Anyone had the Locker Actuator go bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedskinRedTaco, Nov 10, 2010.
  1. Nov 10, 2010 at 11:01 AM
    RedskinRedTaco
    RedskinRedTaco [OP] Well-Known Member
    Paul
    Virginia Beach, VA
    07 TRD 4x4 Offroad Crewcab
    Trifecta folding Touneau Cover, 275/70/16 LTX M/S, Running Boards, Dynamat, tint, Alpine W404 Video system w/ backup cam, Sirius Sat, Polk Audio Component Speakers frt and back, Alpine 4x50 amp. Billy's 5100's set @ 1 3/4, 1" rear blocks, Rear TSB, trimmed frt mud flaps 4", TRD Exhuast, K&N filter. Electric Brake.
    Brought my truck in for its 30K service and to get my locker looked at. Turns out the Actuator was bad. its getting covered under my 100K power train warranty. Has anyone else had this happen?
  2. Nov 10, 2010 at 11:38 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
  3. Nov 10, 2010 at 12:57 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    They dont really go bad, its more like they get cranky from not using it. :D
    I bet service guys just remove it and clean it then either install used one back or if on warranty they will order you a new one and have yours for somebody else. :)
    However, if you push them to limits and have them in service for many years at some point they will need maintenance. usually is getting grease inside the actuator or when you bash them on rocks magnets will crack.
    Another item is plug getting screwed because branch had ripped the wire.
    If you have trouble and you are:
    1. On warranty - then go to dealer
    2. Outside warranty - remove it clean it, grease it and called it good.
