Anyone had this vibration before?
Discussion in 'New Members' started by zgraphic, Jul 19, 2009.
  1. Jul 19, 2009 at 6:23 AM
    zgraphic
    zgraphic [OP] Member
    Sean
    Texas
    05 tacoma DC TX
    Under cover tonneau cover, 2006 OEM 16 inch Wheels, Yokohama geolander HTS tires, German shepherd mix guard dog
    Hello all, new to the forum here.
    I am scratching my head over the Washboard like ride I get at very low speed (stopping and starting), 5-10 mph.
    Truck is at 60000 miles just did dif service, will be doing propeller shaft today. I did change the wheels from the stock 20 inch chrome godawfulness it came with to some nice unobtrusive Toyota Stock 16 inch rims from a 2006 Taco. At the same time changed tires to Yokohama hts geolanders.
    So far I have completed the following diagnostic work:
    Shudder occurs in drive and neutral brakes no brakes
    Removed rear drums and checked for warpage none found, replaced retension springs on both sides
    Had tire dealership install stock dunlops to rule out some of the posts I have read about Yokohama tires. And still had vibe
    That about covers it...
    Any advice would be appreciated. thanks and howdy,
  2. Jul 19, 2009 at 6:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Do you have a lift? How does your carrier bearing look?
  3. Jul 19, 2009 at 6:48 AM
    zgraphic
    Sean
    Texas
    05 tacoma DC TX
    I do not know if the texas edition had a lift. I am new to this vehicle bought it in june. Is the carrier bearing something that I can replace? I have seen many post about it and high speed vibes but none about anything like this. Admittedly this is a little over my head experience wise but I am pretty good with the hands.
  4. Jul 19, 2009 at 7:23 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Hello Sean!!
    Welcome to the forum!! Glad to have you...
    This section is for introductions only! Ask actual questions in the appropriate forum
    Woooowooooo Anotha Texan in da house!!
  5. Jul 19, 2009 at 7:27 AM
    zgraphic
    Sean
    Texas
    05 tacoma DC TX
    Dang Sorry bout that. Will repost elsewhere.
