    2016 TRD off road DC SB 4x4 silver
    My new DCOR 4x4 was 9 oz low front diff, 20 oz low rear diff, 24 oz low trans, dry u-joints and 1/2 the rear u bolts were under torqued. Other than that it was good.....
    taco 16 likes this.
  6. Mar 31, 2016 at 7:25 PM
    #106
    taco 16
    taco 16 Well-Known Member
    Lance
    San Diego
    2016 DCSB TRD Sport 4x4
    Front diff was 3/4 of a quart low and rear diff was a full quart low.
  7. Mar 31, 2016 at 7:32 PM
    #107
    renau001
    renau001 Well-Known Member
    ...yeah, other than that :)
    Wow, what is going on with these assembly issues. No offense to any members in the industry here, but I can't say I'll ever seriously consider buying an American-made vehicle again.
  8. Mar 31, 2016 at 7:46 PM
    #108
    NM Lance
    NM Lance Well-Known Member
    Rather than reading through six pages of this... Is this more commonly an issue with the 2016's than previous years?
    I am about to change the diff's/xfer case and transmission oil in my 2014, and I am going to be inventing swear words if I find any of them abnormally low.
  9. Mar 31, 2016 at 10:07 PM
    #109
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    It's perfectly normal for gear oil to break down more than normal and to have some extra fine particles when initially breaking in the ring and pinion. If you look at the instructions for initially driving with a ring and pinion from an aftermarket company they'll make a big deal about the importance of taking it easy while new and replacing the fluid for the first time after very little use. The axles are the main reason Owner's Manuals talk of a break-in period at this point.
  10. Mar 31, 2016 at 10:10 PM
    #110
    computeruser6
    Dirk
    Escondido
    Yes, the Mobile 1 will be fine. I just use conventional since I go off-road a lot and change the gear oil frequently; makes it a lot cheaper. I would recommend changing all of the fluid out though and getting rid of the initial wear products. If you live where it's hot or tow a lot it might be worth going to a higher weight in the rear axle. I throw 85W-140 in the rear axle of the Tundra during the Summer and switch to a lighter weight in Winter.
    Bossman14[QUOTED] likes this.
  11. Apr 1, 2016 at 3:32 AM
    #111
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You're not telling me anything new.
  12. Apr 2, 2016 at 2:50 PM
    #112
    Markc1024
    Markc1024 Well-Known Member
    Just checked mine. Rear diff 20 ounces low, front 8 ounces low. Transfer case was full.
  13. Apr 21, 2016 at 1:53 PM
    #113
    epluribusunom
    epluribusunom Well-Known Member
    Luke
    '16 White SR5 4x4
    Just checked both of my diffs. Rear diff seemed to be fine, transfer case was definitely full, however the front diff did seem a little low. I could feel the oil with my pinky however it was a bit down there. I have 500 miles on the truck currently and all of the oils were clear as water.
    My question is; is the front diff engaged at all when in 2wd? From my understanding it is not, so if mine was low and I have actually never engaged it I have nothing to worry about?
  14. Apr 21, 2016 at 4:57 PM
    #114
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Checked my rear and it was fine. Front Diff...I cannot touch the oil...need to fill tomorrow. Did not check Trans case yet.
  15. Apr 23, 2016 at 11:12 AM
    #115
    CheapLaborTJ
    CheapLaborTJ Well-Known Member
    Hello to all. I've enjoyed reading TacomaWorld for years and finally signed up.I drove an R-22 for 16 years and can say it was by far the most reliable vehicle I ever owned.
    I'm surprised to see Toyota delivering Tacoma's that are low on A/T fluid,not greased properly and are low on gear oil.This should not be happening and there is no excuse to ship a new vehicle from the factory low on any fluids.
    As part of their job I would think the dealer would also check all the fluids and grease fittings before delivery to the end user.It's called customer service.
  16. Apr 23, 2016 at 12:46 PM
    #116
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    Props to Pedersen Toyota! I looked underneath to see if they checked what they said they checked before purchase. Ubolts, ujoints, transfer and diff fluids all checked and adjusted during PDI.
  17. May 3, 2016 at 10:30 PM
    #117
    roto prop
    roto prop roto-prop
    Washington
    2016 Tacoma TRD BC DC/OR/LB 4x4 Tow pk , jbl premium
    Dipped front grill , vinyl tail gate letters , vinyl door sill lettering , vled interior lights , Vled back up and license plate lights , Vled switch back turn signals and brake lights , h9 low beam light mod , OEM bed matt , Raised front seats.
    USE THE 75W90 If you really want to treat it put some amsoil severe gear synthetic oil in it. Your diff will love you.
  18. May 4, 2016 at 4:45 AM
    #118
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    dealers don't, no money it for them. many don't even check it
    when you bring it in and ask, again, not worth their time. pretty f'd up.
  19. May 4, 2016 at 5:28 PM
    #119
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I had little to know fluid in mine and @ 551 miles, she had to be replaced with a new one.
  20. May 5, 2016 at 5:10 AM
    #120
    BlkTaco47
    BlkTaco47 Unhinged
    how did you know? did issues arise?
