Anyone had the bulb go out behind the ac/heat position selector?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeper2269, Aug 4, 2011.
  1. Aug 4, 2011 at 2:55 AM
    jeeper2269
    jeeper2269 [OP] Well-Known Member
    the bulb went out behind the selector for heat/ac all the way to the right side. anyone had this happen? and how to fix?
  2. Aug 4, 2011 at 4:00 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    there are two bulbs on the back side of the ac assembly twist out and replace with new toyota lightbulb. i had the left side light go out, couldnt find the bulb anywhere at an auto parts store went to dealer and got one same bulb for both sides. good as new
  3. Aug 4, 2011 at 4:30 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    i'm pretty sure replacing the bulb fixes the problem
  4. Aug 4, 2011 at 4:34 AM
    mwtaco
    mwtaco Well-Known Member
    07DCSB Black
    look up the pics on howbto install radio. this is how u remove the ac panel. behind it there are two small bulbs. prob just need to replace it. although mine went out and it wasnt cuz it burned out. i must have knocked it loose when i did my radio install. in any case, its pretty ez.
